Question about Casio Exilim EXS10BK Digital Camera
Casion Exilim EX S10 camera won't turn on...
I have had my Casion Exilim EX S10 for about 4 months. I have been using it with no problem until about 2 weeks ago. Now, though the battery appears to be charged and the camera has never been dropped/bumped, the lens will not extend. The camera is totally out of commission. It is always in a case, never dropped, nothing spilled on it. Should I try a new battery? Is there a larger problem?
  • sandina Dec 02, 2008
    MIne is similar. I lost the original charger, so I couldn't turn mine on either--it had last been used in Aug. (had about 100 shots on it), so I assumed it was a dead battery.  Finally got a replacement charger, put the battery in once charged, and it would turn on long enough to reset date and time; then when I tried to go into camera mode it turned off. Kept retrying--a couple of times it turns on briefly, then the flash recycle light flashes green and it goes off. Try again and I get error message "retry power on" and it shuts off. I do and then I get "lens error" before it shuts down. After about 10 tries it finally stays on (recycle light glows amber).  Sometimes popping the SD card out and then back in allows it to turn on and stay on. Battery indicates a full charge.  Have insane time trying to figure out controls--tried to figure out how to dispose of bad shots and accidentally stumbled across the slideshow, which went swimmingly.  No online manuals, apparently, and the paper manual (which I, mercifully, also mislaid) appears to have been written in Martian by dyslexics.
SOURCE: Casio camera LCD screen broken?
I wouldn't buy this camera. The screens brake very easy.I bought mine from PRESTIGE CAMERA.THEY SOLD ME A WARRANTY THAT IS A RIPOFF.They told me the warranty would cover anything but they layed to me.BE AWARE OF PRESTIGE AND THE WARRANTY THEY SELL>
Posted on Jun 14, 2008
SOURCE: my casio exilim ex-z75 battery charging
OK- This has already been answered, I believe- if you are in the USA, call CASIO AMERICA at (800) 435-7732 between 9am-8pm EST Mon-Fri.- they will help you. The rep. at CASIO tells me that this model has a problem battery, basically. They were helpful (unusual, I know), the whole call only took 3 minutes, and she said that I should have my new battery kit in a week or two.
Posted on Jun 17, 2008
SOURCE: Exilim EX s600 lens grinding on extension
I had the same problem and I left it on the charger over night and in the morning I turned it on and the lens extended smoothly with no noise and is now focusing
Posted on Nov 25, 2008
  • 13433 Answers
SOURCE: wrong language
Hey,
here is the user manual for ex-s100
http://exilim.casio.com/resource/pdf/manuals/EX-S100.pdf
if you can't open the user manual you will need a pdf reader
http://www.adobe.com/products/reader/
Note that the Casio link before may be slow, if it doesn't open in few minutes right click on the link and select save as.
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 21, 2009
welcomejee
  • 10594 Answers
SOURCE: INSTRUCTION BOOKLET
Click Casio Support to download instruction manual of EX-S10
Posted on Feb 27, 2009
Casio exilim EX-S10 wont turn on and lens stuck out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here is a video summary of the steps:
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
Need usb cable to casio exilim camera EX-S10 what type of USB connector is on this camera, not mini A or B. thx
i f i remember correctly, this camera has input/output terminals. both for USB/AV port and a USB: high speed USB.
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ120460169326QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item1c0bfc506e&_trksid=p3286.c0.m14
http://cgi.ebay.com/Casio-USB-cable-Exilim-EX-S10-S5-EX-F1-EX-Z100-150-200_W0QQitemZ110426500160QQcmdZViewItemQQptZCamera_Cables_Cords?hash=item19b5eeac40&_trksid=p3286.c0.m14
Aug 31, 2009 | Casio Cameras
Casion Exilim EX-S880 Charging Error
Clean your connecting areas with alcohol . If that dont work . It could be a bad battery
Aug 18, 2009 | Casio EXILIM Card EX-S770 Digital Camera
Taking photos with casio ex-s10 goes all white
It don't work shutter. You need in repair lens unit.
May 16, 2009 | Casio Exilim EX-S500 Digital Camera
Repeated lens error after Casio already fixed it once
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 02, 2009 | Casio Exilim EX-Z750 Digital Camera
Camera does not respond
I suggest you open the battery compartment and check the connections on the battery. It may be that they are a little dirty, preventing proper electrical connection, in which case you can clean them with a little cotton bud and perhaps some methylated spitits.
Mar 15, 2009 | Casio Exilim EX-Z50 Digital Camera
Battery Problem Casio EX-S880 Digital Camera
Ive had this happen twice. The first time I went back to the store and talked to the tech people to see if it was a problem with the camera itself but ended up buying a new battery. About a week ago, I finally found my charger to plug in the camera that I hadnt used in weeks to find the same problem once again. It must stem from long periods of non use. After finding this question I continued my research and the Casio website tells you to call 1-800-435-7732. Dont know if that helps much but I will be calling them in a little while. Good luck.
Mar 08, 2009 | Casio Exilim EX-S880 Digital Camera
INSTRUCTION BOOKLET
Feb 27, 2009 | Casio Exilim Card EX-S100 Digital Camera
I NEED INSTRUCTIONS FOR MY CASIO EXILIM EX[-S10
You can download the manual from the link below, do not forget to rate the solution:
Click here to get the manual : EX-S10
Alternatively EX-S10.
Thanks.
Feb 27, 2009 | Casio Cameras
Casio Exilim EXS10BK Digital Camera Logo
397 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
Are you a Casio Camera Expert? Answer questions, earn points and help others
