Question about Hampton Bay Dryers
Broken Switch The three speed switch for my High Velocity Fan Mode # FE4-50AdO Serial # 01730 is broken. I need a replacement part.
Pranavendra
  • 16 Answers
SOURCE: 3 speed ceiling fan
I could not understand that "all the three positions are on high speed and off" ? How can be it possible that all the (three) positions give high speed and at the same time no speed (off)? Please explain.
 What I feel that the speed controller be in series with the fan. "in series" mean that the wire should come from phase or line, go to the speed controller , then go to the fan, then finally go to the neutral point. This completes the circuit.
 I will be happy to know more about this if it could not solve your problem.
Posted on Nov 29, 2007
  • 79 Answers
SOURCE: Fan switch broken, wires out when opened
I googled Hampton Bay Manufacturing and this is what I found:
Hampton Bay fans are manufactured by "King of Fans Manufacturing, FL". The contact number for them is 800-330-3267. ...
Maybe they can supply you with a wiring diagram.
Posted on Jun 11, 2008
  • 36 Answers
SOURCE: ceiling fan woobles on high speed
Turn off fan, then check to see that all of the blade mounting screws are tight. (check blade to blade arm and blade arm to fan body screws/mounting mechs.) If none are loose, you can purchase a blade balancing kit from most hardware stores, including Home Depot and Lowes. Let us know if this helps or the cure you come up with.
Posted on Aug 23, 2008
  • 13 Answers
SOURCE: Broken ceiling fan switch
home depot, Ace, true value cary rhem, probably better quality, doesnt sound like the one aloha uses are very rugged
Posted on Jan 27, 2009
Fixe_You
  • 1800 Answers
SOURCE: Only have 2 speeds on a 3 speed ceiling fan- replaced switch, no
no no the problem is with the switch u need to re programm the wires check the old switch
and make the same conection.
Posted on Feb 08, 2009
On a 2007 lincoln navigator the a/c fan motor will not shut off. the fan adjustment bars are showing slower but still the fan is on high
The fan speed reostat is broken or the switch itself is bad. Try replacing the switch first because the motor speed reostat is part of the motor itself. $$$
Aug 30, 2014 | 2007 Lincoln Navigator Luxury
Polar Aire 20 In. 3-Speed High-Velocity Floor Fan on off switch wiring
i need an on/off switch for my utilitech 20" high velocity floor fan model # LF-20MCA
Mar 26, 2012 | Dryers
My interior fan (air conditioning fan) suddenly doesn't work on positions one (lowest) and two, but works fine on positions three and four. What gives?
The fan uses a resistor block that creates the various fan speeds. It sounds as though the lower two fan speed resisitors are broken. This means you will have to replace the fan resistor block. The only other possibility would be the fan switch on the dash you use to set the speed. It is most likely the resistor block, but if you are handy with a test light, you can verify the switch is good or bad, or take it to your favorite mechanic and have him or her verify.
good luck.
Jan 07, 2011 | 2005 Jeep Wrangler
Needc to replace three speed switch for portable house fan.
Try contacting the company that built it, on line. There are shops around that repair items like yours. Try an electronics store, ie- Radio Shack
Oct 07, 2010 | Holmes Products Holmes Patton...
Kenmore over the stove microwave,model # 721.62629200,only low speed fan works on the keypad,no high speed fan.
The fan has a setting for high speed, low, and off. Fan only running at low speed.This indicates problem towards. 1) the fan motor. 2) The loose fan wiring. 3) The fan switch. IN the unit there is a motor for fan.If the motor gets weak or short. The fan will run but only at low speed.Because at high speed the motor will require more power to run.In this case motor needs to be checked and replaced. The other possibility is the fan wiring.There are two wires going from fan to motor and two going from motor to power board.If any of this wire is got loose or getting short then this will stop the fan to run in high speed.In this case the wires needs to be checked and reconnected properly. In the unit there is a switch internally.When you select the fan to high speed mode the switch goes up. when you select the fan to low speed mode the switch turns down.But if the switch is faulty or got worn out.Then it will not move properly up/down.In this case switch needs to be replaced.IN some brand models the High speed and low speed are directly controlled from front control panel.There is no switch in that models.In that case the control panel needs to be checked and replaced. Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 10, 2010 | Kitchen Ranges
Broken on/off switch
YOU CAN GET A NEW SWICTH AT ANY HARDWARE STORE. SHOULD BE A PRETTY EASY REPACEMENT
Sep 21, 2009 | Hampton Bay 30 In. High Velocity Pedestal...
Wiring on a 3 speed rotary switch for a fan (cord type),the switch just broken and i want make a connection on wires for just to run at only one speed.
put the 2 white wires together then try one of the other wires from the fan to the black power wire,if to slow try the other wire if that speed works tape off the other wire . it should be white to white and red to black green is ground
Sep 03, 2009 | Patton U2-1487 Floor / Box Fan
Speed control switch
I saved this text I found when I was researching this a while ago.
Let us know how you do.
Wiring a three speed fan switch
My daughter called me the other day and said Dad the ceiling fan in the kitchen is not working only the light works. I went over and removed the three screws that hold the light and pull chain for the fan down and found that the fan control switch had snapped open and all 4 wires had popped out. The snap clips on each side of the switch had broken off. I went down to Home Depot in the ceiling department and found the switch I was looking for. It said for a four wire ceiling fan. OK, know lets put it back together. First of all if you look at the new switch you should see four holds were the wires will be pushed into. The black wire in the fan is the hot or load wire, this wire is hot whenever the wall switch to the fan is turned on. Put this wire in the hole that is marked “L” this stands for load. Now with this switch in the off position the fan will not work until you pull the chain. The other three holes are marked #1, #2 and #3. On most fans #1 is usually high speed. # 2 medium and #3 low speed. What you now have to determine is what wires are high medium and low. The easiest way to do this is before you put any of the wires back into the new switch is to FIRST MAKE SURE NO POWER IS GOING TO THE FAN. Then simply take one of the colored wires at a time and twist it together with the black hot wire.
Turn the power back on to the fan and knot the fans speed. Do this with all three wires one at a time until you can determine which wire is high speed. Note the color of the wire and mark it down on paper.(Example; blue wire high speed.) Do this with the other two wires to determine there speed. Once you have the speed of each wire you can reassemble the new switch.
Black wire (Load) goes in hole marked L. High speed wire goes in hole marked # 1. Medium speed goes in hole marked #2 and low speed goes in hole # 3. MAKE SURE THE POWER TO THE FAN IS TURNED OFF WHILE YOU ASSEMBLE THE NEW SWITCH.
For those of you that have all these wired hooked up right and still the fan won't work I would then look for an open neutral wire. It should be a white wire. Check to see if all the wires are securly attached.
Good luck. One more word of advice. If you're not sure on what you are doing when it comes to electrical wiring then please do not attempt to do this or any other electrial work yourself. Call a licensed electrian. Any mistakes on your part could void your home owners insurance in case of a fire.
Aug 06, 2008 | Hampton Bay 24002 Ceiling Fan
Dryers Logo
94 people viewed this question
Top Hampton Bay Dryers Experts
Steve
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
