Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Whirlpool dryer will not heat properly
I have a whirlpool Kirkland Signature dryer has no heat and runs continuously ?
  • 2 more comments
  • Sagat2 Nov 14, 2008
    I've got the same problem. I've got a Kirkland badged Whirlpool dryer that doesn't heat up and will run continuously. In more details, the burner will only come on a couple times before it fails to light up again. If the dryer is on its automatic cycle setting (with no timer), then it keeps running because the humidity never drops.
    I'm just digging into the problem, but I'm guessing either a thermostat/thermocouple isn't functioning properly and causes the gas to shut off; or a solenoid has gone bad on the burner assembly that fails to open the gas valve when it's supposed to.
    Please repost the solution when you find it, and I'll do the same!
  • dpdillon Jan 03, 2009
    Me too. I'll test your your suggestions and report back
    Gas dryer
  • gas or electric?
My dryer gives off heat when no close are in it. but as soon i put close in,the dryer will not heat up.
Posted on Mar 15, 2009
I replaced the igniter, sensor and two coils. the dryer works now. I don't know which one was the culprit but after $81 of parts, I'm up and running.
Posted on Jan 08, 2009
  • 67 Answers
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Jan 07, 2009
  • 734 Answers
I am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
Posted on Dec 12, 2008
My Kirkland dryer model # sdgs800jq2 will turn on but no heat
Recheck your model number. It is not coming up on my search but I can give you an answer regardless. The Kirkland Dryer is one of many whirlpool dryers sold under a private label so it can be sold at lower price. It works the same as most dryers. The heat cycle is regulated by 2 components other than the heating coil & timer. They are a thermal fuse to prevent fires and a thermister that turns the coils on not to exceed a predetermined temperature followed by a cool down period until it resets. So the heater is constantly turning on and off. 2 problems can happen. 1) The heater coil can burn out or 2) the exhaust can clog resulting in the dryer over heating and blowing the thermal protection fuse. If your exhaust comes out on top of the house I'd be willing to bet there's a clog just a few inches inside the exhaust outside the house. Some of these require you to cut it open to get at it. Before you do that, get an ohm meter open the dryer housing and test the fuse, thermister, and heater coil. There are numerous youtube video on how to do this seach for them on youtube. Most have to do with continuity. No continuity means the component is broke. For parts, see your local appliance store that has a parts department. Everybody stocks Whirlpool parts. And if worst comes to worst, write down you model number and go to repairclinic.com & enter your model number into their self help section for step by step instructions & video links. Good luck.
Aug 24, 2015 | Dryers
I have A whirlpool kirkland signature 4 cycle heavy duty xl capacity dryer that is not putting out the heat as it was A few days ago. I have cleaned out the vent area to the outside and still nothing. The...
did you clean out the duct that the lint filter slides down into?also remove the vent line from the back of dryer and start it,if it blows strong you still have something in the vent line,stick a leaf blower into the vent line and blow it out to the outside,if the vent is clear then you know there's a block in the dryer or you have a bad blower wheel,if the wheel is bad when you first start it you might hear the blower wheel banging around or make a sound that isn't supposed to be there,i don't know what a kirkland dryer is so next time open the door and send the model number off of the dryer.
Dec 28, 2017 | Dryers
Whirlpool Model SGDS800JQ2 gas dryer getting no heat
Check to make sure the burner ignitor is not burned out. Check all the other parts you mentioned........ pull one wire off each part(one at a time) and check with with with an OHM meter.... should all be in the closed position.
Mar 16, 2010 | Whirlpool Dryers
Our dryer (kirkland signature by whirlpool) quit heating, tumbling, and blowing. When its plugged in you can hear electricity running but nothing happens. the light stil works inside. we have removed the...
soundes to me like the thermal relay has opened. You have to remove the back and check all fuses....some are round some are oblong. remove both wires and test for continuity.
Sep 16, 2009 | Whirlpool Dryers
Ihave a kirkland signature dryer model#seds800jqo dryer runs but
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jul 23, 2009 | GE Profile DPXH46EA Electric Dryer
My Kirkland Signature Whirlpool Washer will not agitate or spin and the motor makes a load noise (like something rattling) when the tub should be moving. but it does drain water.
broken coupler. device between motor and gearcase, look under washer behind the motor for small plastic and rubber coupler. may be worn or broken. cheap part/fairly simple fix. parts house will run ou through the process or i can provide details when you are ready.
May 24, 2009 | Washing Machines
Kirkland Dryer drum does not rotate, but heat comes out
check capacitor next motor its a white long got three clips coming off it change good luck
shaun
Jan 16, 2009 | Whirlpool GEW9250 Electric Dryer
I have a Kirkland Signature dryer made by Whirlpool. It is about 2 years old. The model number is SEDS800MQ1. The dryer will not heat. All of the other functions are working, it just will not heat. It...
maybe your dryer doesnt like you...
naw im jsus playen try to clean the filter on top or somethin or maybe suttin wrong with your boiler
Oct 06, 2008 | Dryers
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
850 people viewed this question
Dan Webster
Dan Webster
Sal De
