Question about Altec Lansing AVS 500 Computer Speakers
I'vebeen given an Altec Lansing Spealer system, AVS500, for a computer, but it is missing a power supply; 18 volts DC and 1 amp. Altec Lansing no longer make that series or its components Any suggestion as to where to get compatable component?
  • 1 more comment
  • Anonymous Dec 17, 2008
    where does ther black wire connect?
  • pfcarnaghe Jan 20, 2009
    Need the power cable AVS500 18 volt 1.0A any place I can get one?
  • Anonymous Feb 16, 2009
    I've been given an Altec Lansing problem, and notify you when a new solution is offered.
Lost instructions on how to hook up. Large speaker makes static. Right speakers work great.
All colors match but can not find the proper jack for the black wire coming out of large speaker
I suspect this is the problem
Posted on Nov 13, 2008
Replacement power supply - can i convert AC to DC output connector?
I'm not clear on the four pins of the DC power supply for the speakers. Do you think there two different voltages needed??? It's not worth trying to convert your ac power supply/ It would take a few parts and you will not end up with 18 vdc. You can purchase a 18 v dc adapter for as little as 15.00.
Jun 16, 2014 | Altec Lansing M604 Computer Speakers
Ac adapter for altec lansing model#acs40 voltage,current & polarity
Altec Lansing Model Number A 1664
Output 15 volts DC 800ma
center Positive +
Jul 29, 2010 | Altec Lansing Multimedia Computer Speakers
When power supply pluged in the wolfer makes loud noise
Try turning the volume down on your computer or on the woofer itself.
Nov 26, 2009 | Altec Lansing AVS 500 Computer Speakers
AVS500 Woofer has low Freq.pulse.front and back speakers working. Need circuit diagram to trouble shoot . Henry
Is the power supply AC or DC. I had a similar problem with my boston acoustics speakers, and I was able to swap the power supply for a DC output one of the same voltage and amperage and the hum went fully away. it is an inverter circut that went bad in my woofer.
Jun 13, 2009 | Altec Lansing 621 Computer Speakers
Power supply AVS500-A6860 fried
This one might work, but I'm not 100% sure on the connector:
Feb 16, 2009 | Altec Lansing AVS 500 Computer Speakers
I have altec lansing speakers AVS500 and have no sound
It sounds like the subwoofer speaker has blown. If you are comfortable working with a soldering iron and speakers then you can open the case and replace the speaker with a replacement subwoofer speaker. A good online store for replacement speakers is
Dec 28, 2008 | Altec Lansing AVS 500 Computer Speakers
What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Nov 20, 2008 | Altec Lansing AVS 300 Computer Speakers
Voltage adapter
NO, it is very under rated and powered. You need an 18 volt and not a 12 VOLT. They should not be that hard to find in an electronics store. Also the amp rating is also important. Make sure you are matching both amps and volts AC or DC to the the label on the woofer or you could end up blowing the out.
Sep 24, 2008 | Altec Lansing AVS 300 Computer Speakers
Altec Lansing computer speakers model AVS500
18VDC 1000mA Center Positive.
Part Number: AVS500-A6860
Model Number: 9701-00648-1UND
Jun 02, 2008 | Altec Lansing AVS 500 Computer Speakers
AVS500 altec lansing computer speaker system powered subwoofer
Its due to your speaker power supply failure or switch! get them checked your speakers will be ready!
Nov 02, 2007 | Altec Lansing 621 Computer Speakers
Altec Lansing AVS 500 Computer Speakers Logo
419 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
