Question about Dryers
GE GAS DRYER DOES NOT HEAT. IGNITOR DOSE NOT GLOW. DO I HAVE TO REMOVE THE FRONT PANEL TO REPLACE IGNITOR? THANKS, FRED
    Novelist:
    Champion:
  • 261 Answers
Which model of gas dryer? May have other issues than the ignitor.
Posted on Oct 17, 2008
GE Profile gas dryer tumbles but NO HEAT, not ignitor
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Apr 30, 2010 | GE Profile Harmony DPGT750GC Gas Dryer
Is there a heating elemant in a gas dryer and if so how do I find it
Hi. The answer to your question is no. A gas dryer dose not use a heating element, for drying. It will use a burner assembly to create the necessary heat for drying the contents.
NOTE_ There is an ignitor. This device is the only component that can be considered an element, but it is strictly used for starting the flame. It is not used for heating purposes. If this is what you are referring to, simply follow the procedure below to inspect this device for faults.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the unit the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working. If the ignitor did not appear to function and it is the spark type, it may be out of adjustment which generally requires professional service or it may require replacement. If the ignitor is the glow type, you can test it for resistance with a multimeter.
The ignitor has two wires connected to it.Label the wires and connections so that you can properly reconnect them later. The wires are connected with slip on connectors. Firmly pull the connectors off of the terminals (do not pull on the wire itself). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If either is corroded they should be cleaned or replaced.
Set the multimeter to the ohms setting X1. Touch one probe to each terminal. You should get a reading anywhere between 50 and 600 ohms. If you get a reading of zero or infinity, the ignitor is definitely bad and will need to be replaced.
Dec 06, 2009 | Kenmore 73952 Gas Dryer
GE Gas Dryer (Model DQSR 483) Drum works but does not heat
There are three things besides what you aleady checked:
1. Open the small access door in front of the dryer and start the heat cycle. The ignitor must glow a bright orange so that it is hot enough to light the gas. If there is no orange glow, then the ignior needs replacement.
2. If it glows then cuts off, then glows, again and cuts off, the thermocouple sensor wire is out of position. It needs to be very, very close to the ignitor. This thermocouple sends a temperature signal when it senses that the ignitor is hot enough to ignite the gas. Unplug the dryer. Re-position the thermocouple wire mount so that the thermocouple wire is almost touching the ignitor. You may also "bend" the wire. Plug power back on and heat.
3. If it still does not heat, then the automatic gas valve that is controlled by the thermocouple sending unit is broken. The automatic gas valve cannot be safely "fixed" and must be replaced.
Hope it's just the thermocouple wire.
Oct 01, 2009 | GE DBXR463EBWW Electric Dryer
I have a Maytag MGD5800TW Gas Dryer. It does not heat up. What should I check?
First, Remove small plastic tab on front panel of dryer lower left corner. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Leave the dryer cycling while observing. When the dryer heats to temperature the flame will shut off. If the gas valve coils are bad the next thing to happen will be that the ignitor will glow orange again, the valve will click again but the flame won't light.
If the gas valve coils prove bad, based on the observations above, follow the procedure below to replace the coils. If NOT, come back with the results of your observations.
It's likely one of the coils is opening a break in the coil as the coil heats up. This coil will shrink when cool and be able to run again. The number for the coil kit, which will replace ALL the coils, for your machine is 279834.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Remove lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dyer will be on right. Gas components will be on left. Replace All coils with Kit Number listed above. Take care not to touch or hit the ignitor or you will be replacing it also. It is VERY brittle.
Service on gas appliances should be undertaken by professionals only due to the danger of gas leakage which can cause fires or death by asphyxiation.
Reverse process to re-assemble.
Sep 20, 2009 | Maytag Dryers
Whrilepool gas dryer wont heat but runs.
First, Remove small plastic tab on front panel of dryer lower below the door on left. Start the dryer on regular cycle and observe what happens through hole. You need to know if ignitor glows orange. If you do not see the ignitor glow orange, replace the ignitor. If seeing full orange of the ignitor, do you hear a clicking and see the flame light?
Sep 20, 2009 | Whirlpool LGR5636L Gas Dryer
Dryer doesnt blow hot air.
I find that quite often the ignitor is out of alignment or the glass window is covered with lint.
a gas dryer blows air through a burner assembly to heat the air. The burner assembly consists essentially of a gas valve, ignitor and a flame sensor. If any part of the burner assembly malfunctions, the result will be low or no heat and slow drying of the clothes.
There are two common styles of ignitors, glow ignitors and spark ignitors. The ignitor ignites the gas either by heating up and glowing, or by sparking. If the ignitor fails, the dryer will not heat.
The easiest way to check the ignitor is to observe it. Remove the small access panel in front, select a high temperature setting and start the dryer. Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow or spark. If you see it glow or spark, then the ignitor is working.
Aug 19, 2009 | Kenmore Dryers
Gas dryer runs but no heat
Hi, Remove the little cap on the front panel lower left corner and start the dryer. Look into the hole and see if the ignitor glows (5 - 10 seconds)
If the ignitor does not glow, try this: Normal 0 UNPLUG the dryer! Remove the rear panel of the dryer and locate the fuse. It is white and ¼” wide and 3” long. It is located on the blower housing. Remove the wires and check to see if it has continuity. If it does not, you need to replace it.
If the ignitor glows and then shuts off before you see a flame, try this:
Normal 0 UNPLUG the dryer. This model you need to remove the two screws under the lint screen. Now use a flat blade screw drive and insert it in the gap between the top and the front panel and pry the top up. Now locate and remove the screws on the inside of the front panel in upper corners. The front should lift off. You will see the two black coils on the gas valve. When you remove the three wire coil, make sure the sleeve inside it gets put back on the post the coils slides onto. I know this is a lot of info but, it's the most popular problems.
Please let me know if this help or if I can assist you further.
Vic
Jun 01, 2009 | Dryers
Dryer won't heat up
HI, Can you see the ignitor glow at all? If not, check the thermofuse first. It is located on the blower housing white, /4" wide, & 3" long. If you can remove the rear panel on your model, that is where the fuse is located. If you can not remove the back panel, some models you have to remove the whole front panel and some the lower half front panel comes off.
If the ignitor does glow, you will need to replace the coils on top of the gas valve.
I hope this helps. Please let me know if I can assist you further.
Vic
May 19, 2009 | Dryers
Ge gas dryer runs but does'nt heat
Open Front panel and check to see if ignitor is glowing when you start the dryer
Apr 16, 2009 | GE DBXR463GB Gas Dryer
No heat in gas dryer
Remove the front panel. Leave the door switch wires connected.
Turn the dryer on and look for the glow bar ignitor to glow red.
This may take a couple minutes.
No glow. Replace the ignitor.
Mar 05, 2009 | Whirlpool Dryers
Dryers Logo
76 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
