Question about JVC KD-LH810 CD Player
Need part number for faceplate connector (chassis side).
Thieves broke into the car and pried the faceplate off. (Instead of pushing the button!).  The mating connector on the head unit was damaged.  There is no part number on it.  The part number would be greatly appreciated. Thanks, Bill
2 Suggested Answers
  • 3 Answers
SOURCE: JVC KD-LHX500 has power, but won't turn on!
Replace the 15 amp spade fuse in the back of the unit. See if that get you going again. If that doesn't do it then check your wirin Black goes to ground, Yellow is a constant hot, Red is a hot trough the fuse box, Blue is for your power antenna if you have one, the Orange with a White Stripe is to the Illumination and is also hot.
Posted on Nov 12, 2008
The buttons on my Sony cdx-l410x aren't working. How do I fix it?
If it's a detachable face plate then carefully clean the contacts on the chassis and faceplate and inspect them look for bent or damaged connectors. A penciler as works great to clean contacts if this type or a q tip dipped in rubbing alcohol. If not you may need to disassemble the faceplate and clean the circuit board. I have seen, in vehicles where a drink holder is right at the radio, over time drink will splash into the face and overtime cause malfunctions. If that still doesn't work then either the faceplate is bad or the chassis is bad. Both have microprocessors that communicate to one another. At that point it is probably cheaper to replace than repair
Aug 08, 2016 | Sony Car Audio & Video
I need the security code of my car radio I removed the battery now it need a code which I don't know Kenwood PDX500M serial number 31104056 please.
For this fix you need to reconnect your battery.
1) Turn on the car.
2) The faceplate rotates out and the CODE - - - - prompt appears.
3) Press >>' and Auto keys simultaneously on the faceplate and hold for 4 seconds. (If the faceplate rotates back into the console push on the upper left top edge of the faceplate and it will flip back around. Press the Eject button and then try it again.)
4) The screen will still say CODE, but the - - - - will disappear! When this happens press the 5 key on the remote twice and it enters a K on the display on the faceplate. Hit the >>' key on the faceplate.
5) Press the 2 key on the remote three times and it enters a C on the display on the faceplate. Hit the >>' key on the faceplate.
6) Press the 2 key on the remote once and it enters an A on the display on the faceplate. Hit the >>' key on the faceplate.
7) Press the 7 key on the remote twice and it enters an R on the display on the faceplate. Hit the >>' key on the faceplate.
8) The radio goes into All Off mode and you are set! Hit the SRC button on the faceplate to select CD, Radio, etc
Dec 19, 2012 | Cars & Trucks
How to remove a stock radio in a 94 town car
Disconnect the negative battery cable. Pry the trim panel using a trim removal tool. Using a DIN "radio removing tool" push the tool into the faceplate far enough to engage the retaining clips. Apply a slight spreading force on the tools and pull the radio chassis out of the instrument panel. Disconnect the wiring connectors and remove the radio.
You can purchase DIN tools from car stereo or auto supply stores. They look like two U-shaped pieces of wire. They are cheap.
Mar 22, 2012 | Car Audio & Video
Buttons on my sony CDX-GT540UI stopped working
Sony car radio cdxgt540ui buttons non responsive - remove four screws on reverse side of faceplate, pry open with fingernails starting at the top right or left corner of the face plate once opened remove board on the reverse side of the LCD there are small brackets holding the LCD use a needle nose to pry each bracket in straight position then remove LCD for ten seconds then place back on to board and been brackets back in place. After these steps the front buttons should work again this process worked for me.
Mar 16, 2012 | Car Audio & Video
HP Officejet 8500 Wireless All-In-One Control Panel Faceplate Err
>the error says it, what you need to do is check if the faceplate the plastic thing which covers the printer buttons is attached firmly.pry open the side of it rmove the faceplate then attched it back again.
Sep 24, 2009 | HP Officejet 4355 All-In-One InkJet...
Burnt out renaut t reg scenic
Are you sure it was your wife's car that was found burnt out at the scene? The thieves could have driven a lookalike car to the scene minus the number plates, broke into and stole yours after setting the other car alight. Check the chassis and engine numbers of the burnt out wreck and compare them with the numbers listed in your Vehicle Registration Document
Jun 11, 2009 | 2000 Renault Sportwagon
LG Refrigerator - I need to remove the ice disp.
The dispenser cover snaps off. Look at the bottom corners of the dispenser faceplate and you may see small slots to put a small flat bladed screwdriver inside to help pry the faceplate off. This faceplate snaps on very tightly so it may seem like there are screws holding it in place, but it only snaps in.
Once you have the faceplate off the rest will be easy as you can see what you are doing and what you have to remove.
Note, if you are replacing the funnel you need to know that this part has been updated as of OCT 2005 (stronger clips to hold it in place) and it will not snap into the older funnel frame (the part it attaches to).
If the serial number for your model starts with 510KR or lower, then you will also need the updated funnel frame part number 3210JA0006S.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG LRSC-26922 Side by Side Refrigerator
Kenwood KRC -X858 Faceplate/Power Problem
I have the exact same problem. I called the tech line and the tech reported that the ribbon cable is probably broke. It is the flex cable between the head unit and the rotating face plate. He said it's not an expensive fix but we would need to mail it to a service center if you're like me and not near one. I just replaced mine with a new unit. It was about time anyways.
Apr 26, 2008 | Kenwood KRC-X858 Cassette Player
No display on faceplate unless I push on it
Three possible faults. Irst choice would be connector on radio you see when faceplate is removed may have some oxidation on pins. Sometimes with a small fine point file or dental pick you can try to scrape off any visible oxidation use caution not to bend any pins and be sure radio has no power . 2nd choice could be worn flex cable that connects to main p.c.b. and Third is chassis that keyboard connects to may be slightly bent causing a bad connection. I have a PDF service manual if you need it kstahl65@att.net
Jan 13, 2008 | JVC KD-AVX2 Car DVD Player
The front panel stuck
This head unit comes with a security screw that can be installed to secure the faceplate for retail display. If it was purchased as a demo model, the screw may be in place. To check, the deck has to be dismounted from the vehicle. The screw location will be in the side of the chassis, near the faceplate on the same side as the release button. Removing the screw will allow the faceplate to come off.
Mar 06, 2007 | JVC KD-G401 CD Player
Open Questions:
See all JVC KD-LH810 CD Player Questions
JVC KD-LH810 CD Player Logo
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
