FixYa.com
Tags:
Sony SCREW +PS 2X5
ASUS Terminator C3 Issues?
By Janice - usenet poster
I am setting up an ASUS Terminator C3 as a home backup box and have had
a few problems.
My Terminator will only work with the ASUS CDrom drive that it came
installed with. I have tried installing a Compaq DVROM and a year old
Sony CD-RW drive. Changing the CS, Slave, Master jumpers does not
resolve the problem with these drives. These drive were pulled from a
working system that had bad SDRAM.
The ASUS CDROM will work with either the
I am trying to determine if the ASUS C3V motherboard will only work
with other ASUS parts or if both optical drives were somehow damaged in
the old computer?
Also, is there a source for the Firewire 1394, USB and TV out headers
for this machine?
Thanks,
Rob
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 28, 2006
FixYa! (100)
Hart
Hart - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
In article <>,
I can think of no good reason for them to key the BIOS
to one CD drive. At least try another CD known to be
in good working order. But the product is new, and
with any new product, the BIOS is seldom finished or
bug free.
Paul
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Paul,
Thanks for the suggestion. The CDRW and DVD-ROM were pulled from a 3
year old machine that had memory errors. AFAIK, both were working
before I pulled them.
On the old machine, all 3 sticks of the PC133 256mb SDRAM had memory
errors. Different errors on each stick according to MS Memory
Diagnostic. This seems an unlikely coincedence.
I am thinking now the old machine's power supply may have been bad and
fried the CD, DVD, SDRAM and ???
I'll try the known good drive and see how that runs.
Thanks,
Rob
Solution #3
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rating: 0%, 0 votes
Paul,
Thanks for the FrontX site. I had not found that before. It is price,
but it would probably still be a cheaper solution that cobbling
something together.
I haven't read anything on the C3 Terminators being picky about CD
drives. I am thinking that both of the ones I tried must be defective
in some way.
Thanks.
Rob
Solution #4
Not Rated (0)
Green1
Green1 - usenet poster
Rating: 0%, 0 votes
In article <>,
Internal port cable assemblies are available here. You can find
some Asus adapter parts on Ebay, but this solution could be
neater looking than having to hack up your own PCI bracket.
These parts fit in a drive bay housing and are modular.
CPX108-2 Dual USB - This one likely has identical pinout to a
standard Asus 2x5 header. The wires can be
moved around in the header if required.
CPX105-2 Firewire - Uses same pinout as Asus 2x5 header. It is missing
the redundant VP and GND wires, which is not a
problem according to FrontX.
The video will be loads of fun. For starters, this header does not
match the pinout of the existing Asus AV/S adapter. SVHS is
Luminance, Chrominance, and two GND. The RCA TV connector is
Composite and GND, AFAIK. That is a total of six wires, and the
Asus header has eight wires.
For components, I would use the following three items:
CPX107-2 S_video Internal - Has four wires.
CPX106-2 RCA video Internal - Has two wires
CPX075-4 2x5 plastic holder - Remove wires from above two items, and
plug them into this 2x5 plastic body.
The last item in the list can be seen on this page:
You will need to pull the four plus two wires from the first two
assemblies, and plug the wires into the correct holes on the 2x5
plastic holder. You will need to contact Asus and get the pinout,
because determining the pinout by experiment will be challenging.
The following section is how I would try to solve the problem
if Asus is clueless or unhelpful:
One way to narrow down the pinout of the Asus connector, is use
an ohmmeter, and identify all the pins that are shorted together
on the 2x5 TV header. Those will be GND pins. By shorted, I mean
they will read between 0 and 1 ohms on your meter, as in a real
good connection. The signal pins might also trigger your meter,
but should give a higher reading (no idea how high).
That will leave you with three signal pins. Using the CPX106-2
RCA TV connector, you would try the three signal pins one at
a time, to drive the center pin of the RCA connector. The outer
shield of the RCA connector goes to one of your GND signals.
One of the three signals will drive a baseband video input
properly (75 ohm baseband input, this is not an RF modulated
signal on channel 3 like your old Pong game). The signal that
makes the TV monitor input work properly is the composite signal.
With the Luminance and Chrominance, there are two possible
orientations, and I would try both until the SVHS device works
properly. (Again, you would connect the two GND wires on the SVHS
assembly to GND pins on the header.) If the first combo
doesn't work, I'd swap L and C and try again. Perhaps a SVHS
tape recorder would be a better experimental vehicle for this
than a monitor, as I don't know if monitors like to have L and
C reversed. The only issue with monitors, is causing them to
operate at scan frequencies outside of their limits.
The wires can be pulled out of the FrontX plastic bodies, by
lifting the tab next to the pin with an X-Acto (hobby) knife.
With the tab slightly ajar, the wire will pull out of the header,
allowing you to plug it back in where ever it is needed.
FrontX is a pretty expensive way to solve this problem, but you
can restrict yourself to buying only the parts you need. If you
deal with Asus directly, they might be able to arrange the sale
of the necessary adapters - the hardest part is getting their
attention, and the phone is the best way to do that. The
service level you get, varies from country to country, so
don't hold your breath. It is also possible, due to the fact
that the product is pretty new, that the TV-OUT accessory hasn't
been created yet.
HTH,
Paul
Can you Help with these PC Cases problems?
PC Cases
cobra and midland cb
i have a cobra 23 plus cb and a... Answer This...
PC Cases
installing mobo
I have an EVGA nForce 650i... Answer This...
PC Cases
case 990 three point hitch
I have a case 990 and the three... Answer This...
PC Cases
having the problem with...
iam facing the big trouble with... Answer This...
PC Cases
homesite of bestbuy.com
On bestbuy.com when i go to... Answer This...
Repair Service
Find PC Case Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
