WANT BOOTING OPTION WITH VISTA OR XP
I HAVE VISTA IN MY C DRIVE AND XP IN MY D DRIVE . MY SYSTEM STARTS WITH VISTA. HOW CAN I GET THE OPTION AT THE TIME OF BOOTING THAT FROM WHICH OS I WANT TO START MY SYSTEM.
I HAVE P4 AND 1 GB RAM, 320 GB HDD ( 250 VISTA + 80 XP).
  • ginger_boy92
    ginger_boy92 Oct 18, 2008
    I think he/she mean how to dual boot window vista and xp... Hhmm... How to that actually???
  • ginger_boy92
    ginger_boy92 Oct 22, 2008
    I don't have window vista installation disk. I only have acer(4925) recovery disk. But I have window xp pro x64 installation disk. I tried installing window xp first(in D:\) Then I used window vista recovery disk to install window vista. After booting it only boot window vista(No option menu). Tried to use easybcd to add window xp boot entry. The Option menu appeared but cannot boot because it cannot find the NTLDR file.Then i tried to install window xp first. Installing window xp first override the bootloader. Then I tried to add window vista from the boot.ini. Also fail(I think because Vista use BCD) Please help me!. Tired of reinstalling window and recovering vista(till now I've done it +-12 times) IT"S CRAZY! took hours to install once.
  • 849 Answers
You have not installed both windows correctly, you may need to install both windows again and select multiboot option.
Posted on Oct 22, 2008
Unistalling Microsoft VISTA HOME Edition
Are booting the laptop from the XP CD? If so it should just give you an option to delete partitions then format and install starts. If you try installing XP after Vista has loaded it wont let you as XP is older. Cheers from Scott
Mar 19, 2010 | Compaq Presario Notebook
Usb dvd writer can install xp?
Yes you can use a usb external cd/dvd-rom to any operating system as long as the bios allows you to, most bios's have the capability.
When the external usb drive has been connected power up the mechine, in post it should tell what to press to enter your boot menu without entering your bios and choose usb drive to boot.
Jan 22, 2010 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
Corrupted XP Professional
No it is not possible to repair xp the way you indicate.
Acers come with one or the other option of operating system and you would choose (if you were offered the downgrade option)
Once that choice is made you are locked into it unless you buy another operating system to install under a dual boot option.
Sorry it is not what you wanted to hear but that is how it is I am afraid.
Aug 21, 2009 | Microsoft Windows XP Professional SP3 Full...
How to uninstall Windows Vista
You must use a full retail or OEM version of XP (not the cd from your old computer) this makes life really easy and can usually be downloaded from the web.
You must also have a genuine XP key, which has not been used on another system.
Next you should know or find out the specifications of your system, to do this goto Manufactures website.
The most important step is to find out if your hardisk is using SATA interface (if so you will require the SATA XP drivers and a floppy disk, as this is the only way that XP can install these drivers.)
Install XP via cd rom by booting cdrom at system start (if you cannot do this then you must access your system bios at first boot by pressing F2 or Del keys(or whatever key your system uses) and change the boot option to cdrom as first drive.
If your system uses SATA press F6 when XP prompts “press F6 to install other” at very beginng of XP install and install sata drivers from floppy.
Jun 12, 2009 | Microsoft Windows Vista Home Premium SP1...
Acer m1610 with double OS (vista + XP)
You need VistaBootPro, which helps you restore the boot loader for Vista. Then you can select Vista and XP from the boot menu.
Jules
Jun 03, 2009 | Acer Computers & Internet
Two hard drives Vista and XP not booting
If you would like to start up in the xp ,At computer start up hit F1 or F2 there are so many ways some times its hold the del key ,once your into the BIOS you can change the boot order of your drives to make the drive xp is on load first .You will have to do this everytime or buy a program that will do it for you .I would just leave the power unpluged on one of the drives until you need it that way it will be safe from a virus or if you have a hard drive crash you always have one good drive .Hops this helps.
Dec 19, 2008 | Microsoft Windows Vista Home Premium with...
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I formated D: drive than also first time starting two option xp or vista than I want vista's option remove...
Boot to Vista. Then
  • right-click "my computer", then "properties".
  • click the "Advanced" section (Vista: on the left side bar).
  • In the section that says "Startup and Recovery", click "settings".
  • Under "Default operating system", choose "Windows Vista".
  • REMOVE the checks next to "Time to display list of..." and "Time to display recovery options..."
  • click ok to everything.
Now you will need to remove Windows XP.
IMPORTANT: for the next step make sure you boot to Windows Vista. Otherwise you could corrupt your computer.
  • Go to "Start", "Control Panel"
  • Open "Administrative Tools"
  • next, open "Computer Management".
  • On the left, there's a side bar. Under "Storage", click "Disk Management".
  • Now, If windows XP is on drive C:\,
    right click C:\ and select "Format"
  • Click "OK".
hope this helps.
Aug 04, 2008 | Microsoft Windows XP Professional
Dual booting in my system one window xp and another window vista C:drive in xp D: in vista than I D: is format than also first time starting two option xp or vista than I want vista's option remove please...
hi,
To remove starting option boot with XP and go to run type cmd. then go to c: prompt. type edit boot.ini and remove the line that refers the vista. and save it.
Aug 03, 2008 | Lenovo 3000 N100 0768 - Pentium Dual Core...
Hello
Accordint to your post yoursys has enabled as sata drive.xp can not indentify sata disk while installing windows. to solve this you have to change ur bois settings. to chnage press f2 while booting system and check for sata option change it to ide and save settings. now you can install xp.
Jun 23, 2008 | Computers & Internet
A135-S7406 Instruction for replacing Vista with XP
insert the windows xp cd on the system before booting ,in the bios setup choose BOOT from CD option and u can install xp onto it..
no additional drivers are required
note: try xp with service pack 3 to have vista themes..
please do vote
regards
pradhan
Mar 21, 2008 | Toshiba Satellite A135 Notebook
Computers & Internet Logo
98 people viewed this question
David Payne
David Payne
