Question about Apple iPod MA446LL/A MP3 Player
Ipod locked the ipod locked, with the red solid symbol. nothing happens when you plug it in pc.
  • frio Oct 20, 2008
    Yes! i got it by doing just that,thanks anyways.
  • frio Oct 22, 2008
    Can files on cp,from home video,dvd movies, be put in ipod.If so,can you help how to do it. THANKS!
Press the button in the center along with the menu button for 10 seconds. apple logo will appear on your screen. Thanks
Posted on Oct 20, 2008
Flashing number lock, solid cap lock, will not turn on at all
Count the number of flashes. That is the trouble code.
Jan 29, 2014 | Dell Inspiron 1526 Notebook
Unlock
Unlock an iPod Model A1199
Although the second generation iPod Nano (also known as 2G) uses a four-digit pass code that prevents unauthorized access to your iPod by locking the screen, you can also unlock the device by plugging it into your computer's USB 2.0 port.
When the 2G iPod Nano is connected to the computer it is synchronized, and automatically unlocks the screen according to the official Apple site.
In order to successfully unlock the Nano it must be plugged into the primary computer used for synchronizing content.
Click "Start," "All Programs" and "iTunes" on your PC's desktop, or click "iTunes" on the Macintosh's desktop dock.
Plug the iPod Nano's cable into the docking port on the iPod Nano.
Plug the other end into the USB port on the computer to open iTunes.
Click "Controls" at the top of the iTunes' menu, and select "Eject iPod."
The iPod Nano's screen will be unlocked once it is ejected from your computer.
Manual Guide download
http://manuals.info.apple.com/en_US/iPod_nano_2nd_Gen_Features_Guide.pdf
Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod.
In order to use the device's functions again, you need to enter the correct code.
However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Plug the iPod USB cable into the bottom of your iPod Nano.
Plug the other end of the USB cable into a free USB port on your Mac or PC computer.
Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
Select your iPod Nano from the "Devices" list in the main iTunes window.
Click on the "Sync" button to make a connection between your computer and your iPod Nano.
Click on the "Eject" symbol once the syncing process is complete.
Remove your iPod Nano from the USB cable.
The iPod's lock code will now be reset and you will be able to access all features again.
Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again.
Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
iPod Support
http://www.apple.com/support/ipod/
Jul 24, 2013 | Apple iPod nano
How to disable ipod
Your iPod touch shows a lock symbol on the top of the screen when it's in lock mode. This protects your iPod from being accidentally bumped on or off while you're focused on other things. Getting in and out of lock mode is somewhat intuitive, but can take a couple of tries the first time.
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off.
This helps save battery life if you have it locked while it's asleep.
It prevents your music from turning off if you've put your iPod in your pocket. However.
it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right.
Mar 24, 2013 | Apple iPod touch
It has a locked in the screen
What Does Lock Mode Do? Lock mode keeps you from accidentally turning your iPod on or off. This helps save battery life if you have it locked while it's asleep. It prevents your music from turning off if you've put your iPod in your pocket. However. it's not an advanced security feature -- anyone can bring your iPod out of lock mode if they know how.
Lock Symbol When you see the lock symbol on the top of your iPod touch's screen, it always means that the iPod is in lock mode. There's no other reason for that symbol to appear. If it appears and your iPod is not in lock mode, just turn your iPod touch off and then on again and it should disappear. b> Entering Lock Mode b> Press the Sleep/Wake button on the top right of the iPod touch. You may need to hold it down for a couple of seconds. Don't hold it down for too long, as ten seconds or so will force a restart and turn your iPod completely off and then on again. b> Exiting Lock Mode b> Press the Sleep/Wake button again, and wait a moment for the screen to light up. You'll see a slider bar that prompts you to slide it to wake up and unlock the iPod touch. Put a finger or thumb on the solid part of the slider, then slide your finger to the right. This gesture is simple, but might take a couple of tries. You need to tap firmly on the slider, then keep contact with the iPod as you slide to the right. Hope this helps.
b>
Jan 22, 2013 | Apple iPod Audio Players & Recorders
DESBLOQUEAR PANTALLA
How to Unlock an iPod Nano Code
With the latest iPod Nano model, you can set a four-digit code and lock all intruders from accessing your iPod. In order to use the device's functions again, you need to enter the correct code. However, if you happen to lose or forget the code, you will need to find another way to unlock your iPod Nano.
Things You'll Need:
iPod Nano Mac or PC computer iPod USB cable
1 Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
2 Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
3 Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
4 Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
Jan 05, 2012 | Apple iPod nano
Enter code i pod \
Hi
Things You'll Need
Dec 30, 2011 | Apple iPod nano
It is modle a1320 and i fogot the skrean lock pass
  • Plug the iPod USB cable into the bottom of your iPod Nano. Plug the other end of the USB cable into a free USB port on your Mac or PC computer. Open the iTunes program by using the Dock on a Mac or the Start menu on a PC.
  • Select your iPod Nano from the "Devices" list in the main iTunes window. Click on the "Sync" button to make a connection between your computer and your iPod Nano.
  • Click on the "Eject" symbol once the syncing process is complete. Remove your iPod Nano from the USB cable. The iPod's lock code will now be reset and you will be able to access all features again.
  • Navigate to the "Screen Lock" option in the iPod menu to lock your iPod's screen again. Since your iPod's lock code was just reset, you will be prompted to select a new four-digit code.
    I hope this will help you...
  • Jan 07, 2011 | Apple iPod nano
    Mmy ipod is at the music screen where it shows the
    that happened to mine once i think i just let it charge...but u have to unlock it
    Jan 11, 2010 | Apple iPod nano
    Corrupted and locked
    Press setup, go down to the lock symbol. do not enter it, just have it highlighted, then press "0" seven times. this will make it region free.
    Nov 04, 2009 | Apple iPod nano
    Itouch locked in recovery mode
    same thing happened to me the software is probably corrupted go to the nearest apple store and they will replace it or fix it
    Nov 24, 2008 | Apple iPod touch
    Apple iPod MA446LL/A MP3 Player Logo
    35 people viewed this question
    Top Apple Audio Players & Recorders Experts
    TO Lady
    Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
