Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Odor coming fromback panel
I have a kenmore side by side- during hurricane Ike mypower was off for 16 days and slowly an odor is coming from the external back panel- I have removed the veggie /meat trays and noticed gook around the two tubes leading into the back wall- and have poured bleach around it but there is still an odor. we can hardly stay in the house and my 89 y/o mom stay s with me now b/cher home was severly damaged during the the hurricane spends most of the day sitting outside. PLEASE HELP
  • bettyejo Oct 17, 2008
    remove grill. pan will not come out ( leave it in place ) took an empty liquid dish detergent botlle of bleach and water squirt into pan let it sit - scape if needed . then take a wet/dry vac - repeat)
    I will let you now if the odor is completely gone
  • 120 Answers
You can also use bleach let it sit there for a couple of days so it will kill bacteria and odor the smell is all the meat and blood that drain down to the pan
Posted on Oct 17, 2008
Low water pressure on cold water cycle only. Need to know how to take out filter screen to clean. Lost water pressure during Hurricane Ike and have had this problem for a year. Haven't been able to find...
take off the cold water line from the valve on the wall. be sure and turn off the water first. the screen on the hose end may be plugged with rust or some debris.
Jun 28, 2009 | Kenmore 24032\24036 Top Load Washer
Moldy taste from Whirlpool side by side
The problem can still be in your lines, or in the dispenser itself. If you run hot water with a little bit of vinegar in the lines and let it sit for about 30 minutes and then flush the whole system this should take care of your problem
Apr 29, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ODOR COMING FROM OUTSIDE REFRIGERATOR
Most refrigerators have a catch basin under the cabinet that is accessible after removal of the trim at the bottom.  This trim grill can have a half-dozen different fasteners on it although most have plastic extensions that are inserted into matching holes in the sheet metal that forms the base of the unit.
Try (gently) lifting the bottom lip of the grill while pulling it outward; if this frees the bottom edge, then angle the grill outward at the bottom and pulling it downward to free the upper edge. On some units there may also be a knob-like section that when turned releases the grill.
You didn't mention brand and model but with these, you should be able to find a downloadable manual on line that would detail how to remove the grill.
Once the grill is out of the way, most catch basins simply are lifted up and pulled out for cleaning and emptying.
To fully rid the fridge of odors, it may be necessary to pour hot (not boiling) water down any drains you see in each compartment several times to flush them.  Obviously, the catch basin should be in place when doing this and they can be quite shallow.
Good luck-
Dec 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Fridge has an odor recently
It is likely that you have a problem with the capacitor.  Look for it on top of the compressor.  If it is discolored or smells...you'll know!...replace it.  While you're there, clean out the condenser fins.
Nov 14, 2008 | Kenmore 50522 / 50524 Side by Side...
Freezer section not cold enough/fridge ok
sounds as if you might have a compressor related sealed system problem, youll have 5 year war on such an issue from the manufacture
Oct 29, 2008 | Maytag MSD2758GEW
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
JCD 2389 GES Not cooling
Yes. I would suggest the control board is possibly damaged.
Model jcd2389ges JENN AIR SIDE BY SIDE REFRIGERATOR Parts
This is not the only place to look, but it is where I would start.
Dec 19, 2017 | Jenn-Air JCD2290HES Side by Side...
Refrigerator odor
hi there,
the bad odour could be from the compressor, evaporator or heat exchanger. can you supply the complete model # please?
thanks.
Sep 25, 2008 | Whirlpool Refrigerators
Ice maker trobleshooting
We lost power due to hurricane Ike and now that the power is back on the ice maker is not working. Is there a reset button or what needs to be done to get it working again?
Aug 10, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
118 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
