Question about Pioneer TS-A6980R Coaxial Car Speaker
Voice coil tweters sound ok,,,,,,,,,but voice coil mid-range burned out,,,smoked, how i can replace it?
  • Anonymous Nov 26, 2008
    burned out
    Problem Solver:
  • 13 Answers
I'm sorry to tell you but it sounds like you may have put to much bass at a decent power rating through them and there not designed to be replaced. The whole speaker needs to be replaced. Do not use it as you are running a risk of shorting the circuitry in your radio or amp if the impedence is off from the blown speakers and can burn it up also.
Posted on Oct 17, 2008
Smoke, burning smell coming from my machine. Door wont open and clothes and water inside is black
the bad smell you refer to is a smell of the electric motor burned out have the motor replaced the machine should be ok
Nov 23, 2017 | Whirlpool Washing Machines
One of my Bose 601 speakers has developed a mid freq buzzing at volume. Ant ideas?
Yep, if it is a scratchy sort of sound, the units coil has overheated, the voice coils insulation has bubbled and expanded, and is now rubbing against the magnet as it moves. Only fix is to replace the driver. U can confirm by moving the inner circle of the cone in and out of the magnet. Should not rub and be perfectly centered around the magnet.
A vibration sort of sound can be caused by loose screws holding down the driver. But that is usually the case on your large heavy drivers with large excursions, not a mid range speaker.
Mar 15, 2014 | Bose 601 Main / Stereo Speaker
I got a 15" TS-VR15
Honestly man it sounds like you have burned up the voice coils inside the only way to fix it is to take it to a place where they specialize in fixing car subs.. And to be honest 80% of the time its just cheaper to go buy a new Sub. Sorry to hear that i know they arent cheap i burned up the voice coils in my 2 15" Kicker Comp CVR's and they wanted over 140$ to fix each one. And well to be honest after they tear off the factory glue whos to tell how long thiers will last. Hope this helps Dont forget to give me a good vote even though im sure you didnt want to hear that...
Jun 29, 2011 | Audiopipe Car Audio & Video
Only bass driver working on the pair. tweeter and mid range cones not working.
hi,
check the tweeter and mid range. its coil may become faulty.
for checking the speakers carefully remove the speakers one by one, remove its connections.
and check the speakers with a AAA cell. is it producing cracking sound. if not the speakers coils are burned.
ok
Feb 01, 2011 | Mission 782 Main / Stereo Speaker
Right speaker perfect. Left speaker sounds like someone is talking through a kazoo.
Hello
Just check the left side speaker for its voice coil trouble. If voice coil has got damaged, this kind of fault will occure. If so replace the speaker with an identical one, both in size and impedence [ie resistsnce in Oms]. Connect an other good speaker of any type to the left speaker wire, and check whether the sound though it is perfect or not. If it is perfect, there is no doubt that the speaker inside the TV is damged. If the connected outside speaker also gives disorted sound, the Audio Output IC inside the Tv is faulty. Have to replace it with same type and number.
Before doing all these, go to the sound control section through your TVs menu options, and be sure that the balance control is set to mid position.
Ok.
Jan 19, 2011 | Samsung LN32A330 32 in. LCD TV
Need to know how to wire a dual voice coil subwoofer
All a Dual Core Speaker is, is Two speakers, sort of, in one. It has Connections for the Mid-range and Woofer, so The Inner speaker, is the Mid Range and the Outer, is the Woofer. Wire + to + (Red to Red), & - to - (Black to Black)
Jan 22, 2010 | Soundstream PCS-12 Car Subwoofer
Smoke was coming out of my subs and it was alot.
Open the sub box and see what it looks like before you go purchasing stuff with no problem for certain. You may have had wires touch and they will smoke. Also try connecting a different speaker to the amp and see if it works. this lets you know if the amp/speaker is working or not
Sep 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Speaker aint hitting like it should and i smell something burning from the speaker what could this be and how can i fix it
sounds like you are frying the voice coil! Push the centre of the cone in and if you hear a crackle then time to buy new speakers.. sounds like they are on way out if you can smell burning!
Apr 19, 2009 | Volfenhag ZX-4715 Car Mid-Range
Bi-amp
After examining a picture of a 5802 ( I have been servicing adcom for over 20 years ), these are not bi amp posts, but bi wire posts.
Bi-amp means that 2 amps are being used, one for highs, one for lows. This means that you have no crossovers in the speakers, instead, you have an electronic crossover between the amps and the pre-amp. The highs and lows are separated in the electronic crossover. One amp handles the lows, one handles the highs.
Bi-wire means that you have the crossovers still inside the speakers. The amp handles the full range of music ( highs-mids-lows ). Different kinds of speaker wire produce different results. If you have bi-Wire terminals on your speaker, they come with shorting wires, that tie the tweeter + to the woofer + on the back of the speaker, and the tweeter - to the woofer - . When the shorting wires are removed completely, you have now electrically separated the tweeter and woofer from each other, while maintinaing the crossovers ( inside the speaker ) for each.When this is done, you can now bi-wire the speakers and amp, and use different kinds of wire for the lower frequencies and the upper frequencies, depending on your ears ( everyone hears a little differently, thats why there are so may makers of components, and wire ).
Why do we have crossovers?.....the tweeter voice coils ( the things that make the sound ) are made of hair thin wire. This wire cannot handle much power and if you were to put bass in to a tweeter, you would burn the tweeter out almost instantly. A tweeter is a very light, fast moving device which can react very quickly to high frequency sounds ( symbols, triangles, guitar strings....). Woofers are more rugged. They have voice coils made of heavier wire and are designed for larger movements that Bass demands. Subsequently, woofers aren't very good for high frequencies because they are slower devices.
So what do we do ?.....Keep the lows away from the tweter and the highs away from the woofer.....thats the job of the crossover.
In the event that your speaker has the crossover OUTSIDE the speaker box, you should check ( as always ) with the manufacturer of the speaker to see how it can be changed to suit your needs. Remember to always read and follow your owners manual. Good luck....Rob
Feb 22, 2008 | Audio Players & Recorders
Speaker act more like tweeter only, not mid range + tweeter
They are mid Hi speakers.1st Open them and check if the mid speakers are ok maybe they are defected or the protection is open. Good Luck Toufic Malek
Sep 22, 2007 | Yamaha NS-A327 Speaker
Pioneer TS-A6980R Coaxial Car Speaker Logo
43 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
