Laptop will be pull up internet wireless. Just purchased a Linksys, installed, but laptop says< The specified remote computer would not be found. Name or IP address, and then try connecting again. Help, I do not know what this means.
  • 128 Answers
Make sure your wireless lan in your laptop is enabled
Posted on Oct 17, 2008
Risricky@ai cannot install my linksys router onto my laptop
I presume you mean that you cannot connect to your linksys router from your laptop and have not used it before.
You should make the initial connection using a network cable rather than wireless. Once you have done this you will be able to connect to the linksys router administration webpage by opening internet explorer (other web browsers are available) and typing in http://ipaddress where ip address is the default ip address as specified in the router getting started or installation guide. The default for Linksys routers is http://192.168.1.1 Once you can access the Administration page you should be able to configure the wireless settings using the inbuilt wizards.
Hope you get sorted
Caltor
Sep 07, 2011 | Computers & Internet
How to connect my Linksys router with my wi tribe modem?? my laptop pick up the wireless signal and can connect,,it says "connected" but when you open a page it says either "invalid server...
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Jul 04, 2011 | Linksys WRH54G Wireless Router
Can't connect acer aspire on to linksys wireless.
Is the acer wired to the router? call linksys technical support, if they cannot help try this http://technicalsupport.blog.friendster.com
Feb 19, 2009 | Linksys Wireless-G WRT54G Router
2wire capacity for wireless connection
yes you can return the linksys.
the following link should help you setup the 2 wire for wireless conneciton.
Dec 03, 2008 | 2wire (1000-000057-000) Modem
No Installation CD for Wireless-G Notebook Adapter
Hello! It is possible to install it without the CD< but not easily >You will need to, On a separate computer, Go to Linksys.com and download the drivers, then just burn them to a CD< or Put them on a flash drive, and install it on the laptop. Unless the laptop has a Ethernet port, then just connected the computer to the linksys router VIA Ethernet to download the drivers.
Nov 24, 2008 | Linksys Wireless-G WRT54G Router
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Wireless router
hi frank its a new thing to have to go out and decide what router to purchase and install i use a linksys and have had good luck with the wireless connection quality . does his laptop have a wireless lan card installed most new laptops do have one but its worth a look to make shure it does. depending on how much you want to spend how far away does his laptop sit from location of router ? if not more than 10 ft go ahead and purchase a cheaper one 60.00 now if you want a better quality one go with the twin antenna linksys for about 130,00 and please make shure that he installs the security software that comes with the router and make a password and secure it for shure .i hope ive helped you decide on what router to purchase they all work fairley good .
as far as how they work they are all plug and play install the cd software first then follow instructions carefully and set up is 10 minutes away good luck by for now
Jul 03, 2008 | Linksys Wireless-G WRT54G Router
Helo top experts
i assume that your computer can access the internet while hardwired to the wireless-g router. if so, you just need to connect your wireless computer to the wireless signal of the wireless-g router. you just need to scan or view the available networks detected by your wireless computer and select the wireless name (ssid) of your wireless-g router. make sure to enter the correct wireless security (network key) if it's enabled on your router. i hope this'll help you but if you can't still access the internet wirelessly, provide the specific model number of your wireless-g router, specify if you're using a laptop or a wireless desktop, and the brand and model of your wireless card/adapter
May 14, 2008 | Linksys (WRT54GC) Router
Wireless Network for my laptop
You must purchase a wireless router. I recommend Linksys. If your laptop has ethernet capabilities this will work just fine. (ethernet ports look like oversized phone cord ports) they are very simple to use and install in minutes. just be sure to make sure your network is password locked!
If this helps, I would really appreciate a FixYa! rating. If not, do not hesitate to contact me. I own a linksys wireless router, and can help you install it, if need be. Have a good day!
Apr 30, 2008 | Dell Inspiron 8200 Latitude C840 Laptop...
No internet connection
You didn't specify if you're using DSL or Cable internet.
With DSL, keep in mind the software1.gif on the PC is what "dials out" to the ISP with your name / password, and you MUST set the name and password in the router. Otherwise, ONLY the computer that has the software installed (verizon, etc) will be able to connect.
If you're using a cable connection, you don't have to do this, however, most newer Linksys routers come with a 'setup' disk, which MUST be used regardless of connection type.
Dec 31, 2007 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
