Question about Motorola Mobility MOTORIZR Z3 Cellular Phone
Home screen shows but keyboard and all buttons on the side of the phone do not respond
  • 3 Answers
I had the same problem and if you hold the command button on the top right side of the phone it unlocks the phone
Posted on Dec 13, 2008
I pad fully charged cant slide to unlock?
Hi Lynn, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
How To fix any Android Phone Tablet that won turn on
Apr 30, 2016 | Tablets & eReaders
Where is the reset button on a zeki windows tablet located at
Hi Brenda, The link below is a youtube video showing you how to fix your tablet, Also there's video's down the right side you can check out as well....CHEERS..
Apr 24, 2016 | Tablets & eReaders
My iphone screen wont work but the buttons will
Try restarting your device by holding down the Power button. If your screen still fails to respond, back up your data to iTunes on a computer. While still connected to the computer, turn off your device by holding the Power button, and the Home button. Don't release either button yet. When the Apple logo appears, let go of the Power button, but not the Home button. Then your iPhone should show a picture of connecting to iTunes. Then you can set up your device through your computer on iTunes, and your phone should work fine.
Dec 22, 2013 | Apple iPhone Smartphone
Htc prophet touch screen issue
for window phones
1. Press the "Home" key and press "Start." Use the directional pad to highlight "Settings," then press the center or "Enter" button.
2. Use the directional pad to select the System tab. Select "Screen," then press the center or "Enter" button. Select "Align Screen."
3. Using your smartphone's stylus, tap the crosshairs as they appear on your screen. Do this for as many as appear, until the calibration tool finishes. Your screen is now properly calibrated.
for Android phone
4. Press the "Home" button or capacitive area, then press "Menu." Tap "Settings."
5. Tap "Language and keyboard." Tap "Keyboard settings." Tap "Tutorial" and go through the steps that appear on your screen.
6. Once this is finished, turn your phone off and on again. Your keyboard has been adjusted, which activates a re-calibration of the capacitive touchscreen. (Capacitive screens are technically far more accurate that resistive, and so a full calibration tool is not included with Android phones.)
Aug 20, 2012 | imate JAMin Smartphone
Home button no longer works
did i fall down or got hit by you. there are some other reasons but mainly it can be the above mentioned.
Tell me in this regard then i can suggest the better solution.
good luck!
Feb 19, 2012 | HTC G2 Cell Phone
Does the verizon motorola bt51 need a sim card? and where does it go in?
No Verizon has internal SIM cards that you can not remove. Only GSM phones have removable SIM cards.
Jun 02, 2010 | Motorola Cell Phones
My phone pad doesn't respond??? The only button
Your motorola RAZR V3 cellular phones has a solution,Most V3 versions of phones have one specific problem.which is flex problem.when ever your using your phone and your keypads does not respond,No that is the flex cause the flex is connected from the screen to the you can change the flex of your phone.
Jan 11, 2010 | Motorola Mobility RAZR V3
Voice mail does not respond to commands from auto dialer screen
i found this on another forum... hopefully it's the answer we are looking for.
Re: Bug with Phone virtual number pad
I've found the answer to this problem!
Part of the problem is that the screen blacks out shortly after a call is connected.
When that happened I pressed the green phone button to get the keyboard back.
This keyboard image is a dummy. It visually responds to your touch but does not send the signal.
After you dial and your call is connected look at the bottom of the screen and you'll see that the normal menu tab changes and appears with the number 5 and letters jkl on it.
Pull it up with your finger. THIS is the keypad you must use when within a call to send number signals. I tested it and confirmed that it works.
If you have pulled up the dummy keyboard by pressing the green call button from within a call then simply hit the BACK button to see the real keypad tab.
If the screen has gone black and you need to light it up again then you can press BACK, HOME, or MENU to see the real keypad tab -- press anything BUT the green call button (which will give you the dummy keypad).
This dummy keypad is a true design flaw but knowing how to get to the functional one makes it an annoyance not a hindrance to using the phone.
Dec 10, 2008 | HTC G1
Touch screen suddenly stopped responding!
Make sure your device is not locked. Lock button is the "Slide Switch" lower left side of device. If locked, will show a lock in upper right part of screen. Will unlock when you pull down the keyboard. This is also a very good feature to prevent accidentally dialing when getting in/out of your car etc...To unlock, slide switch to middle position.
Sep 04, 2007 | Samsung SCH-i730 Pocket PC
Buttons not responding.
you need a new keyboard assembly
Aug 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility MOTORIZR Z3 Cellular Phone Logo
67 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
