Question about Siemens WXLP1460 Front Load
"Old" Siemens WM 2010 Front Load
One of the pump hoses was blocked and prevented it from getting the water out. We had it running for a few days with the pump security valve open so that the water was draining directly to the floor.
After that there was some sort of short circuit, we are guessing produced by the water underneath the washer. Now the machine lights up but won´t start running any program; is there any fuse which might have been damaged and where is it located?
Many thanx, demian
4 Suggested Answers
  • 154 Answers
SOURCE: my siemens frontload washer is not draining -
You need to remove the filter and clean it, also make sure that you clean the filter receptacle on the machine and check the waste hose that leads out of the machine and check it for kinks that might be restriting flow, refer tothe image below for further assistance:
Posted on Jun 22, 2010
  • 154 Answers
SOURCE: My Siemens WM14S791ME Frontloading washing machine
F:23 means that there is a leak into the basepan of the machine and it should be checked by a competent repair person as sson as possible, the boby pin may have jabbed a hole in somthing or more likly there is a bad seal some were on the drum.
rickead1
  • 1998 Answers
SOURCE: Siemens wfxd8400uc/01 front load washer give a
oh your gonna have so much fun with this sorry i had this model before and its one of those omg type of units. have you opened the pump door and checked inside the pump most of the times this is the problem first off another thing that these lovely little devils do is they have these small screens inside the rear water valve really small as in inside the tube that goes into the machine remove each of these and wash them thoroughly the smallest speck of debris on these small screens causes these not to run hope this helps write back if this doesnt fix your situation well go more in depth at removing alot of things in order to track down your problem youll find another thing funny also that if you were to remove the cover the entire technical sheet is in german
Posted on Jul 24, 2010
We just got a new lg tromm digital front load,washer the light after my first load is blinking OE, what does this mean and clothes are still wet
That's actually DE (Drain Error) and I would never expect that on a first load unless use washed a rubber backed rug, pillow, or other item which might have given off a lot of stuff that could block up the filter, preventing pump out. (washer will not spin if water is not pumped out) Check the filter, located behind the access door on the front left bottom corner of the washer after using the small hose there to drain the remaining water out of the machine. If there was no obstruction in the filter, check for electrical problem,.... wire not connected to pump, etc. Wm2077 is an older model already. If it is new, call for warranty service and give servicer provider a copy of your sales slip to file with warranty claim.
Mar 18, 2011 | LG WM-2077C Front Load Washer
Dishwasher siemens is not draining water.
Hello & Welcome to FixYa
Dishwasher not draining completely problem usually occurs due to clogged/blocked drain hose or the drain pump not working. First try to clean the drain hose and drain pump filter for any clogs, then check drain pump operation. If the problem returns after cleaning then it is the drain pump that needs replacement. Please get back to me if you have any other questions.
Kevin
Jan 09, 2011 | Siemens WFXD8400UC Front Load Washer
My Siemens WFXD8400UC won't drain; I have checked the hose and nothing is blocked as far as I can tell. Any suggestions?
Hello, welcome to FixYa.
You mentioned you checked the hose, yet based on your description it sounds like a pump isse.
I would start by checking the pump for lint or other debris which may prevent it from draining properly.
**Unplug the washer from the wall or turn off the breaker at your service panel...safety first**
Here`s how...Start by removing the bottom front panel which provides access to the drain pump and manual door lock release.
1) Carefully lift and block (up with a 2x4 or egual block of some type) front of washer to provide access to screws along the bottom which are angled slightly.
2) Remove three (3) screws, then carefully slide panel down and away from washer.
3) You should now see the pump access filter to your right, as such...
4) The pump has a small tub connected to it which will allow you to try and drain the water from it before removing the filter.
5) The filter will unscrew counter clockwise...careful it likely has water in it. This is where a wet-dry shop-vac comes in handy....or a nearby floor drain.
6) Now pull out the trap and visually inspect the inside of the pump as well as the filter/trap. Hopefully you'll find the item/debris that initiated the error code.
7) After removing any debris or obstruction`s re-install the button trap/lint filter and plug the washer in to power or reset the breaker and give it a test.
8) Run a load and watch for leaks. Leave the pump access panel off until you are sure you screwed the cap in tight and there are no leaks.
Ultimately you may have a faulty drain pump, but I would certainly start by performing the things I listed first.
Let me know if you require further assistance and if not and this solves your problem, please rate the solution I provided accordingly.
Thank you for coming to "fixya" and good luck.
macmarkus :)
Aug 17, 2010 | Siemens WFXD8400UC Front Load Washer
Lg wm-2277hw front load washer getting a OE error code after cleaning drain hose and filter
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 22, 2010 | LG WM-2277HW Front Load Washer
I have a lg front load there is still water in the washer and it is flashing OE
this is a drain pump fault code.the firstthing to do is use a wet dry shop vac and attach it to the end of the drain hose and remove all the water.
once the water has been removed you need to check the hose that are attched to the drain pump and look for anything that will dtop or block the pump.if you do not find anything inthe pum[ make sure you check the hose that runs from the bottom of the tub to the drsin pump its selft
Feb 03, 2010 | LG WM-2277HW Front Load Washer
Leaking under Washing machine LG serie WM 2277H.What causes and how to fix it? Thanks!
First check all hoses. The hoses inside the unit, sometimes leak and looks like a water pump problem. Does it leak all the time or only when running. If only running , most likely it's the pump. If you and a friend can lift up the front of the unit "tilt" and block it. Use a flash light and look for water around the pump. The pump will be white plastic with 2 hoses running to it. It has to be a hose or pump (90%). I hope this is a start.
Nov 03, 2009 | LG WM-2277HW Front Load Washer
Machine will not discharge water
Any error codes? Pumps out OK?
Sounds to me as if the cold water inlet screen is plugged up, preventing rinse water from entering machine. Turn off the cold water to the machine and remove the cold water supply hose. Check the screen inside where the hose came off the machine. Run some water out the hose into the drain or a bucket before reconnecting to machine. Let me know if you still have problems.
Apr 19, 2009 | LG WM-1832C Front Load Washer
Washing machine trouble
Very important that the thin tube is clog free, disconnect from top to blow into it, clear if any block, refit. This is connected to the pressure switch, controls water level.
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Important: height of drain hose is abt 3 feet from ground level.
Rate me pl.....if helped.
Jan 03, 2008 | LG WM-2277HW Front Load Washer
Siemens WXLP1460 Front Load Logo
56 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
