Question about Sharp 25R-S100 25" TV
Hyundai 14" colored tv no power
I repaired a hyundai 14" color TV. only the standby power will lights up. i check the 5volts supply in the system IC. no problem. i check the 110volts supply at the flyback transformer. still no problem. but theres no deflection in the horizontal output. is the flyback transformer is busted?
  • 40 Answers
If the final flyback is ok ,then check the driver transistor and the voltage in his collector .Probably the flyback transformer is ok.please reply.
Posted on Nov 13, 2008
Tv is stuck on standby. The standby light (red) is steady and when I press the STANDBY button, nothing happens. no response or flashing light.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 11, 2015 | Televison & Video
Tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light position...
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light
Aug 30, 2011 | Sharp 21" Multi System Stereo TV
Power supply is good but indicator lit just blink ones and then off, at first i fixed the power supply, i changed the 5mo380r and power supply board has 5volts standby now but when i turn on the main...
i had a similar problem and I thought I had fixed the power supply but still didnt work. long story short I ended up replacing the power supply and finally worked.
good luck
Jun 17, 2011 | Samsung Televison & Video
Two lines appearing and moving up and down on my Pana 14"color tv
Hello, This is called 60cycle hum and it is caused by the 60Hz signal of the power supply "leaking" into the video circuitry. It is caused by a faulty filter capacitor. and can be seen by using an oscilloscope. I would suggest that you take the TV to a qualified TV technician for servicing, because this type of repair is not for the do it yourself person. I hope this helps, Thank you, Shuttle83 http://www.electron-age-technologies-llc.com
Jun 10, 2009 | Panasonic TC-14KM30R 14" TV
My Dell w4200hd will not turn on. The color on the little light by the power on/off switch will change from what I think is standby color to a different color when I try and turn it on, and I hear...
i do have the power supply at my shop. but i don't think the power supply is the problem. i already replaced the power supply on this set with this symtom and no help. you can find parts at discountmerchants.com J.D.W.
Mar 08, 2009 | Dell W4200 42 in. HD-Ready Plasma...
Tv keep going on standby when you turn it on
tv goes into standby all the time if a power supply is not fine, what happens is that a power supply produces two voltages, one small one powers a standby components and bigger voltage powers a line transformer which later produces more small voltages,
then later cancels the first small voltage.
chec your power supply semi conductors like, transistors, diodes and small value resistors, on your power supply. some power supply uses a IC to oscillate a ht. so check a supply at a w/shop.
Feb 07, 2009 | Goodmans 257NS 20" TV
Sharp colored tv
check the b+ supply of your flyback if they have check the horisontal transistor. check also if they have 5v supply in the system and 9v in the chroma ic or replace the memory ic.please reply.
Aug 08, 2008 | Sharp 25R-S100 25" TV
Wont power on
thers an open resistor near power supply secondary section,supply voltage to 5v and 12v to system control ic, or check the vertical ic for malfunction
Sep 14, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
TV turn off and problem with red colour
the problem is in your color circuit and power supply make checks in those areas check the power supply regulator, diodes, cap ,and resistors.in the color circuit replace your color ic.then you can do resoldering of the components in the those same circuit,this will contain your problem good luck.
Jul 26, 2007 | Toshiba TP50F60/61 TV
TV in standby mode
Hi iducher the tv power supply is faulty have a tech repair your tv.good luck
Apr 26, 2007 | Supersonic SC-999TDVD 13 in. TV/DVD Combo
Sharp 25R-S100 25" TV Logo
203 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
