Question about Lands Phones
I have bought eight Panasonic KX-TS3282B phones to replace my old Panasonic KX-T22150 Ease-a-Phones. Both models have intercoms. The intercoms on the old phones work perfectly in all of my jacks, but the intercoms on the new phones work on only three of my eight jacks. Panasonic Tech Support tells me that the old phones are hybrid ones which work on either parallel or series circuits, whereas the new phones are regular business system phones which work only on parallel circuits. My phone man checked all of my jacks and determined that they're all wired in parallel, and all are wired identically. I tried disconnecting all my old phones while using my new ones, in case they were interfering, but this did not correct the problem; still, only three of my eight jacks worked with the new phones. I also tried disconnecting my DirecTV receivers and my answering machine from their phone jacks, but this did not help, either. Although I have DSL on my line, which runs on a frequency similar to the new phones, it is connected to only one specific jack, and is filtered before it reaches any other jacks, so that doesn't seem to be the problem, especially because three of my jacks do work with the new phones. Does anyone have any suggestions as to how I can get my new phones to work on all eight jacks, instead of only on three?
  • 84 Answers
SOURCE: telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
Posted on Feb 13, 2008
  • 59 Answers
SOURCE: I have a phone jack with a dsl filter on it.
do u have two phone lines or one?
Posted on Nov 15, 2008
  • 2559 Answers
SOURCE: How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Posted on Feb 12, 2009
    • 95 Answers
    SOURCE: need to connect phone and fax machine to one phone jack
    You have the wrong adapter probably. Most common types are single line splitters and will not work like you want. They only split line one and 2 gets blocked out as they only have 2 copper connector on the plug centered to get line 1 only. If you want to use an adapter you will need a 2 line splitter like this one:
    A simpler solution is to plug your fax into your phone. On top of your phone are multiple jacks labeled L1/L2, L2 only or L2/data. Plug your phone into the wall using the L1/L2 jack then plug your fax into the L2 jack and this will work fine and still allow you use of line 2 on your phone. If you don't want to hear the ring then set your fax machine to auto answer. Hope this helps you.
    Posted on Mar 29, 2009
    • 3085 Answers
    SOURCE: I have an HP 6210.
    ALL fax machines need an ANALOG phone line to work reliably. DSL is DIGITAL.
    Posted on Jul 04, 2009
    How do I use the intercom function on a KX-T7731 phone??
    Panasonic analog phones plug into analog KSU's and have extension numbers beginning with 101. In additon, you can dial 0 to reach the phone programmed as Operator, and it's usually extension 101.
    With the intercom dial tone (press INTERCOM or pick up the handset or press SP PHONE) you can start dialing codes defined in your number plan. You can also program left side buttons to monitor are directly select other extensions or dial codes to page all idle speakers in a 77xx phone.
    Note this is specific to TA series systems, but the operation is similar in all Panasonic models.
    Apr 19, 2011 | Panasonic KX-T7731 Corded Phone
    Display screen shows "Will return soon" Would like
    You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
    KX-TA624 Phone System
    Press intercom button, dial 750#, lift handset then return handset to cradle to end.
    KX-TA1232 Phone System
    Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
    KX-TDA100 or KX-TDA200 Phone Systems
    Press intercom button, dial *7500, lift handset then return handset to cradle to end.
    Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
    Panasonic telephone model no KX-TGA 131 EX user manual please
    please send the panasonic phone model no kx tga 131 ex operating manual book
    Nov 20, 2010 | Panasonic Cell Phones
    Panasonic kx-t7633
    On the intercom dial *71x1 where x is 0 for all calls, 1 for outside calls and 2 for intercom calls. *71x0 cancels, or you can just press the FWD/DND button until it goes out.
    May 07, 2009 | Panasonic KX-T7633 Corded Phone
    Panasonic kx-t7330 suddenly cannot use intercom and phone calls
    I'm guessing the phone is 8 years old and you spilled something into the keystrip.
    Start by unplugging it to see if it resets. Then, look for a mechanical failure (sticky buttons, broken buttons, etc.). Some alcohol and a Q-Tip will clean the buttons, or carefully take the phone apart and wash out the housing.
    Last, but not least, any of the new 7730/31/35/36 phones will replace that set.
    Feb 24, 2009 | Panasonic KX-T7731 Corded Phone
    Panasonic kx tg7200fx and kx tg 1100 compatible for use in intercom
    A few days ago I bought Panasonic KX TG1100 - but the base unit does not ring - only the handset!
    Can I do anything about it?
    Nov 08, 2008 | Panasonic KX-TG2357 Cordless Phone
    Panasonic kx-t7630
    i notice my Intercom Button flashes every 10 can i turn it off? Seems like My Intercom is calling my Co-Worker's Extension. Please advice. Thanks
    Jul 06, 2008 | Panasonic KX-T7630 Corded Phone
    Lands Phones Logo
    Top Lands Phones Experts
    Are you a Lands Phone Expert? Answer questions, earn points and help others
