Hello my problem is with an rca tv model t20008bk serial 522320268. What channel is input? Is there input? It has a yellow and white connector for input( I think it's input, Otherwis it's output) So ya what channel is input?
  • killer1390 Oct 17, 2008
    Yes! What I need is the channel for video input for my TV, Or if there even is a video input channel!
    Sergeant:
    Champion:
  • 227 Answers
I can help you but i do not understand your question.can you be more specific of what is it that you want
audio/video input or tuner
Posted on Oct 17, 2008
How do i hook up mono tv with eterxnal speakers with a dvr box
If the DVR has RCA-type connectors, yellow to yellow for picture, and white to white for sound. Tune tv to line input.
If the DVR supports outputting everything on coax, use a piece of coax cable, and tune tv to channel 3.
Your coax cable from wall has to go into DVR first, then out to tv.
Aug 26, 2014 | RCA F32650 32" TV
VCR only shows black and white
how do you have the vcr connected to the tv, through the antenna input on the tv or a video input on the tv with yellow white and red connectors? If connected with antenna input you may have tv on the wrong channel, like 3 instead of 4.
Mar 16, 2014 | RCA Televison & Video
My dynex tv only shows channel not available message?
Okay- the three cables (red, white, and yellow) are called RCA plug connectors. They are commonly used to carry audio and video signals.
Plug them into your Xbox according to the color codes- red cable connector to the red socket (jacks); then white to white, and yellow to yellow.
Now connect these leads to the RCA input jacks in the back of your t.v. - maintaining the same color code connections (red to red; white to white, and yellow to yellow)
The RCA input jacks on your t.v. should be labeled with an input number, to distinguish itself from the other inputs, like HDMI, S-Video, and such.
After plugging in your Xbox to the wall outlet or surge strip, turn it on.
Turn your t.v. set on.
With the remote control that came with your t.v. set, open the menu bar, scroll to... and open the "External Output" menu.
You should see a list of [however many] inputs your particular t.v has. Scroll to the input number that the 3 RCA cables are attached to, and press that number as the default video screen.
Exit the prompts and your Xbox video screen should be displayed.
Nov 27, 2013 | Dynex DX-LCD32-09 LCD TV
How to get dvd on tv
There are generally 2 ways to connect a dvd player to a tv.1 If you have 3 rca connectors on the back of your tv (they are color coded yellow for video and white and red for audio left and right channels respectively) and the same connectors on the back or side of the dvd player.Use rca cables to connect the dvd player to the tv,connecting yellow to yellow white to white and red to red.Using the remote put your tv on video.Put the channel selector on the dvd/vcr player on video or L1 or E1 (depending on what brand dvd/vcr you have).2 connect a rf (coaxial cable from the rf output of the dvd/vcr and connect this directly to the rf (antenna) input to your tv.Put the tv on channel 3.Play the dvd/vcr to see if you have the video.If not put the tv on channel 4.Some dvd/vcr's put their signals out on channel 3 and others on channel 4.Good luck.
Sep 15, 2013 | Disney 13" TV
HOW DO YOU CONNECT TO THE TV
You look for the video and audio outputs available from your camera, the standard analog type are video composite (yellow RCA connector) and audio L channel (white RCA connector), R channel (red RCA connector), if the audio output is mono, you should have a black RCA connector, the you should look the corresponding inputs at your TV set and select them. If you have a digital output, usually a firewire connection, you should look for the cable and corresponding input at your TV set.
Feb 08, 2011 | Mitsuba HDC-505 Camcorder
Coaxial hookup broke off. Can i use an s cable through vcr? need instructions.
If your Sharp television has RCA jacks, you may use them through your VCR. Your VCR would have to have a tuner and then you may use this as a means for getting a signal. Newer VCRs and DVD players generally do not have a tuner. Thanks for asking!
Jul 22, 2010 | Sharp 27N-S300 TV
How do you connect to a direct tv box
1st, what kind of Tv Box ? with SCART Connector? or RCA Connector?
2nd, the recoder has a Scart connector or Females Rca connectors.
check for Video IN and L/R input Rca Connector
then use a Scart/RCA cable to connect DVD to TV Box.
Nov 07, 2009 | Philips Magnavox MWR10D6 DVD Recorder
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
Broken cable hook up
sometimes if the tuner is not damaged then a technician can put it back on... the other option is to tune the channel through a vcr.. essentally bypassing the tv tuner and useing vcr tuner. hook the cable to vcr then using rca jacks yellow red and white connect it to you tv(if it has rca jacks ...most have them these days.. sometimes on front and sometime on back or even on the side.. tune your tv to that input(video 1 or something like that.. then using your vcr remote change channel...its not a perfect solution but it will save you the 130 buck most charge to repair that connector
May 01, 2008 | RCA HD61LPW175 61" Rear Projection HDTV
Am not able to identify the TV's video input channel for my AKAI CFT 2791
yellow input for video
red and white correspond to audio
Dec 06, 2007 | Akai CF2791 27" TV
Open Questions:
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
