Question about Maytag Dryers
My maytag mdg6700aww will not heat up. How do I fix the problem?
    Novelist:
    Champion:
  • 261 Answers
Ok when you open the dryer door there is four screws two on the door hinge and two across the other side in the same manner. When these are removed you will want to lift slightly on the door to disengage the hinges from the case to remove. Now this front piece will unclip and come off. You will see the lint trap duct in white in front of you. Now look to the left and around the duct to see where the sensors are at the elbow. Check the continuity of these after you unplug the power and after removing the wires from the terminals. If no continuity than this maybe the whole of the problem.If these are ok than you need to finish removing the front and tilting top back to pull drum to check ignitor and flame sensor as well ohms of the gas coils.
Posted on Oct 17, 2008
How to remove front of mdg6700aww
Remove the top then you can get to the screws on the console it has screws on top and tabs on the bottom then you will see the screws along the top of the front panel it is slotted at the bottom always unplug before working on electrical appliances
May 22, 2014 | Maytag Neptune MDG6700A Gas Dryer
How do I remove the front panel etc. from a Maytag MDG6700AWW dryer. But not standard Maytag assembly.
This appears to be the Samsung made dryer built for Maytag. Remove the screws for the main top located in the rear left and right, the rest should be down hill from there. This model may have screws one left and one right under the bottom of the front panel too. Pleazer Appliance...
May 19, 2014 | Maytag Dryers
Maytag mdg6700aww dryer clicks to start the igniter. Sometimes the burner ignites, other it doesn't and I can smell raw natural gas from the vent. Not drying. Help
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 14, 2011 | Maytag Neptune MDG6700A Gas Dryer
I have a MAYTAG MDE6000AYW Series Dryer. It does not heat up, it makes no noise, tumbles, and the lights work, what can I do to solve the no heating problem with the dryer?
the heating coil needs fixing you can fix it yourself but try a repair man first allot of them come too your home and fix them so choose your repair guy wisely...
Apr 12, 2011 | Maytag MDE6000 Dryer
MAYTAG DRYER NEPTUNE MODEL MDG6700AWW SHOWING ERROR CODE ON PANEL E5
this is a way to diagnose your dryer, as the only codes I have ever saw E 1,2 and 3:
http://media.fotki.com/1_p,srtrqwwdrrfrtkrxgtqsskgwtqkq,vi/bqdgktddqxbwtrqsbqdxbwsqrwrtq/1/1303472/5961857/image7954013674829342211img-or.jpg
Mar 04, 2011 | Maytag Dryers
Problem with the Maytag Neptune MDG6700A Gas Dryer WHEN STARTED HEATS UP THEN NO HEAT AT ALL. MAYTAG MDG6700AWW
Hello & Welcome to FixYa
When the dryer heats for few minutes and then it won't work it means that the thermostat is bad and needs replacement. This part is located on the blower wheel housing inside the duct, you can also check this part for continuity before replacing. Please get back to me if you have any other questions.
Kevin
Dec 02, 2010 | Maytag Neptune MDG6700A Gas Dryer
Maytag mdg6700aww gas dryer runs but heat kicks out after 5 min
You have bad coils on your main gas valve . They tend to short (open) after getting warm which cuts off the gas to the burner . After cooling , they will work again for another 5 min until shorting again . Replace the coils (2 in a kit ).
Jul 12, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryers Logo
316 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
