Question about Goodman Heating & Cooling
I have a goodman gups100-4 furnace.The basement flooded and got the control board wet. I replaced the control board and blew out the furnace making sure it was dry. Now the blower will not stop running and it was not submerged. What can i do to fix this
solveditnow
  • 39 Answers
SOURCE: (HVAC) Furnace Not Igniting Quickly
Make sure a back draft in the flue is not happening. Wind can blow it out until the flue heats up. The flame sensor may not be close enough to the burner flame. It may be weak and need to be replaced or if its an optical one it may be dirty and not see the flame very well. Its not wasting much gas but it puts extra wear and tear on the gas controls, is noisy, and, as you said, blows cold drafty air. A gas control system that has issues of any kind is not real safe. It needs to get fixed.
Posted on Jan 08, 2009
  • 189 Answers
SOURCE: blinking constantly troubleshooting ligt I revesed 115 v.pol.
This one is difficult to solve on line. I wish I could see the unit. First, check the diagnostic code chart on the inside of the blower compartment door. Constant blinking is the code for "normal no call for heat" or " normal call for heat". The diagnostic code chart will explain the difference according to the flashing speed. So this part may be ok. Second, disconnect your thermostat wires fron the furnace. If this turns off your blower you have either a bad or miswired thermostat, or a bad thermostat wire. If this doesn't narrow it down... then locate all of the wires coming from the blower motor.
If it is a "variable" speed motor the wires will be connected to the board by a module. Make sure the connector is plugged in properly. Check the dip switch settings to make sure you are not set for continuous fan.
If it has a "multiple" speed blower. Locate all of the wires coming from the motor. The two brown wires should be connected to the capacitor. The white wire should go to the neutral post on the board. The black wire will connect to the post marked "cool". Of the remaining wires... determine the speed by color according to the schematic. Place the desired heating speed wire on the post marked heat. The remaining wires MUST be connected to the posts labeled "park" or "spare". I believe that you may have mistakingly placed one of these remaining wires in the wrong location.
If none of this helps keep in mind..... just because the parts you changed are new, does NOT mean that they are good.
I hope this info helps you...
Good luck....
Posted on May 03, 2009
sawdust46694
  • 398 Answers
SOURCE: goodman furnace app 6 yrs old blower only runs app
You need to remove the blower ,blow it out with a good air compressor. oil if if there is a place. be sure to blow it out once a year. its thermo protected. To stop from burning up the motor.
Posted on Aug 17, 2009
  • 588 Answers
SOURCE: furnace blower won't stop running
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Posted on Jan 05, 2010
SOURCE: Carrier weathermaker sx 58 furnace
I have serviced these furnaces for 20 years and I can tell you most of these models did not have diagnostic lite on them. (although some did, especially if the control board has been replaced) The problem is most likely a bad 3 wire pilot. This will cause exactly what you describe. 2 things to consider though. 1, If you were to replace the pilot don't get a cheaper knockoff. In my experience these do not last long at all. Get the right one from a carrier dealer. It will cost more but be much more reliable. 2 What is the condition of the secondary heat exchanger? Most if not all of the sx series had issues with the secondary heat exchangers rotting out and leaking. If the furnace is out of warranty you would be much better replacing the furnace as the cost of replacing the secondary heat exchanger will probably be almost the same as a new furnace. ( those babies are EXPENSIVE!)
Posted on May 01, 2010
My goodman GMVC95 furnace circuit board is flashing On 6 I replaced the flame sensor but it's still flashing. Does it have to be manually reset?
Alright, have you checked the low voltage fuse on the circuit board in the blower compartment? Make sure you check the roll out switches as well. If all of these issue appear to be fine then you may have a bad circuit board. There has been a bad batch of circuit boards going around many of the popular furnace brands this winter. Trane Gas Furnaces and Goodman Gas Furnaces have been effected. We sell both brands and have had to replace many circuit boards on new furnaces. Trane Gas Furnaces Installed Goodman Gas Furnace Installation Gaithersburg
Feb 03, 2018 | Goodman Heating & Cooling
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Goodman furnace GMT115-5B Turn fan to on on
Bypass the tstat first but that's where I'd be leaning.
Aug 14, 2017 | Goodman GMS90703BXA Heater
Problem with Goodman furnace electric ignition
Power is there, or no lights would blink. Steady blinking or flashing three times, stop, three times Etc
Nov 23, 2011 | Goodman Heating & Cooling
I have a Goodman GMS9 Furnace that ignites and runs perfect for about 5minutes and then I will here a woosh of air and the flame goes out and inducer motor stops for about 3 seconds, then it re-lites and...
This is a common problem with this brand and can even often fool HVAC contractors! There is a control module/circuit board inside the furnace that needs to be replaced for proper operation. The circuit board controls multiple functions and switches and relays inside the equipment and it begins developing a mind of it's own and starts turning certain things on and off at improper sequences. Most of Goodmans furnaces come with a 10 year parts warranty, so try exhausting that resource first before buying one.
Hope this helps James
Apr 06, 2011 | Goodman GMS90703BXA Heater
Furnace wont run ...thermostat battery went dead i replaced the batteries and still furnace wont run...We recently had a power outage for approximately 12 hours. This furnace is in our garage. we had...
Hello, The first thing you need to check with a multimeter is if you are getting 24 volts between the R AND C terminal on the intergrated control board. If not than the transformer is blown and needs to replaced or the fuse on the control board has blown and will need to be replaced. When check for 24 volts at the R and C terminal make sure the door switch is pushed in, u can just use electrical tape to temporaily hold the switch in. If you are getting 24 volts at R and C and notthing continues to run than the intergrated control board is most likely the cause and must be replaced.
Feb 04, 2011 | Goodman GMS90703BXA Heater
Goodman gmp075-3 gas furnace and the flame cycles
you need the same board. the one you have is not compatible with your unit
Greg
Dec 11, 2009 | Goodman GDS80904BNA Open Flame Heater
Goodman gmp075-3 gas furnace and the flame cycles for 4 sec
JUST SAND THE FLAME SENSOR LOCATED IN FRONT OF THE LAST GAS PORT.
Dec 02, 2009 | Goodman GMS90703BXA Heater
Goodman furnace
double check your wiring. R terminal on the furnace will provide 24 volts to the t-stat. W terminal in the t-stat will send 24 volts back to the furnace W terminal to turn on the heat. G terminal in the t-stat will send power to the G terminal in the furnace when the t-stat is switched to fan on. Y terminal in the t-stat will send power to the Y terminal in the furnace which in turn will send 24 volts to the A/C outside. The C terminal in the furnace should be connected to the c terminal in the A/C outside as well as to the T-stat. Check the fuse again
Jun 02, 2009 | Goodman GMS90703BXA Heater
RCA 56 inch projection TV
six inches will just reach the bottom of the main cuircit board. Does the units green light flash? there is no reset hutton there is a fuse. but i would suspect if it got wet then something blew
Feb 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Heating & Cooling Logo
75 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
