Question about Bose Lifestyle 30 System
Bose Lifestyle 30 series II - 6 cd changer troubleshooting error display EO1
I wonder if anyone can assist me in troubleshooting my Bose LS30 series II 6 cd changer error display. Basically, once my magazine inserted a continuous humm sounded from my music center as if the eject mechanism was continuously working. An error display EO1 appeared and I was able to release the mag from the music center. Bose customer service explained that is was a mechanical problem associated to a gear which might either be misaligned or worn out. Honestly, I hardly use the cd changer and doubt that it is associated to wear. If I could only figure out a way to open up the music center in order to investigate further. Any sound advice would be welcomed for this troubleshooting issue?
  • jessicat77 Dec 08, 2008
    System won't power on. When plugged in, making a running noise. Eject button for magazine appears to be stuck in down position. Tried everything.. Help!
3 Suggested Answers
SOURCE: Bose Lifestyle 30 6-cd changer magazine manual release?
hi, you can release the magazine by inserting a small flat head screwdriver in the slot and pushing the lever towards the back of the unit, this will release the cd but only if ther is not one stuck in the player as it will remain halfway between the mag and the cdplayer. don't force it to comae out. remember to obviously have the dorr to the player open before you try this.
Posted on Aug 12, 2007
SOURCE: I have a loud humm in my bose lifestyle 28 system
Turn on your bose so you can hear it hum. Go to the back of your cable box and remove the co ax cable connected to "cable in". If the humming stops, the sheilding on your cable is no longer grounded. Purchase MPAV800 or similar surge protector to run cable line through it and get it grounded.
Posted on Apr 17, 2009
I lost my Bose remote for the sound system, how do I turn on the system?
PDF]TV SOUND SYSTEM - Bose
worldwide.bose.com/axa/assets/.../owg_en_solo.pdf
Bose CorporationTo reduce the risk of fire or electrical shock, do not expose the product to rain or ... be determined by turning the equipment off and on, you are encouraged to try.
Nov 28, 2015 | Bose Lifestyle 25 Series Ii 6 Cd 5.1...
Bose lifestyle plays for 5min shuts down
Do the easy troubleshooting first! Get a source of clean, dry compressed air and blow out the inside works. Next, get some contact spray and spray into the volume control potentiometer and work it down and up.
Jan 13, 2013 | Bose Lifestyle 8 series II System
I have a Bose Lifestyle 35 Series II and want to know whether it's compatible with a DVD+RW. I'll burn it in a Toshiba recorder, finalize it and then play it on the Bose. Will it play?
Hi This what Bose say about formats
"The Lifestyle® 35 system plays DVD-video in interlaced format, as well as music on CD, CD-R (recordable) and CD-RW (re-writable). The system also plays MP3 files on CD and AM/FM radio. "
So by the sound of this i suspec that you may struggle with DVD/RW. but my best advice is try it.
Nov 10, 2009 | Bose Lifestyle 35 Series II System
Error code 10 during sound calibration
Please ensure that you have turned on the Accoustimass module, this can cause communication errors when calibrating. Also check that all connections are correctly plugged in as if one is not quite sat right this may give the error, just try unplugging them and plug them back in.
May 31, 2009 | Bose Lifestyle 35 Series II System
Display not working
I think there are some solutions available from www.AnyoneCanFixIt.com for the Bose Lifestyle 20 series with the display issue.
May 26, 2009 | Bose LifeStyle 5 Series-III CD Shelf...
Cannot find a device code for ATT Uverse DVR cable box
SOrry for your plight, the Bose staff are correct, they do release occassional firmware updates via a DVD or a CD throught their costumers mailer. If you are not part of this mailer, you may go to any Bose service center and request the latest update disc for your Lifestyle 18-II system. Udpates should be able to help you sort out your problem.
Glad to be of service...
Jan 21, 2009 | Bose Lifestyle 18 System
Bose surround sound system cuts off
Hi when you turn on check all your speakers work check connections make sure the wire has no stray strands touching the fault could be in the sub unit this is possible / or your speakers one or more could have gone short circuit due to exessive volume thats if you play loud. Had a party lately .Just joking .Regards kirk
Dec 10, 2008 | Bose (321GS) System
Can't eject cd from cd changer
hi check and see if there is 12 volt to the cd changer or blown fuse.
Oct 26, 2008 | Bose Lifestyle 20 System
Bose 6 disc cd changer
Some bose cd changers have a gear the get cracked and must be replaced. You did not specify which bose you have, so I have told you of the most common problem with the bose 6 cd changers.
If this is in one of the silver slimline type of units, it is very difficult to get them apart if you have not dome it before. The gear is also very hard to get to in the changer. it would be a good idea to let a professional service technician look at it. You will need to take it to an authorized bose service center because bose does not sell parts to any service centers unless they are bose authorized. They just started that about 2 years ago.
I hope this was helpful to you, let me know if I can assist you further.
Dave
Jun 30, 2008 | Audio Players & Recorders
Jul 29, 2007 | Bose Lifestyle 30 System
Bose Lifestyle 30 System Logo
760 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
