Question about Samsung ML 1610 Laser Printer
Samsung ML-1610 Does not print after a paper jam
After a paper jam when too many sheets of paper started into the system extracted sheets by brute force. After restarting the printer, all doors closed, lights normal, on print command paper feeds normally. In Open Office Prints a page in tiny font, the whole page is about two inches.
In Evolution the printer works normally but nothing prints .
Ideas??
  • Anonymous Mar 20, 2014
    Samsung ml 3051nd printer showing "paper jam 0 open/close cover" but no jam in that printer
    Samsung ml 3051nd printer showing paper jam 0 open/close cover,but no jam in printer
After checking no paper left on rollers etc, turn printer of for a while and then turn back on and press the paper release button
Posted on Oct 27, 2008
Have a samsung ML-1610 and used to work fine. Now every time I print something the paper keeps getting jammed.
Get a package of roller cleaner papers at an office supply store or online. Run it thru the printer as directed to remove the fine paper dust that has accumulated on the rollers and the paper path.
Jan 03, 2015 | Samsung ML 1610 Laser Printer
My samsung ml-1610 printer always getting paper jam on print job. Is this problem related to fuser or something else? please help me...
There are a series of rollers which are made of rubber in the unit. When these rollers become dry or covered with dust (usually from cheap paper) they arent able to pick up paper correctly any longer.
Think of it as though you are trying to turn a page, and you have to lick your finger to do so.
Its the same concept. When your printer grabs the paper, it cannot hold it while it is rolling it through the printer.
There are kits available through your manufacturer or a local print shop which can clean your printer and help to restore it to its working order.
Hope this helps!
Feb 23, 2011 | Samsung ML 1610 Laser Printer
The online error light is red on my ML-1610 Mono Laser Printer any ideas how to fix this?
It probably has a jam somewhere. Open each flap, remove the toner cartridge and check the paper path is clear.
Jul 16, 2010 | Samsung ML 1610 Laser Printer
HP PSC 1610 All-In-One paper jam 1/2 sheet
Throw this thing out as it is clearly rubbish. HP inkjet printers will **** the life and money out of you. Get a Brother HL-2170W and you will have care free printing for cheap.
Cheers old chap.
Mar 19, 2010 | HP PSC 1610 All-In-One InkJet Printer
I can only print one sheet, then the paper stucks. What do I have to do? I have to open the front door, get rid of the paper and start over. So one more sheet is printed and the paper stucks again. This...
Samsung is a reliable brand, but they have had problems with the vendor for the exit sensor. When it goes bad the paper comes part way out of the exit and jams. The part is less than a dollar, and you might find it at www.precisionroller.com
Jan 22, 2010 | Samsung ML 2010 Laser Printer
Samsung ml-1610
There's probably a small bit of paper jammed in the paper-out sensor (hopefully. Otherwise the sensor may have been snapped off).
Extract the paper tray and look inside with a strong light. The paper out sensor should be a dark gray or black piece of plastic dangling from the upper left side. Remove any paper bits you find with a pair of tweezers, then blow on the mechanisms with a compressed air canister for good measure.
Oct 27, 2009 | Samsung ML 1610 Laser Printer
The paper has jammed in my ML-1610 printer.
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Mar 09, 2009 | Samsung ML 1610 Laser Printer
Samsung ML2010 paper feed
clean the rubber pickup with water or alcohol by cotton cloth and try again
Feb 26, 2009 | Samsung ML 2010 Laser Printer
Printer indicates paper jam. Cannot find any evidence of papejam.
if you as service man you can unerstand my solution
follow up
1.your printer lamp thermostate or thermostater is cuttoff or printer cartridge is not properly instald. it is a technical problem
Feb 05, 2009 | Samsung ML 1610 Laser Printer
Fake paper jam
the roler, which picks the paper need to clean, try it
Oct 28, 2008 | Samsung ML 1610 Laser Printer
Samsung ML 1610 Laser Printer Logo
463 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
