Question about Nikon Cameras
Help! My Nikon lens (18-55mm on a D60) has stopped autofocusing even though it was previously problem-free! The lens is set to autofocus but it is still not working.
  • Anonymous Dec 20, 2008
    My D60 was working fine, suddenly the autofocus will not work and most of the time I cannot get the shutter release to take a picture. I have a 55-120 and a 18-55 and neither lens will work. It must be a problem with the body.
The first thing to do in this situation is to check that the auto focus assist light is coming on and that both the lens and body are set to auto focus mode.
Assuming the above check out, then check the electrical contacts on the camera. In a dust-free environment, remove the lens and look into the camera body towards the top of the camera. You will see several metal "fingers" which make contact with the lens. Be sure these are clean, free of grime, and not bent. A cotton swab with a small amount of alcohol will do the trick, though a foam swab with lens fluid is probably a bit better.
Posted on Mar 12, 2009
I have a nikon d60... is the tamron 70-300 zoom lens compatible ?
Tamron makes their lenses with a variety of mounts. A lens with a Canon mount, for example, will not fit a Nikon. Assuming the lens has a Nikon mount then yes, it is compatible with the D60. However, the D60 lacks an autofocus motor, relying on the lens to have one. Some Tamron lenses have such a motor, some do not. Such lenses will not autofocus with the D60, but everything else still works, including manual focus.
Sep 18, 2011 | Cameras
Sigma AF Zoom 70-210mm F4-5.6 Nikon Mount Camera Lens. is compatible with the nikon d60?? this is the Serial #1172609
Yes, the lens is compatible with the D60, with one proviso. The D60 lacks an autofocus motor, relying on the lens to have one. This lens does not, so the autofocus feature will not work. Other than that, everything else will work.
Aug 27, 2011 | Cameras
Will a Nikon Sigma 70-210 work on my nikon D60??
Assuming the lens has a Nikon mount, then it will fit and work on the D60. Sigma makes lenses for a variety of cameras; a lens with a Canon mount, for example, will not fit onto a Nikon camera. However, the 70-210 is a rather old lens. Unless it specifies "HSM" it will not autofocus on the D60. The D60 does not have an autofocus motor, relying on the lens to have one. Nikon calls such lenses "AF-S" while Sigma designates theirs "HSM".
Feb 03, 2011 | Nikon Sigma 70-210 F4-5.6 55MM AutoFocus...
Autofocus stops after heavy usage
Maybe cleaning the gold coloured contacts on the back of the lens and the ones in the camera may help. Worth a try!
May 12, 2010 | Tamron 18-200mm f/3.5-6.3 for Nikon
I have a Nikon D60 and my autofocus has stopped working. It is not because of the lense because i have tried other lenses and the auto focus won't work with them either so it must be an issue with the...
You should check custom menu setting 2, and make sure it's set to one of the auto modes. Make sure the lenses you are using are AF-S and not regular AF lenses. The D60 has no autofocus motor, so autofocus only works with AF-S lenses.
I always suggest folks take a look at Ken Rockwell's website also, here's a link to a specific page on autofocus on the D60.
Post a comment here if none of this works and I'll see what else we can do.
Jan 08, 2010 | Nikon D60 Digital Camera
My autofocus has stopped working even though it was set to AF mode
Try cleaning the contacts on the camera body and the lens where they meet with a cotton swab lightly dampened with rubbing alcohol.
Nov 25, 2009 | Nikon D60 Digital Camera with 18-55mm lens
My Nikon D60 wont auto focus on any of my lenses. Could it be a problem with the body?
The d60 needs Auto focus lenses(Ones with motors inside the lense) it doesn`t autofocus on other lenses. this was done to reduce the price of the camera body
Hope this helps
Aug 04, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Can't autofocus Nikon 50mm f1.8 lens
The lens has an autofocus motor, but because it is an older model, it will not autofocus for the D40(x), D60, or D5000, which have more stripped down components. I advise you exchange the lens for the newer model, or return the D5000 and get the D90 for just a bit more.
Jun 11, 2009 | Nikon Normal AF Nikkor 50mm f/1.8D...
Can I use a Kenko Lens with a Nikon D60?
If it's an AF teleconverter you will be able to use it and get proper exposure from the camera, but it will not autofocus with the D60. The D60 requires AF-S lenses and teleconverters for autofocus.
Mar 01, 2009 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Auto focus on 55mm lens not working on d 60 nikon
Since Nikon doesn't have a 55mm lens in its current lineup, I'm going to assume it's a rather old lens (though probably newer than my 55mm). As such, it won't have an internal focusing motor, and thus will not autofocus on the D60. The D60 requires lenses designated AF-S in order to autofocus.
Aug 29, 2008 | Nikon Cameras
Cameras Logo
202 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
