Question about Speed Queen ATS90AWN Front Load Washer
ESP error code
Working on a Speed Queen front loader. Hit start, and the door locks, but the machine will click 3 times, and then go into an ESP error. I've changed every part on the machine, pressure switch, door lock, entire front panel (splash), transformer, motor, motor control, water valves etc. Still the same problem. Any suggestions?
5 Suggested Answers
  • 12 Answers
SOURCE: At start of spin cycle water splashes over top and runs down.
Hi, just fixed the daughters speed queen, same problem. The three brake shoes were worn allowing the tub to spin with the agitator.
replaced the shoes, washer fine. At first I thought it was the top ring. spent 30 dollars for nothing.
good luck
Posted on Apr 09, 2009
  • 142 Answers
check hoses and pump area.
Posted on Sep 14, 2009
  • 84 Answers
SOURCE: My speed queen top loader is leaking water during
It is probably the pump. Run the washer with the front off of it. The pump is on the bottom of the motor.
Easy repair.
Posted on Jan 12, 2010
  • 254 Answers
SOURCE: Speed Queen top loader leaks from top of tub at large load spin c
make sure unit is level possibly lower front legs down so front sits higher,,, and also when u put or load in push the tub back so when the water enters it all enters into the tub sometimes the water will splash on the tube and cause a problem u are discribing hope this help
Posted on Feb 03, 2010
Speed Queen top loader, have had to replace the inlet valve 3 times and only owned the machine for 6 months!
Check your water pressure. If it's too high, that's exactly what will happen... Inlet valves will wear out.
Nov 16, 2015 | Speed Queen Washing Machines
I got an error code e5e from frigidaire front loader
Hello barnessursula - Typically error code E5E indicates that there is a communication problem. Base on the intensity of the issue, I suggest contacting a professional technician to accurately repair the unit. Technician will need to check the wiring between the main control board and the speed control board. Depending on the diagnoses and if the wiring is bad, it has to be corrected. However, if the wiring is good the main control board will need to be replace or if the problem is not corrected, the speed control board will need replacing.
Dec 15, 2012 | Frigidaire ATF6000ES Front Load Washer
Hi, I have a Speed Queen LTSA7AWN washer/dryer combo. It will not start hte cycle. After closing the door, the door light flashes.
This is a door lock error. The control is not seeing that the door was locked.
Try pushing the door closed where the door strike is. If this does not work you may nee to adjust the door strike.
Dec 28, 2010 | Speed Queen CTS99AWN Front Load Washer /...
Did you replace the striker on the door, or the door lock mechanism?
Try adjusting the striker on door.
Dec 28, 2009 | Speed Queen ATS90AWN Front Load Washer
DOOr error on speed queen front load commercial washer
I had this problem. What I did is replace the door latch. Then disconnected the machine over night, then everything was fine. I waited over night because i couldn't get rid of the door error every time I reconnected the washer. I think i read that you have to have the machine disconnected at least a minute. Another thing you may want to look at is the locking mechanism and switch. I recommend starting with the latch and switch. they're the cheapest parts to replace.
Oct 30, 2009 | Washing Machines
Washer is overfilling & leaking
Are you using front loader only detergent?(oversudsing) Overfilling is either a pressure switch, or pressure chamber is blocked(located toward underside of outer bowl approx 6 inches long) this is only in older machines with extensive cold washes.
May 23, 2009 | Speed Queen ATS90AWN Front Load Washer
I have a maytag top load wash machine that has broke on me for the last time!!!! i want to get a speed queen to replace it. how do i go about getting a manual on a speed queen washer so i can see how they...
Click on Speed Queen above in blue...............front loaders would be nice. But ask the dealer where the filter is, what the codes mean, etc. These are all supposed to be secret - so their techs can come around to make more money..... No jokes its real.
Feb 26, 2009 | Speed Queen AWS52NW Top Load Washer
Speed Queen ATS90AWN Front Load Washer Logo
462 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
