let me guess, you using a windows vista right? when the operating systems blocks a certain type of installation when using windows vista, you need to click the allow button right there on the block screen.
The print server is Vista compatible. However, the Deskjet F4180 is not listed as a supported printer.Look at this list: http://iogear.com/files/pdf/GPSU21_Printer_Compatiblity_List_4-20-09.pdf . This print server is not the right one for your printer. You can either try a different print server, a supported printer or directly connect the printer to a computer and make that computer a print server for the rest of your network. The last option will take a bit more work. In Windows, the directly connected computer will need to allow sharing for the printer and the firewall software will need to trust the other machines in the network connect to it. The other computers will only be able to print and not use the other multi-function features. You may need to get additional software drivers to make this work (particularly if one computer uses a 64-bit OS and another has a 32-bit OS).
Please go to control panel> printers and faxes, and choose your printer and make sure it is set as default printer. If it is set so already, please try to print from Word and note the exact error message you are getting and report back. Include your operating system info.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
i have a hp deskjet f4185 all in one printer but i lost the cd. i need the sofware or it will not connect to print or scan please help me where can i get the sofware?
sounds like U have a printer driver error and need to go to hp.com and get a updated driver for windows vista and if you have vista with 64 bit processing there is a different driver for that. Give it a try with hp.com, good luck
