Question about Kenmore Kitchen Ranges
Kenmore drop in range code F7
Timer buzzer keep going off with the code F 7 beside the time. What does this mean?
Stove is Kenmore drop in range approximatley 15 years old , number on the door 3263B1016P001
Pls advise.
many thanks,
Pam
  • 750 Answers
Oven control beeps and Electronic control as detected fault condition.
Press CLEAR to clear the display and stop displaysF1,F3, F7 ,or F9 beeping.
Program oven again.If fault recurs,record fault number.
Press CLEAR and contact your Sears authorized qualified service agency.
Posted on Oct 17, 2008
What does the flashing f 7 mean on a Kenmore stove
F7 code usually means a power failure. It means that at one point, the stove wasn't getting any power to it. This could be from a short blackout or just bumping the plug. If it continues to come up, you may have a short in your outlet. You just need to reset the front to get it to stop flashing.
Elisa Jed ' http://www.jmappliance.com/Appliance-Repairs-Refrigerator-Repairs-Redlands-CA.html
Jul 18, 2014 | Kenmore Kitchen Ranges
F7 keeps beeping on my electric slide in range model #911.4658813- stove top works but oven will not operate as everytime I turn off electricity and on again the F7 comes back on
Hi
Error code F7 means that an error with the keypad has occurred. Usually it happens due to loose ribbon cable on the keypad or the electronic control assembly itself going bad. To resolve this issue first, disconnect the power to unit and then gain access to the back of the clock assembly (Electronic Range Control/ERC). Now unplug the touch pad ribbon connector from the ERC, it would be a flat wire approx. 1 1/2" to 2" wide and make sure that the cable is not broken and nothing is shorted on the keypad. After this is done insert the cable back and then plug the unit back to check. If the error is still there then the electronic control board should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 29, 2011 | Kenmore Kitchen Ranges
I have an older stove and the kitchen timer buzzer keeps going off...at random times...i have never actually used the timer
un plug stove, pull cover off . if you dont use it unplug the timer wire put wire nut on it. and call it a day.
Apr 11, 2010 | Kitchen Ranges
Error Code F7
F7 Function key shorted Replace touch padThis is what the code means. The key could just be stuck. Try pushing it several times to see if it will unstick. before you replace the touchpad.
Mar 11, 2010 | Kitchen Ranges
Beeping won't stop and the F7 error code appears on the monitor
You may have got water into the control panel or cooktop causing an electrical short. Hopefully if you give a few days to dry out and plug it back in the code will be gone.
Sep 10, 2009 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F7 Code on the Stove Top Burner
Hi hyaeron and picksi66
Happy to help you!!
This means,
I would advise you on this occasion to call service.
These guys are good!
A&E factory service does most brands warranty services.
They are open 7days/24hours nation wide.
call tonight! 1-800-905-9505
I am happy to assist you!
Neil
PS. Before you leave this site please leave a "Problem Solved" rating for me on fixya.com
Jul 07, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore double oven
This is what f 7 means:
F7 A = Function pad button stuck or
B = Bad clock Unstick button or
Will need to replace the oven control. Part # is WB36T10486 for black and WB36T10488 for white. Cost is $314.75 for black and $417.99 for white. You can get it at http://www3.sears.com/.
Nov 16, 2007 | Kenmore 47772/47774/47779 Electric Double...
F7 alarm
I believe "F7" is a function key error with the Electronic Range Control (ERC). The ERC is not serviceable, so it will have to be replaced. If you can provide me with the model number off the range (usually located on a label inside the lower drawer), I can provide you with a part number. I hope this helps.
Aug 07, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kitchen Ranges Logo
378 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
