Question about Sony Cyber-Shot DSC-S90 Digital Camera
Will not power on properly
When I turn on the power button the screen says "Access", then "Turn the power off and on again". I have full battery power. I can review previously taken pictures but can't take any new pics. I also can not get the zoom lens to retract completely.
  • 1 more comment
  • soccerchica Dec 29, 2008
    help??
  • Anonymous Jan 09, 2009
    i have the same exact problem....
  • Kimberly Cook Jan 23, 2009
    Ditto! Exactly!!
    Problem Solver:
  • 6 Answers
For what its worth I had this same problem with both rechargeables and alkcalines. Fresh batteries were rejected after just a few shots and were clearly NOT dead. Solution seems to be either use Sony's NP-NH25 cybershot battery which is made of two AA batteries jointed at the hip or use generic rechargeable NiMh batteries with a capacity superior to Sony's battery (>2500mAh).
Dan
Posted on Jan 10, 2009
My Kindle Fire HD is frozen. It says that there is 96% battery. I don't know if I'm supposed to disconnect the battery (which I cannot access) or what. Help!
You can try holding down the power button to see if it gives a menu to turn off the device. If not, you can also try plugging in the power to see if that unfreezes the screen. If neither of those work, you can let the device run out of battery and then charge it again, as it will restart the system after losing the battery and gaining a charge again. After it runs out of battery and you have it charged again, you will need to hold the power button to turn it back on
Apr 13, 2017 | Amazon Kindle Fire HD
System is frozen. Wont shut down or go to start screen.
Here are two things to try:
I- Using the Power button:
1 Press and hold the Power button for at least 4 seconds.
2 Swipe-down the shutdown confirmation screen to the bottom
edge of the display to turn off the tablet.
Using Charms:
1 Swipe-in from the right edge of the display to access Charms.
2 Touch Settings
Turning Off the Screen
Press the Power button to turn off the screen.
Using Charms:
2 Touch Settings
NOTE: If your tablet is in a standby state (tablet is on, but screen is off), press the Power button or Windows button once to turn on the screen.
12
Setting Up Your Tablet
? Power
? Shut down to turn off the tablet.
II- Unplug the battery, wait 30 seconds, then install the battery again.
Sep 04, 2015 | Dell Venue 8 Pro Tablet Computer
I,ve not been able to see anything on "DCR-HC32 -HC-42" LCD screen, but its working properly if we press it blindly, otherwise its viewfinder is o.k
If the touch screen of the Camcorder is not working, please follow the troubleshooting steps.
Please make sure that you're using fully charged batteries.
Turn off the Camcorder and turn ON again and check the operation.
Try resetting the Camcorder by pressing the reset button above the hand strap.
Note: In the above picture, 10 represent the reset button.
If the issue persists again, please perform LCD screen Calibration and check if that helps.
Please follow the steps below to perform the LCD Calibration
Perform a power resetting of the Camcorder. To perform power resetting, please remove the battery pack, turn the Power switch to ON for more than 15 seconds, turn the Power switch to OFF position and then reinsert the battery pack.
If the issue persists even after performing all the above-mentioned steps, service is required.
I hope this information will help you to resolve the touch screen issue of the Camcorder.
Feb 08, 2011 | Sony Handycam DCR-HC42 Mini DV Digital...
The button is on and the lock 9 is on and flashing and the screen is black. It was working fine. I opened the laptop and my screen is black. The A in the lock is blue and the icon next to it. The power...
Hold the power button for 5 seconds or more - does it turn off properly? If so, can you turn it back on afterwards?
Take out the battery and unplug the power adaptor. Let it sit for a few minutes. Now try the power adaptor alone. If this works, try shutting down and running on battery again.
Apr 18, 2010 | Dell Vostro 1510 Laptop
Turn the power off and on again message
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settigs 1 Menu of the Camera to OK.This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks for contacting FixYa
Feb 15, 2010 | Sony Cyber-shot DSC-W170 Digital Camera
Sony Cyber Shots camera, turn the power off and on again problem
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
Thanks,
KenSolutions
FixYa
Sep 13, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Sony DSC-W30 ACCESS problem
try hitting it against something harder (like a table). I just did and it worked for me.
Jan 28, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
Access and turn on again the camera
I called Sony at 800-222-7669 and was told to turn camera off, remove battery, turn camera on holding the power button for one full minute, put battery back in and power up as usual. Probably the one minute drains the residual energy in a capacitor.
I passed the info to my wife but she had solved the problem by tapping on the front to release a bind on the lens coming out. Probably caused by handling during her trip to California. So I don't know if the one-minute thing works but it is certainly worth a try.
Hope this helps you!
Dec 29, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
DSC-W50 sony cybershot
I had the same problem with my DSC-W55. I actually just called the customer service number on the sony website and they told me how to solve the problem.
- Take your battery out
- Press and hold the power button for 60 seconds
- Re enter your battery
- Voila.. it should work when you turn it on. Mine did.
Nov 19, 2007 | Sony Cybershot S650 Digital Camera
Sony Cyber-Shot DSC-S90 Digital Camera Logo
90 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
