Home | Hitachi | 61SWX10B 61 in. Rear Projection Television | Tv won't come on
Hitachi 61SWX10B 61 in. Rear Projection Television
Problem for Hitachi 61SWX10B 61 in. Rear Projection Television
Tv won't come on
By blackhercule on Oct 17, 2008
I have a Hatachi 53" ultra vision digital and i was watching it one day and it went out.I tried to turn it back on and the red light was flashing in the front.I took the back cover off the bottom and tried to turn the tv back on and there are 2 green light and one was flashing as the light on the front of the tv was flashing as well.I have no picture and no sound.But the tv comes on.
Solution #1
posted on May 05, 2009
Not Rated)
ginko
Rank: Guru  Televisions & Videos  Expert
Rating: 89%, 4939 votes
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Was this helpful?
Yes
No
Popular Solutions for Hitachi 61SWX10B 61 in. Rear
Questions and Unsolved Problems for Hitachi 61SWX10B 61 in. Rear
Do you recommend Hitachi 61SWX10B 61 in. Rear Projection Television?
Answer
Answer
Bright blue shadow in the center left of the screen Hitachi 50c20
Answer
intermittent sound loss on both internal and external channels. The sound works for a while and then... (More)
Answer
i have a hitachi dlp television model/serial 61swx10b The sound has slowly began to come and go at... (More)
Answer
I have no sound coming from the speakers our from the home teater
Answer
Hi,I have a problem with my Hitachi TV, The problem is deflection PCB, part # JT23274, model... (More)
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hitachi 61SWX10B 61 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1494
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
