Question about Hobart AM14-253 Free-standing Dishwasher
Hobart ar14 i think the retainer _switch weldment is shot .how do iknow ?the machine doesnt torn on when i close the door. it also looks like its burnt .
Do you mean the door switch/magnet?
Posted on Oct 25, 2008
Hi I have a Hobart LXIH dishwasher and it is leaking water out of the bottom corners of the door. Do you know what might be causing this?It has a seal at the top but no seal on the sides or bottom.
Make sure your rinse wash arms have the end plugs. If one is missing, water will spray out door.
Your fill valve could possibly be malfunctioning, therefore not closing all of the way. I used to work for Hobart. These LX machines can be a pain in the rear. If you have a water softner, then the valve is probably functioning normally. I do not recall it ever being the door gaskets. I would think you should be getting an error code with the wrench. This is a hot water machine. If you have lime scale building up inside, you may try deliming it. The drain valve could be also causing a problem. There are so many things it could be.
Oct 16, 2017 | Hobart Dishwashers
Hobart am 14c doors won't stay closed. Replaced counterbalance spring but don't know if it has the right tension on it?? Door opens up during wash cycle.
I think you have a commercial machine, and it almost sounds like the door or attached sheet metal may be warped.
Recommend you have someone watch it and see if the latch is really secure, or is always just about to let go.
Also, see if an electric or electronic part has failed allowing the door to open prematurely.
If the latching mechanism is very touchy, and you want to try to do-it-yourself, perhaps a pry bar used gently could adjust the door to not let go at the wrong time.
God bless your efforts.
Feb 21, 2017 | Hobart Dishwashers
2 used LXi machines, they were power washed and stored. an electrician had to open the electric board (drawer) in order to hardwire machines both machines flash the "door open" (dr op) display.
there is a door switch (reed switch) located inside (I believe) the top right side of the unit and there is a magnet in the same place on the door that triggers the switch. If it isn't adjusted right it wont sense the doors are closed. Odd that both would be doing the same thing. Here are the parts diagrams. Reed switch part number 00-473109 http://www.hobart.co.kr/data_file/LXi.pdf
Sep 20, 2016 | Hobart Dishwashers
My washer panel will light up and the load washer light will come on, but the machine won't start
To me that sounds like the problem may be within the door switch/lock, on the doorlock asm. is a little botton that sticks out of it,look and see if its their or perhaps its broken off. What that button does is tells the washer the door is closed so it can go ahead and lock it to start the cycle,its perhaps broken off sothe machine doesnt think the door is closed and thusly wont start.
GENE
Oct 06, 2011 | Kenmore Elite 45986 Front Load Washer
Have a Hobart am 14 ? Service guy sent in a magnet (pt.# 96552450) and a switch (pt# 436071) The switch does not match what is in the machine. What is wrong with this set up?
Call them back!
I assume that he sent you the parts for the new version door switch assembly or He used the wrong ML# when looking up the parts. The ML# is the material list they used for each version of the machine over the years. When they make changes to a machine, like updating the door switch, they issue whats called a TSB (technical service bulletin) to each technician and parts person. Nowadays I think its all computer based. and they dont issue the paper manuals that they used to issue. It was much easier to track way back when. not so much today though.
Hope that helps.
Apr 24, 2010 | Hobart 42 in. AM14C-154 Free-standing...
Random starting by itself
Does this happen all the time?Is the door closed and are they bent?If you stand in front of the unit on the right door up top is there a grey looking capsule (door magnet) is it loose?Next to it should be another capsule which has a switch inside.I would make sure these 2 capsules are tight.Let me know.I'm a hobart tech.
Apr 11, 2009 | Hobart AM14-253 Free-standing Dishwasher
Hobart 450 chopper mixer
Im a hobart service tech and repaired these units often,the seal job is a pain in the ***.Everything has to be torn apart.Forget manuals hobart doesnt give them out but i can step you through it.
Jun 06, 2008 | Hobart A200 Stand Mixer
Close door read out appears
You have a problem with the door alignment and the door switch.. The slightest movement triggers the door switch. You should have someone look at what is causing this issue.
For service on your saeco espresso machine in the New York area: www.cerinicoffee.com
May 24, 2008 | Saeco Incanto Classic Espresso Machine
Am model Hobart dishwasher
Yes. Most of the AM models have a magnet on the RH door, and a corrospnding reed switch on the jam. Sometimes the magnet fractures in the casing and weakens its strength. Otherwise it is likely the reed switch.
On the more recent AMs, it you open the control box and there is a green board on the inside of the door. There will be an LED to show when the door is closed. Look towards the bottom right of the board.
Mike
Apr 23, 2008 | Hobart 29 in. AM15-1 Free-Standing...
Kitchenaid dishwasher KUDS02SRSS2 start light blinking won't start
I have this same kitchenaid model. It would not start after selecting the wash cycle and pressing start. The light would blink as if the door was open. I did the reset by pushing the sani-rinse, heat dry, sani-rinse, heat-dry and closing the door. You can hear something going on inside. After that stopped (about 3 minutes). I was able to select the wash cycle, press the start, close the door, and it started. Good luck!
Feb 22, 2008 | Dishwashers
Hobart AM14-253 Free-standing Dishwasher Logo
105 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
