Question about Mitsubishi WT-46809 46" Rear Projection Television
Wt-46809 YOu have posted a solution to my problem for my wt-46809 but for some reason i cannot see it i get another persons solution ? can you pleas ehelp.
  • chris leck Oct 25, 2008
    first off i have to say i d o ot under stand vey well how this is supposed to work.This the third and final time i am going to try to get help here( i have got alot of help but just when i think i am there i guess i hit the worng button). I have already replaced the ics and the pico fuses and the vertical ic and i am still gettig 2-3 error code please help.If i have made anyone upset before i didnt mean to not ask for more help i didnt know if i hit for more help that it would go against you.
  • 281 Answers
Can you please explain your problem.
Posted on Oct 25, 2008
On my mitsubishi wt-46809 the error code is 2 blinks pause 2 blinks. What is this?
it is short protection and means one of the fuses for the convergence circuit is blown.
I can help with this if you want.
Jan 14, 2011 | Mitsubishi WT-46809 46" Rear Projection...
When you press the Volume Up/Down buttons does it show anything on the screen (like the level indicator bars...)?
Nov 07, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Installing STK392-570 IC's on a Mitsubishi WT-46809
Whoever told you that the WT46809 took two STK392-570 Ic for convergence amps were absolutely - 100% correct... The amps are located at position number Ic8c01 & Ic8c02 on the board. Very difficult to miss too they are about half the size of a pack of cigarettes and 1/4 as thick. They are Mitsubishi part number 267p150010 and after replacing them you want to also check all the low ohm resistors in that circuit for the yoke return.
If you order them don't get them from ebay or some other less than ignorant place, our industry is loaded with chineese knock-offs that would last tem minutes in your set before failing again... Personally I'd order them from Acme Enterprises out of Florida, 800-575-9833 and know that they were Sanyo originals that way.
BTW: If you replace these yourself make sure to use a generous portion of heat sink compound on the new installs for heat dissipation.
Dec 11, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Rear projection set
Convergence circuit repair = replace STK392-570 IC's........
Located on center circuit board on large heat sinks........T.
Please rate this solution...................
No sound
have you tried dvd or other sources?
Mitsubishi WT-46809
I hooked up the DTV mode good picture but no sound ? Help please
Oct 09, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Wt-46809 Not coming on
Try hard reset==leave unplugged from AC a while.
Next--NMI==need more information!
Is this your first problem? Any symptoms before shutdown?
MItsubishi WT 46809- not staying on when turned on
One or more fuse devices open==caused by convergence IC
shorted. Solution==replace fuse(s) and STK I.C.(s).
Oct 08, 2007 | Mitsubishi WT-46809 46" Rear Projection...
Mitsubishi WT-46809 46" Rear Projection Television Logo
51 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
