Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster 1/3 HP - humming, but does not open.
Door worked fine 1 hour prior to door not working. no storm, no electrical problems. overhead unit gets power - light comes on. Press either remote or wall remote and unit clicks, then hums for about a second or two, then stops humming. Door is not jammed - works fine when released. Motor turns freely when manually turned (so it's not locked up). Circuit board problem or transformer? any ideas?
thanks
  • Lockyboy Oct 20, 2008
    I have same problem. It happened once before and we had it serviced. Guy was here for 10 minutes and fixed it easily -- according to my wife who was home. Hate to spend another $75 for 10 minutes of time.
It's the gear drive. There are kits online for about $40, if you're semi-handy you can replace it yourself. Search for liftmaster replacement parts.
Posted on Dec 16, 2008
Liftmaster 3265M. Two units. Why does neither work since lightning storm?
Chamberlain Liftmaster garage door opener problems ...
? 3:10
https://www.youtube.com/watch?v=Zq_CxeTXoSM
Jul 2, 2013 - Uploaded by Mike McCarron
Might have taken a lightening strike, knocked out GFCI that was on the circuit that garage door opener was on. When I ... And sometimes after it happens it takes 30 or so seconds before the opener will work again. ... The keypad unit worked well butneither the homelink or the remote units worked.
Garage Door Openers - Lightning Strike - Forum - Bob Vila
www.bobvila.com/posts/30883-garage-door-openers-lightning-strike?...
Aug 6, 2005 - The house did not lose power and I do not believe the house was actually hit. ... the light comes on on the unit (as expected), but neither door opens or ... Afterplugging it back in, try opening the door with the hardwired button first - if it still doesn'twork, chances are your opener's taken some damage but not ...
I Have A Liftmaster Garage Door Opener Unit. The Remote Work ...
www.diyforums.net/i-have-a-liftmaster-garage-door-opener-unit.-the-re.
Jan 01, 2016 | Building Materials
Door worked, 2 hours later didn't- just hummed good weather
If it just hums when a button is pressed it could be the start capacitor. This sits next to the motor and is about 5 inches long and about as big around as a silver dollar.
May 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman Garage Door Opener Quit Working.
It could be a bad logic board especially if you have had any electrical storms in the area. I would remove and check the logic board for burnt or missing traces on the printed circuit board.
Sep 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Courtesy light not going off
This is usually caused by electrical storms. Electrical surges seem to get to the small relays that control the light and fry them.
Jun 29, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain 1/2hp Operator won't work after electrical storm
Sounds like the circuit board got zapped. You could price a new board or take it apart and check the components if you know how, but normal mortals would just buy a new unit.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door won't open
Unfortunately storms do bad things so door openers sometimes. It has most likely gotten to your logic board. You can remove that board and look for burnt or missing traces of the print. Random flashing of that LED is normal.
May 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
My garage door opener stoped working after a storm.
TRY TO REPROGRAM THE REMOTES TO THE OPENER - THESE UNITS CAN LOSE THE MEMORY DURING STORMS.
I WOULD SUGGEST ADDING A SURGE PROTECTOR AT THE PLUG IN TO PREVENT DAMAGE TO YOUR UNIT IN THE FUTURE.
Apr 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
there is a 2amp fuse inside the opener. go get one and replace it. please look at what kind of fuse it is it's the one that has glass all around and about 1 inch long. to replace this unplug the unit then take the 4 screws out take cover off and you will see the fuse inside
Mar 10, 2009 | liftmaster Chamberlain Garage Door Opener...
My garage door opener does not work may have beem electrical storm. unit has power model 248739
I have Sears Craftsman model 139.58778 and the remote is suddenly not working for no apparent reason. The transmitter in the garage works fine but the portable unit for the car does not. The red light goes on and the toggle switches are correctly set and match the overhead unit setting. Any ideas what is wrong? I purchased a new remote and it did not work either after being correctly set, Thank you!
Sep 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
1,552 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
