Worried about cconnection not working
Ok i was wondering what kind of dvi cables would i need or is the dvi convertors that comes with the videocard im getting work, i tried using a dvi to vga adapter for my moniter recently and it didnt work, im worried that i might have the same problem with my new video card
heres the card
http://www.newegg.com/Product/Produc...82E16814130356
the pics of the ports it has
http://www.newegg.com/Product/ShowIm...d%20-%20Retail
the connections my moniter has its a gateway 700g 17 inch moniter
the pic isnt of my moniter but shows what connections i have on it.
http://www.codinghorror.com/blog/ima...-vga-ports.jpg
thanks
5 Suggested Answers
  • 43 Answers
SOURCE: Upgrading SR2010NX
Processor and ddr2 work fine as it comes to fan you have to know what kind of fan it uses 80 mm or 120 mm.
Posted on Jan 31, 2008
PCBuilda
  • 101 Answers
SOURCE: DVI cable not working
If you still have your old monitor plug it back in for a bit and load the drivers for the new monitor (from the disk which came with the new monitor). Right click on your desktop and choose properties and set your display resolution to something like 1024 x 768. Shut down the pc and connect your new monitor to it with the dvi adapter. If it is recognised ok you can then set the resolution from 1024 x 768 to the recommended amount for your new screen. The refresh rate is also important as some lcd screens only work at a certain level. There should be an auto switch on the monitor and if you press this it sets the display to optimum, - or should do.
Posted on Mar 21, 2008
  • 24 Answers
SOURCE: what dvi cable do i need?
Any bog standard dvi cable should work. As should a dvi to vga converter. Dvi is by far the better interface, and I would highly recommend using it, without any converters. I don't believe you can up convert vga to dvi, but you can certainly downgrade a dvi signal to vga, but i can't see why you would want to...
Posted on Dec 25, 2008
  • 36 Answers
SOURCE: I want to get a new video card But..
For Motherboard interface:
mini tower version of the Optiplex GX520 appears to have one PCI Express Slot. other cases don't appear to have anything.
Check the photos on the link below to match up your form factor
http://www.dell.com/content/products/productdetails.aspx/optix_gx520?c=us&cs=28&l=en&s=dfb
For monitor, make sure you have a DVi port or something like that & that your card has a matching port or that you can get an acceptable adapter. If monitor not DV capable, HD video card will not help you much.
Posted on Jan 09, 2009
***Need Help Connecting HP Pavilion dv6500 (running Win Vista SP1) To Panasonic Plasma!!
No. It is not going to work.
VGA is an Analog signal. HDMI is a digital signal, that is why you need the box, it converts analog to digital.
You can get VGA to DVI and DVI to HDMI convertors because DVI is capable of using both - depending on the type of DVI you have.
What is the difference between DVI and DVI NVIDIA
HDMI Wikipedia the free encyclopedia
Video Graphics Array
Mar 29, 2017 | Computers & Internet
I just have a TESTING.... box floating on the screen. Even the menu buttons display nothing. Has this beast finally bit the dust?
Possible reasons for that may be bad cable connection, burnt videocard, or problem in the signal board in the monitor.
So, first check with another monitor if your PC is actually giving a singnal. Then look both ends of the cable for bend pins. They can be easily strighten with thin plyers. You can replace the cable VGA (or DVI) cable to see if it will fix the problem.
If your videocard is OK and the cable is OK, then try to open the monitor. Replace the capacitors on the signal board. Look for blown capacitors on the power board too. Replace if any.
If this cant help, there is major problem with the signal board of the monitor and more measuring is needed. There are buffer elements between the connector and the signal processor and some of them may be faulty. If there are no buffers and the signal goes directly to the processor, entire board should be replaced.
If there are VGA and DVI inputs, you may try the other input with the relevant cable.
Aug 11, 2010 | ViewSonic VA800 17.4" Flat Panel LCD...
I have an LG Flatron L226WTQ-SF and my monitor has some "shadowing". If you need more infos I can send you some pictures.
If you are using analog VGA cable, replace it with one that has ferrite rings near both ends. The best is to use DVI digital cable but this depends on the capabilities of the videocard and the monitor ofcource, but I think this monitor has DVI input.
Aug 05, 2010 | LG L226WTQ-BF Monitor
What cable do I need to connect latitude D600 to a hdtv ?
The first step is to inspect both your laptop and TV and identify the connections, easily located on the back of either component. There are five basic types of jacks, or ports involved:
*Composite/phono plug (RCA)
*S-Video
*Video graphics array (VGA)
*Digital video interface (DVI)
*High-definition multimedia interface (HDMI)
*An RCA connector, sometimes called a phono connector, is used for analog audio and video components. Three round, colored sockets are standard — left audio is white, right audio is red, and composite video is yellow. These are standard jacks on older TV’s and laptops. A three-prong cable, readily available at any computer or electronics, is the easiest way to make an RCA laptop to TV connection.
*S-Video, or Super-Video, a more advanced analog video connector, uses a four-prong round plug, like those used in TV cable installations. Separate audio cables are the same as for the RCA connector, left audio/white, and right audio/red. S-Video is commonly found on older TV sets and some laptops.
With S-Video on both TV and laptop, connecting a laptop to a TV is a simple matter of a single S-Video cable. If your laptop has a great sound system, you won’t need audio cables, but for better quality you’ll also want audio cables.
RCA to S-Video cable, a special laptop to TV cable, is available when you have RCA jacks on one device and an S-Video port on the other.
*A VGA connector and cable are used to carry analog video signals plus display and graphics data. The VGA is a 15-pin connector commonly found on laptops and other devices. With this port you need a PC-to-TV Convertor to connect laptop to TV. You simply plug the VGA cable from the source into the convertor, and use an S-Video or RCA cable out to the TV. The converter is USB powered, so there’s no external power adapter to carry around, making this laptop to TV connection entirely portable.
*A DVI port is rectangular with 24 pins arranged in three horizontal rows of eight pins for digital video; separate RCA analog audio cables fit into white and red plugs. DVI ports are found on Macintosh laptops; sometimes they are smaller than normal DVI ports and require an adapter, which usually comes with the laptop.
*The HDMI port, one-half the size of the DVI port, is also rectangular with 19 pins. It provides digital audio in addition to digital video, despite it’s smaller size, for a complete TV to laptop connection. These ports are found on new HDTVs, and sometimes there are two or more. TVs with HDMI ports are the only ones that do not require additional audio cables.
TV’s with a single digital port labeled HDMI/DVI require only one cable when the source is another HDMI component. But when source is a DVI laptop, you need a DVI-to-HDMI cable for the video and a separate pair of RCA analog stereo cables.
NOTE: Whenever ports do not match, you can by adaptors and/or cables to make any connection.
Nov 22, 2009 | Dell Latitude D600 Notebook
Is it possible to put PCI videocard on 661fxme
The motherboard supports AGP to 8X so yes is the answer.
Sep 26, 2009 | ATI All-In-Wonder Radeon 9600 AGP...
I have a new graphics card and the connections dont match
the motherboard might be VGA, and the card PCIE, the connectors will not match, more info is required, better still check motherboard specifications, and look for the right type of graphics card.
Jan 25, 2009 | Computers & Internet
What dvi cable do i need?
Oct 17, 2008 | Computers & Internet
Re: Video Card TOAST???
Given the environment and issue, sometimes a solid way to process of eliminate, is to add a display to the laptop. Laptop videocards are embedded/integrated in the motherboard/logic board. So, your Mac has not been specified. This provides for many variables. I'll keep this simple but thorough.
First, monitors. Unless you have a great hook up from the next level, you will most likely have a:
  • VGA monitor. if the monitor has the cable attached to it, and not via connectors, but actually runs into the back of the monitor, odds are it's VGA.
  • DVI monitor. Most DVI monitors do have atleast a VGA input.
DVI is digital and far more robust, but the cables and connectors might not outweight what you gain from it if you're not using it to, watch movies, edit video and or edit high resolution photo. If you already own a DVI monitor, then I feel the cable ( if 3-6 ft) and the "possible adapter"
($20) is well worth enjoying what you've paid for.
The "possible adapter" is a white (made by Apple for Apple) proprietary adapter that is required to connect any Macintosh laptop that IS NOT of the ALUMINUM POWERBOOK or MAC BOOK or MACBOOK PRO series, to a monitor. All recent Macintosh laptops ship with 1 form or another of a video adapter.
  • Mini VGA to VGA
  • Mini DVI to DVI
If you need to cross over VGA to DVI and DVI to VGA adapters are available, but you will then have to make note of the gender of the connecting port or cable end.
So, if you own:
  • A white G3/G4 IBook, the video output connection is MINI VGA.
  • Older Titanium Powerbooks, pre 667Mhz have a standard VGA on the rear.
  • 667Mhz-1Ghz Titanium Powerbook, all Aluminum Powerbooks, and ALL Macbook Pros have an on-board DVI female ports. In the rear for TIbooks and Rear right side on Aluminumbooks and MBPs.
  • All Macbooks utilize mini DVI.
SO, ON WITH THE QUESTION PLEASE!!
Connect a display to your laptop. If you get a picture, than more than likely, any component from the cable that runs from the motherboard, up into the display panel, to the inside of the display, is faulty.
If you do not get a picture, than its highly possible the video card or GPU has failed.
If you could specify your model, I can further assist you.
Sep 02, 2008 | Apple iBook G3 Mac Notebook
Screen turns off after installing drivers on Gainward GF 6800GT AGP | PLEASE HELP!
yes buy a dvi to screen 20 times better picture faster your cpu is lowest perfermer i see add 1 gb ram too on op of your 1 gb have u dl netframework 2.0 i know ati needs itow ork did u dl all upri updaes online 1st after u install xp u nee dto update it alll 1st use latest driver from nvidia
Dec 12, 2007 | Computers & Internet
DVI input on monitor not working
Contacted viewsonic about this issue- they suggested- have both dvi and vga hooked up to same machine. start with poweroff on both. power on monitor, then power on computer. when you see display coming from the vga, power off pc, then disconnect vga cable, turn off power to monitor, disconnect power cord from monitor for 5 + seconds, reconnect power cord, power on monitor, then power on pc.
If this doesn't work to get the dvi working, (as happened to us) we returned our monitor for a replacement, since it was still under warranty.
Sep 17, 2007 | ViewSonic VX2025wm 20.1" LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
