1993 Oldsmobile Cutlass Ciera Logo
Posted on Oct 17, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Car wont start after driving
Starter,plugs,fuel filter replaced,generator tested and passed. small vacum line crack repaired .1993 buick serria,3300,6 cylnders
car start up fine runs fine after running/driving for 10 or more minutes and shutting off car will not start for 20 minutes then turns right over like nothing was wrong.doring this down time car just cranks and cranks
wont start.any ideas whats wrong?
  • 2 more comments
  • ddevale Oct 17, 2008
    thanks i will give that a try
  • marlerg Oct 22, 2008
    We have the same car and it is doing the same thing. Did you try the ignition module. We have changed the starter and that did not help.
  • Anonymous Jul 04, 2012
    had same problem with my truck was switching around relays and my charge relay was out replaced and now runs fine
  • Anonymous Mar 13, 2014
    was driving down the highway and the car blew an oil line now wont start it started fine in the morning replaced oil line but it wont take a boost
Anonymous
Level 3:
Master:
  • Master 426 Answers
  • Posted on Oct 17, 2008
Anonymous
Master
Level 3:
Master:
Answers
426
Questions
Helped
205641
Points
1323
Ignition module is the likeliest place to look.
1993 d21 wont start without starter fluid
Could be this,test it if you can to make sure.
1helpful
I have a 1990 mitsubishi might max it wont run smooth unless you keep your foot on the gas and keep the rpms up a little bit and it wont drive cause it stalls everytime you try to move it. ive replaced the...
You've already eliminated the spark plug & wireset, distributor cap & rotor.
Sounds like your car needs a tune-up, specifically, the PCV (positive crankcase ventilation) valve, and/of the EGR (Exhaust Gas Recirculation) valve.
Components checked/replaced during a tune-up are:
air filter
motor oil
motor oil filter
breather filter
fuel filter(s)
fuel strainer
PCV valve
EGR valve
spark plugs
spark plug wires
ECM or distributor cap & rotor
cabin air filter
transmission oil filter
transmission oil
engine coolant
check all vacuum hoses and lines
Troubleshooting the no-start condition - from the 1990 Mitsu Mighty Max Repair Manual:
Priority Action Part Type -- Cause
1 Inspect Battery -- Battery Discharged or Faulty.
2 Inspect Battery Cable -- Corroded, Broken, Shorted or Poorly Connected Battery Cable.
3 Inspect Distributor Cap -- Distributor Cap Cracked or Burned.
3 Inspect Fuel Filter -- Clogged or Dirty Fuel Filter.
5 Inspect Ignition Coil -- Faulty Ignition Coil.
6 Inspect Wireset -- Worn, Damaged or Faulty Spark Plug Wire(s).
7 Inspect Spark Plug -- Incorrectly Gapped or Fouled Spark Plug(s).
8 Inspect Starter -- Starter Motor Faulty.
9 Inspect Fuel Pump -- Low Fuel Pressure.
10 Inspect Solenoid Switch -- Faulty Starter Solenoid Switch.
11 Inspect Fuel Pump Relay -- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator -- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch -- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive -- Faulty Starter Drive.
15 Inspect Fuel Injector -- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer -- Clogged or Dirty Fuel Pump Strainerat.
17 Inspect Engine Control Computer -- Incorrect Operating Information Being Delivered and Sent From The EEC.
18 Inspect Fuel Tank -- Fuel Tank Empty.
19 Inspect Carburetor -- Carburetor Flooded or Faulty Choke.
20 Inspect Distributor -- Worn, Loose, or Incorrectly Installed Distributor.
My car wont start
5 Inspect Coil - Ignition -- Faulty Ignition Coil.
11 Inspect Relay - Fuel Pump ----- Faulty Fuel Pump Relay.
12 Inspect Fuel Injector Pressure Regulator --- Faulty Fuel Injector Pressure Regulator.
13 Inspect Ignition Switch --- Improperly Connected or Faulty Ignition Switch.
14 Inspect Starter Drive --- Faulty Starter Drive.
15 Inspect Fuel Injector --- Dirty or Worn Fuel Injectors.
16 Inspect Fuel Pump Strainer ---- Clogged or Dirty Fuel Pump Strainerat.
3helpful
Recently bought 1993 Buick LeSabre. When driving the car around for a little while, it stalls when you come to a stop. The car will start up right away and will continue to stall. Help Please!
could be spark plugs and wires or fuel filter clogged. if not any of these fixes.. its possible you have an intake leak... check all those small little vacuum hoses for cracks and security. can you rate my answer..thanks!
2helpful
4answers
1993 Buick Skylark- Starts but immediately powers
Could be fuel filter, best thing to do is chg. fuel filter and do a fuel pressure test, don't think for a moment that it can't be the pump they have been known to go out just that quick.
Wont start
I'm assuming the engine is cranking over while turning the key and wont start. from this assumsion it possible the cam sensor on the timing chain is broken. or no fuel pressure. to test for fuel pressure, turn the igntion key on, locate the fuel line & port on the fuel line, remove the cap & depress the small screader valve by using a small pocket screwdriver, fuel should shoot out with a lot of pressure. no fuel shooting out most likey the fuel pump is bad. if this has good pressure the cam sensor is most likey the cause. to replace the sensor, you need to replace the timing chain.
2answers
Car starts then stalls out...
could be to many thing to take chances with, but most commonly;fuel filter,gas line antifreeze or a crack in your air intake which would take your vacuum seal away, start with the least expensive and work from their. Worst case scenario pinched fuel line
6helpful
3answers
Buick lesabre no start
Hi you have replaced allmost everything ,(try fuel pump relay)
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
