Question about Samsung P241
Unlock regional code for Samsung dvd p241 make it region free
I would like to make my Samsung P241 dvd player region free. So far I haven't found a solution on the web.
  • tfmcihael Dec 07, 2008
    same here can't get my plaer to work
SOURCE: Region code for Samsung DVD-V6700
1. Make sure there is no DVD in the drive. The player must be empty. Turn on the player, (the Samsung logo appears)
2. Press the SUBTITLE button on your remote
3. With your remote enter the code: 76884
4. The current region is displayed on the top left corner of the screen. (e.g. 4)
5. Press 9 on your remote (Region free)
6. Again press the SUBTITLE button on your remote
7. Enjoy the Region free player
If your player is NOT Region 4 by default then you will need to Substitute the Numbers in Step 3 with the ones Below.
Region codes:
RC 1: 2, 9, 3, 3, 4
RC 2: 3, 8, 7, 6, 7 (or 5, 7, 5, 3, 8 )
RC 3: 5, 6, 7, 3, 2
RC 4: 7, 6, 8, 8, 4
RC 5: 5, 3, 8, 1, 4
RC 6: 2, 4, 4, 6, 2
For Example if your Player was Purchased in the USA ( Which is Region 1) then Step 3 would read :-
3. With your remote enter the code: 29334
Posted on Jan 29, 2008
SOURCE: region free - Samsung DVD-VR375 DVD Recorder / VCR
I have managed to get a solution to this now. I have a region 4 as in Australia so depending on where you are you'll need to try the correct region. It worked for me first time. Point 4/ below my region code appeared in the top right corner for a couple of seconds not the top left! Once you've completed below turn the machine on again and stick in one of the dvds that would not work before.
Cheers Stewart
1/Turn machine on without disc inside
2/Press menu button
3/Enter region code (See below for list)
4/A highlighted 'region area number' will appear in the upper left corner (some players)
5/Press 9 to change the region number to multi-regional
6/Turn machine off
R1 - 29334
R2 - 38767
or, 5 7 5 3 8
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Posted on Sep 19, 2008
  • 146 Answers
SOURCE: changing to multi region dvd
There are a couple sites I found that offer the codes for that player and the BD-P1000. I am not sure if I am allowed to post the links for those sites but the link to the site zimcloud posted is one of the places I saw it listed. You can google the model and region code and a list of sites come up.
Cheers
Posted on Jan 03, 2009
SOURCE: region free code for samsung HD-BD2E
Haven't tried it, but found this online somewhere....
1. Open tray and remove any disks in tray.
2. Close tray.
3. Switch Off Player and Unplug from mains wait 30 seconds (this clears RAM)
4. Reconnect to mains
5. Turn on player with remote.
6. Press ENTER on remote.
5. Press 8, 4, 2, 6, 9.
7. Press ENTER on remote. (The tray will open)
8. Switch off power from remote, then switch back on.
9. Player is now Region Free.
Posted on Mar 22, 2009
MNfisherman
  • 11896 Answers
SOURCE: region hack code for samsung dvd-p241
You can try to use this tip, which is generally used for all these Samsung models: DVD-709,DVD-809,DVD-909,DVD-511,DVD-611,DVD-615,DVD-811,DVD-M105,DVD-M105 E,DVD-M108,DVD-M203,DVD-M204,DVD-M205,DVD-M305,DVD-M405,DVD-P233,DVD-V530. I think that P-241 is about the same of P-233, which is unlocked with this tip. You can try, and then answer me if worked.
1. Make sure that there is no disc in the tray and switch on the player.
2. Cold start the player, by holding down the PLAY and STOP buttons on the player.
3. You should see a set of language options. Release the PLAY and STOP buttons.
4. Select your language.
5. Press REPEAT then the following codes for the required region the player is already set to (region you bought the player in) do not confuse this with the A-B button:
Region 1 - 2, 9, 3, 3, 4
Region 2 - 3, 8, 7, 6, 7
("E series M105", M205 and M305 users try: 57538)
Region 3 - 5, 6, 7, 3, 2
Region 4 - 7, 6, 8, 8, 4
Region 5 - 5, 3, 8, 1, 4
Region 6 - 2, 4, 4, 6, 2
6. A code will appear, indicating the region setting of your player.
7. Press 9 for region-free, or 1 for region 1, 2 for region 2, etc.
8. Press OPEN/CLOSE on the Player to open the disc tray. You may need to push the tray shut rather than use the player button, in order for the region not to be changed to 4 (M203).
9. Press STANDBY (POWER) on the remote control to close the tray. Next time the player is turned on it will set to the region specified. If the player halts on the FBI Warnings, press Forward Search x2 or faster.
On some models, you will have the ability to disable Macrovision, but you will have to turn off the Quasi-PAL option and set the SCART output type to Video rather than RGB.
Posted on Jul 09, 2009
Currently Region 2 - I want to make it region free
Manufacturers of DVDs and DVD players install codes that only allow us to play DVDs that are manufactured for our region. (For example, the U.S. and Canada are region 1, while China is region 6.) To make your DVD player region-free, you'll need to find the unlock codes that will allow it to play DVDs from all over the world. Below are some steps to help make your DVD player region-free.
Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs. Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player. Have your remote handy. You will need your remote to enter the input codes into your DVD player. Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured. Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number. Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open. Test your imported DVD to see if it works, once you have entered your code into the DVD player.
Apr 18, 2013 | Samsung Black Slim External Usb Dvd Writer...
DOWNLOAD REGION FREE CODE FOR SAMSUNG DVD BD-E5300 PLAYER
You may get a region free code from these WEB sites.
Unlock DVD Players - Region Free Code
www.dvdexploder.com/ www.download-info.com/dvd/index_new.htm
Feb 15, 2013 | Samsung Blu-ray Player BD-E5300
I have a Samsung ES8200 3D Blue Ray player and wish to find the code to unlock the region code
You maybe able to get a region free code for your player from these WEB sites.
Feb 10, 2013 | Samsung Televison & Video
Samsung blu ray ht e5550w region unlock code
You maybe able to get region free code for your player from these WEB sites.
Jan 28, 2013 | Samsung BD-UP5000 Blu-ray and HD-DVD...
Model c500. How do I change region?
Found this on the web some time ago. Samsung C500 DVD player. Use the following steps to make this player region free;
1. Start the DVD with no disc and use the remote;
2. Click the Repeat (not the Repeat A/B) button located far left of the remote.
3. Click the Fast Rewind button <<
4. Click the Next Chapter button >>'
5. Click the Fast Forward button >>
6. Click the Prev Chapter button '<<
7. Click the Play button >
8. Once the grid selections appear, use the arrow buttons to select/highlight "9" for region free. Make sure to select "save and exit" as shown below to screen on your television. The player will shut-off automatically. Restart and play with any DVDs.
Hope this works!
Jul 21, 2010 | Samsung Televison & Video
Region hack code for samsung dvd-p241
Jul 09, 2009 | Philips Magnavox MWD7006 DVD Player
DVD Freeze-Ups
Sounds like the transverse motor is bad.
Dec 03, 2007 | Samsung DVD-P241 DVD Player
Video on P241 DVD player
replace the bigger IC of the module
Oct 23, 2007 | Samsung DVD-P241 DVD Player
Samsung P241 Logo
340 people viewed this question
Henry  Thomas
Henry Thomas
