Need to set up D-Link Dir 655 as Sonicwall client!
Hey guys, I consult for a client with a sonicwall firewall at their end and I am connecting remotely using the SonicWall Global VPN Client on a windows xp box. Unfortunately, Sonicwall doesn't have a client that supports a any 64bit windows and my main box runs xp64. I there a way to set up my D-Link Dir 655 router as the client? And if so, how do I go about doing this? Thanks in advance for your help!
  • 35 Answers
SOURCE: Cannot connect with SonicWall VPN Client with GigaFast EE420 R
sonic is sitting on the gateway. so dont matter where u are still u cant get outside
Posted on Aug 13, 2008
SOURCE: Wyse S30 thin Client with Ubuntu
I played with those a lot with the LTSP and finally made it work...
All in all, the problem is that the X.org cannot autoconfigure the graphic chip of this client. On ubuntu 7.10 you need to force it to use the amd driver and cannot do it from the LTSP.conf file.
In your LTSP.conf file, you have to point to a xorg.conf file specific for your s30 thin client (I called it s30xorg.conf). Then you need to build this xorg.conf file (lots of help on the net on how to do this) and place it in the right folder. (The folder is probably not the same than on my system but it should be pretty obvious or at least written in the manuals or help files where to pu it). In this xorg.conf file, you will need to specify the amd driver and some standard vesa resolutions and refresh rates (also widely availavble on the net). Then dont forget to rebuild your LTSP image with those new files in the tree.
If I remember correctly you will also need to disable the ubuntu splash screen from another config file somewhere... I am sure you will find which one.
Then voila.
Let me know if you can make it work... if what I said is total gebrish, go on reading everythin you can find on the net until you understand what is here.
Thanks
Posted on Dec 04, 2008
sach3000
  • 51 Answers
SOURCE: Can I remote access a desktop using Thin Client (Neoware e140)
with RDP 5 or 6
Start - Run- mstsc
Posted on Aug 21, 2009
  • 128 Answers
SOURCE: sonicwall client won't connect to the internet
The default VPN policy rules prevent LAN access, also known as split-tunneling, since this creates a security risk (the ability of the VPN session to be hijacked or compromised through a covert channel).
If you are not the system admin, you need to talk to your system admin. If you are the system admin, then you need to review the documentation with respect to
http://www.sonicwall.com/us/support/kb.asp?kbsk=policy+allow+lan
Posted on Oct 07, 2009
  • 345 Answers
SOURCE: WRT120N doesn;t permit VPN accesses
Most times when VPN is not working is because one of the ports is not forwarding right. Easy fix is to go to router settings and enable DMZ for your computers IP address. Also you can actually find out what are the ports this VPN uses and go to Port Forwarding part of router and open the ports manually. My favorite is DMZ. All this does is open up ports for your computer IP address so there is no blocked pockets. Good luck.
Posted on Jan 12, 2010
Cofiguring sonicwall TZ190 to block all trojans and viruses
The"svchost.exe" is a normall windows system files.
It does not cause any harm to your pc.
It's only a running process.
Regards
Uttam
Feb 19, 2010 | SonicWALL TZ170 (01-ssc-5740) Firewall
I need to add an ip range to my sonicwall tz 170
This is not directly possible to do with a TZ170 as the device will only allow configuration for 1 static or dynamic IP at a time for the WAN port.
However this being the case, I suggest setting the SonicWALL up as a perimeter firewall and place devices that require the other public IPs form the additional IP range behind the TZ170. Basically the SonicWALL becomes the gateway for the other IPs needed as long as the range of the IP block is contiguous.
This would involve using the 4 ports of the LAN on the back of the TZ170 to connect directly to the other devices or if it is more then 4 devices, using a switch connected to the LAN side of the SonicWALL to provide connectivity to the multiple devices behind it. Most TZ170 are licensed for 10 connections on the LAN side and if you require more then 10, additional licenses will need to be purchased.
I would be careful pushing too much traffic through a TZ170 as it is designed for Small Business use and will quickly become overloaded with too much traffic causing high latency/traffic bottlenecks and in extreme cases connections being dropped. This is especially true for multiple VPNs.
Jan 23, 2010 | SonicWALL TZ 170 SP Firewall
Sonicwall client won't connect to the internet
Oct 07, 2009 | Sonicwall PRO 3060 NFR (01-ssc-5378)...
I am using Sonicwall Pro 2040. I am trying to connect Sonic Wall gateway but it is asking for pre-shared key instead of user and password please help me. regards pratap
pre-shared key is a must for connectivity. only after inputting this, you would be prompted with user id & password, if configured to.
Sep 02, 2009 | SonicWALL Pro 2040 Firewall
How to routing router static ip address and local
Use the Sonicwall configuration wizard..
Please find below is to configure what ever you want.
Setup Wizard - This wizard will help you quickly configure the SonicWALL to secure your Internet connection. Once completed, you can use the SonicWALL Web Management Interface for additional configuration.
Registration & License Wizard - This wizard will help you register you and your firewall with mysonicwall.com and obtain licenses for additional Security Services features.
PortShield Interface Wizard - Segment and configure the integrated managed LAN switch of the SonicWALL.
Public Server Wizard - Quickly configure your SonicWALL to provide public access to an internal server.
VPN Wizard - Create a new site-to-site VPN Policy or configure the WAN GroupVPN to accept connections from the SonicWALL Global VPN Client
Thanks
Apr 22, 2009 | SonicWALL TZ170 (01-ssc-5740) Firewall
Cannot run RDP, Telnet over MPLS when sonic firewall is connected
You have to give rights to the particular systems. Means enable NAT policys in the sonicwall router.
for details go to the SonicWall Router Manual. Or else you can contact me, I will help you.
Thanks
Sriram.S
Chennai - 4
Feb 26, 2009 | SonicWALL PRO 100 Firewall
Sonicwall Internet Connection Issue! HELP PLEASE!!!
juz clear the arp entries or else change the connectivity cable from modem to firewall.
Aug 21, 2008 | SonicWALL PRO 230 Firewall
Jul 29, 2008 | Computers & Internet
Can not connect to PPPOE DSL
Is there a reason why the Sonicwall needs to do the PPPOE auth? You should be able to let the modem do the PPPOE connection and have the Sonicwall behind it. The Sonic wall will get a private IP address. Andy
Jun 21, 2007 | SonicWALL TELE2 Firewall
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
