Question about Ricoh Office Equipment & Supplies
Do i need usb cable to install printer to my computer
  • 6,487 Answers
Yes, you need a sub cable for your printer in order for you to use to your computer because almost all of the printers now connect to a computer via USB in order for it to work...
Don't forget to rate the solution FIXYA thank you....
Posted on Oct 17, 2008
My computer is saying it is not connected to my Lexmark x2670 printer but I have everything connected. I need my printer! Help please.
Cannot Communicate; install USB; Install cable; installation USB; Installation cable; Cannot continue installation; Unable to press Continue; Unavailable Continue button; Continue button not active; Opaque Continue button; Gray Continue button; Continue button grayed out; USB connection not recognized
What you will see The Continue button is gray (i.e. Continue), preventing further driver stallation. connect the Installation Cable; using the supplied installation cable, connect to any USB port on this computer. Back Quit Continue There are several possible reasons for an inactive Continue button. Try the following suggestions in the order provided to resolve this issue: Action
1 Make sure the printer is turned on:
2 Confirm a solid connection of the USB installation cable on both printer and computer. HINT: The USB port is identified by this symbol:
3 Keeping Step 2 in mind, disconnect the USB cable from both printer and computer and then reconnect the USB cable at both ends.
HINT: Listen for audio alerts or notification icons or balloons in the Windows notification area. For example, or or .
4 If your computer has multiple USB ports, try connecting the USB installation cable to a different USB port.
NOTE: Passive or self-powered USB hubs may cause a problem.
5 If one is available, try connecting another USB device to the same USB port to see if it is recognized by the operating system.
6 If one is available, try a different USB cable that is under 10 feet.
NOTE: Some port replicators or docking stations for laptops or notebooks may cause a problem.
7 Confirm that you are installing the correct software driver for your printer model. For example, a 7600 Series driver works with the X7650 and X7675 All-In-One.
8 Turn off the printer, and disconnect and reinsert the power supply and power cord. Click here for image.
9 Click Quit to exit the installation. Remove the CD from the CD or DVD drive. Then reinsert the CD and try to perform the installation again.
To save time you can skip or close the hardware setup wizard if you have already completed these tasks. 10 Confirm that Device Manager recognizes the device. To open Windows Device Manager: Click on Start and then Run.In the Run dialog, type devmgmt.msc. Click OK.11 Next, disconnect the USB cable from the printer and reconnect it. Watch the Device Manager indow while you do so. The appearance of the items in the screen should change as Device Manager tries to recognize the device. Click here for image.Macintosh users: System Profiler is the Device Manager equivalent. Click here for instructions on accessing System Profiler, and look under Hardware > USB for the printer.12 Does Device Manager show a change in appearance?-If Yes, contact Lexmark Technical Support for additional assistance. -If No, there may be a problem with your computer and its USB support. The computer must recognize the USB cable in order for installation to work. 13 Reboot your PC and try these steps again.
Oct 02, 2011 | Lexmark X2670 All-In-One Printer
My Officejet 5610xi All-in-One will not print from my computer. The printer tells me it is not connected to my computer
try to check the cable or the usb connection from the computer to the printer it must be loosing or not connected properly to the interface. Install the the driver camed with your printer to your computer to be able to use it.
Oct 17, 2008 | HP Office Equipment & Supplies
I have a canon pixma mp 287 printer i have installed the drivers also and it is also not offline but when i am giving command to it then it is showing that printer is not responding.why it is showing like...
solution :
1. Uninstall driver printer and remove Printer USB cable from computer. After uninstall finish, restart printer.
2. Reinstall driver printer (don't connect printer USB cable to computer). Wait for the install process, until message "connect a printer USB cable to computer". After message appear, connect printer USB cable to computer.
3. Wait process install finish and try to print.
Sep 23, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
During the wireless install, once the installation USB cable is connected the CONTINUE button does not activate...
It could be the USB cable. Make sure the cable is properly inserted in the USB port behind your printer and on your computer. Try to unplug then replug the USB cable into your computer and printer.
Apr 16, 2011 | Lexmark Z1480 InkJet Printer
I am installing this new printer and need the usb cable to connect printer to computer. Where is it? I cannot see it anywhere.
you cant see the usb cable? or the usb port? Some printers are still not supplied with a USB cable, silly I know, but for some reason they dont supply. If you were not supplied a USB cable you will need to go to your computer store (or the place you got the printer) and purchse a USB cable
Feb 09, 2011 | Brother Multi-Function Center MFC-240C...
Printer USB Cable un recognized DCP150C
You need to isolate the problem. You tried using multiple cables and reinstalled the printer driver several times, but you never mentioned that you tried connecting the printer into another computer. What if the problem is the USB port of the computer and not the printer cable?
Try connecting and installing the problem printer into different computer for testing purpose only. If it work, then the problem is the USB port of the computer. To fix this, try updating the USB driver of your computer.
If same problem occurs using another computer, then you need to contact the manufacturer of your printer. I've heard this problem before and I don't have an update if there's a fix with it.
Have a great day!
Oct 01, 2009 | Brother Office Equipment & Supplies
I'm trying g to connect my Dell AIO 922 printer to
You need to go to Control Panel add/remove programs and remove all Printer programs. Then disconnect the USB cable, install the printer software until a message comes up that says plug in your printer. If no message comes up, complete the software installation and then plug in the USB cable. The computer should find the printer at this time.
Aug 15, 2009 | Epson Stylus Photo R200 InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
How to connect and install driver to the printer
The HP 640C will connect to a PC with either a parallel or a USB cable. If you are connecting to a Mac computer, you will connect to your PC with a USB cable. I would recommend the USB cable for either the Mac or a PC as it is a better connection. If you do not have either of those cables you will need to buy one from your local computer accessory store. Turn off your printer and computer. Connect your cable to the printer and computer. Then boot your computer, and once the bootup finishes, turn on the printer. At that point you will have to install the software driver cd that came with the printer. If you do not have the software you can go to the HP website and download the correct drivers for your computer.
Jul 07, 2009 | HP DeskJet 640c InkJet Printer
Installation for canon pixma ip 1500
Hey you again, you rated me yesterday Inappropriate. Actually, fixya expert afraid to give some solution because you will rated us Inappropriate even the problem is came from you where you was not clearly stated your problem.
Ok, but anyway I am still to help you, Is it the problem goes to the manual installation you need or the driver instead?
Printers used to be the bugbear of computer users. They were difficult to set up and ornery in operation. That's no longer the case and it's likely you'll have no problems getting your printer up and running. This is particularly the case if your printer comes packaged with your computer system or if you stick to well-known brands such as Hewlett-Packard, Epson, Lexmark and Canon.
Connecting a printer involves four steps:
  1. Unpacking your printer, removing any packaging material and installing the ink or toner cartridge. Refer to your printer's instructions to guide you.
  2. Connecting the printer cable to the printer and to the back of your computer.
  3. Connecting the printer's power cord to a power outlet.
  4. Installing the printer driver and any additional software. The printer driver is a piece of software that tells your computer how to interact with your printer.
If your printer comes as part of your system, you may find that its driver is already installed. In that case, all you'll need to do is unpack it, connect the printer cable and power cord and switch on your computer.
geekgirl.tip: Get a cable One word of warning: Make sure you purchase a printer cable! Often, this is not included in your computer system, despite it being an essential item. You'll need the correct type of cable for your printer: If it's a USB-enabled printer, you need a USB cable (note, the new USB 2 cables work with older USB 1 printers, too; so if in doubt, get a USB 2 cable); if it's a parallel printer, you'll need a parallel cable.
Make sure you get a cable long enough to reach easily from your printer to your computer. However, you should avoid cables longer than 10', because long cables can cause problems with communication between printer and computer. Try to position your printer so a 6' (or shorter) cable can make the connection.
Follow the wizard If your printer's software has not been pre-installed, read any installation instructions that accompany your printer and follow those instructions. If no instructions are provided, follow this procedure:
(Note: This procedure applies to printers which use a parallel connection. If your printer uses a USB connection, you should connect it while Windows is running and it will be recognised.)
  1. Make sure you have your original Windows CD-ROM handy. You may need it.
  2. Switch the computer off.
  3. Connect the parallel printer cable to your computer.
  4. Connect the printer's power cord to a power outlet.
  5. Switch on the printer and the computer.
  6. In most cases, Windows will detect that you've attached a new hardware device and it will launch the Add Hardware Wizard and attempt to search for the appropriate software. If the wizard doesn't launch and Windows appears to ignore your printer, you can launch the Add Printer wizard yourself by clicking the Start button, selecting Control Panel, clicking Printers And Other Hardware, and then clicking Add Printer.
  7. If the printer is directly connected to your computer, select the Local Printer Attached To This Computer option. If you will be connecting to the printer via a network connection, select the Network Printer option, then click Next.
  8. The wizard will first try to search for any Plug and Play devices (these are components that should, by rights, automatically notify Windows when they're first connected). If the wizard discovers your printer, it will display further instructions to complete the installation. You may need to restart your system to finish.
Nov 23, 2007 | Computers & Internet
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
