Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
1993 harley fat boy will not start
When i attempt to start the bike, I do not get lights, clicks or anything. The battery has been tested and is good. The battery cables have been checked for tightness.
  • 4 Answers
Another common problem with this year FLSTF is the key switch, OEM has a mechanical switch that can fail, often you can go to the second setting and start the bike. Likely a new switch will fix issue
Posted on Apr 11, 2009
  • 216 Answers
Your bikes not getting the message thats its turned on. Check your start button, the wiring to the start button. If thats not it, the key switch/wiring.
Posted on Oct 17, 2008
How to start harley fat boy after long storage?
If it is carburetted you may have had fuel dry up and contaminate, plug carburetor jets etc. IN any case even if EFI the fuel is likely stale and you need to drain the fuel tank and put in fresh fuel. Did you have your mufflers plugged or did rodents get into them and build nests?? Is you battery dead. Re charge it to hold at least 12.6VDC and have it load tested. If you did not have it on a battery maintainer it is likely shot. Does it do anything, any lighting on, any click when you try to start it etc. POST a lot more information if you wantmore definitive assisatnce etc.
May 02, 2014 | 2005 Harley Davidson FLSTF - FLSTFI Fat...
Harley turns over once or twice then clicks
If the battery is good, all connections good, clean tight then sounds like the starter BUT you can test that also.
Apr 22, 2014 | 1993 Harley Davidson FLSTF Fat boy
Which fuse is the main fuse for a 2003 harley fatboy
Hi Anonymous, on a Softail remove seat and directly behind the battery is a black plastic box. The cover slides up and off revealing the starter relay and the system/fuel pump relay for you injected folks and the various assorted circuit fuses. Good luck and have nice day.
Apr 10, 2013 | 2003 Harley Davidson FLSTFI Fat Boy
Starter clicks and does not start
Does that sometimes welcome to the world of harley try putting it in 1st gear and give it a lil nudge because the compression I keeping the bike from starting , if that don't work check out your battery.
Dec 30, 2012 | 1993 Harley Davidson FLSTF Fat boy
Harley heritage 1994 starter relay repair
Hi Anonymous, when you are trying to diagnois anything in the starter circuit you must start with a fully charged battery of 12.5 volts or better and will pass a load test of 9 volts or better while cranking the engine over and the cable connections are clean and tight especially the negative cable at both ends. If you suspect a faulty starter relay just swap it with your horn, brake, or system/fuel pump relay, if the bike starts with no problems replace the bad relay. Good luck
Sep 28, 2012 | 1993 Harley Davidson FLSTF Fat boy
Can't get fat boy bike into neutral
Hi Jack7850, for more information about your question please visit the websites below. Good luck and have nice day.
How To Properly Adjust The Clutch Clutch Cable Harley Davidson
May 16, 2012 | 1993 Harley Davidson FLSTF Fat boy
Can i boost my motorcycle with my 4 cylinder car?
Yes you can but anytime you jump start your bike with either another vehicle or one of those "booster" battery chargers, you are risking damaging the electronics on your bike with a voltage spike. I'd prefer to use a slow charge battery charger overnight to build the battery up to the point where it will start the bike. If the battery is over a year old on your Fat Boy, take it out and have it load tested. The Softail bikes are extremely rough on batteries due to the heat and vibration they are subjected to inside the horseshoe oil tank.
Good Luck
Steve
Jul 31, 2011 | 1993 Harley Davidson FLSTF Fat boy
I have a 2005 harley davidson fatboy and my problem is that when i try to start the bike it clicks really loud ?, the volts on my battery are 12.80, but when i put the bike on the 200 amp engine start it...
You cannot go by a volt meter reading to tell whether your battery is good or not. The battery will read 12 volts and still not have enough current to light a decent bulb on your bike. This is because the volt meter is designed not to load the battery down. You starter puts a tremendous load on the battery. I'd also avoid using the "boost" or "jump start" position on the battery charger. You can get a voltage spike from those things and take out some expensive electronics on your bike. Take the battery out of the bike and take it somewhere that can "load test" the battery.
Good Luck
Steve
Jul 22, 2011 | 2001 Harley Davidson FLSTF - FLSTFI Fat...
I have a 1990 harley fatboy.recently it has been slow to start,now its to the point that it barely turns over and ends with the clicking sound. after several attempts i noticed the battery was getting...
You have a shorted cell in the battery. Go buy a new battery. When you're trying to start the bike, it's doing so on 10 volts or less. When the voltage drops, the amperage goes sky high. That's why the battery, the cables, and the starter motor are heating up.
Good Luck
Steve
May 22, 2010 | 1993 Harley Davidson FLSTF Fat boy
Lands Phones Logo
182 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
