Question about Pioneer PRO-700HD 64" Rear Projection Television
Pioneer Pro-700HD Mirror Broken
In moving the TV I needed to remove the back panel to get the unit through the door. The mirror fell and broke. Are mirrors still available and from whom.
  • BeerRef Dec 06, 2008
    Did you get this fixed yet? I have the same problem and the one website that I did find to purchase the mirror just changed the status from In Stock to Backordered the day after I clicked on the "buy" button. I am thinking I am going to have to get it custom cut and shipped to me.
  • tallbrit Dec 22, 2008
    Parts Store was the solution and shipped the mirror in 3 weeks. Pioneer wanted substantial shipping costs. Many thanks
Thanks for trying… partstore.com was actually the website that I originally tried ordering from. I feel lame for not including that tidbit of info on my original post because I didn't want to give that site a bad rap. After a bit more reasearch I discovered this site: http://www.highreflectivemirrors.com/ they carry the replacement for only $120 with free shipping and with only a few clicks I purchased it via PayPal. I am currently awaiting delivery and will post again if for some reason it doesn't work out.
Posted on Dec 18, 2008
How to replace passenger side power mirror on 1998 ford ranger XLT? Hit another vehicle and knocked mirror off.
On the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you'll need to manipulate the panel and disconnect the door handle linkage from the door handle and disconnect the wiring for your controls and mirror. Then you can remove the bolts securing the mirror housing onto the door. (I assume that part is still intact).
If it's just the mirror piece and backing that fell out of the housing, then on the inside of the housing, you should see two to four clips that secure the pivot point and two rods that control the pitch of the mirror. You may be able to just 'jam' the mirror backing back in. But the rods need to be secured to the back of the mirror backing in order to prevent the mirror from just falling or moving on its own
Oct 05, 2009 | 1998 Ford Ranger SuperCab
A basketball goal fell on my wifes 2003 pontiac montana and it broke the mirror on drivers side. how do i get the mirror off?
You gotta pull door panel find screws for arm rest, pull door hand off, you have push type retainers around panel need to get door panel tool from parts store or carefull use & bent screw driver to pry & pop off from there unplug harness connectors to panel & remove panel pull plastic dorn in front of door you should have 3 10mm head nuts on mirror studs good luck
Sep 07, 2009 | 2003 Pontiac Montana
Broken driver side mirror
you'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge. Then you can remove the cover adjacent to the mirror and remove the bolts and the mirror will pop right out
Aug 19, 2009 | 2005 Ford Focus
Replacement of the side reaerview mirror on a
so you don't need to change the housing, but just the panel the mirror sits on right? If you mean the entire unit, then you'll need to remove your door panel (screws are by the door handle, arm rest, under door and side of door) and remove the cover adjacent to your mirror to remove the bolts to remove the mirror.
If it's just the back and the mirror, you'll need to angle the mirror until you can see the release clips on the back of the panel that mounts it to the housing (Pivot Point)... be very careful as the clips can easily break....
Aug 10, 2009 | 2004 Dodge Ram 2500
Need to replace the broken outside right passenger mirror I have replacement
To repace the COMPLETE MIRROR UNIT, the inside door trim must be removed. Hope this helps
Apr 29, 2009 | Chevrolet Suburban 1500 Cars & Trucks
Mirror Broke, where can I find a new one?
Good Day, XBRMann;
Go to google and insert pioneer parts, that is the best place, going to the factory, the pio is a high end product, get what they produce and provide.
Good Luck & be careful this time, big IRISH.
Jul 15, 2008 | Pioneer PRO-610 58" Rear Projection...
Need to put in projector mirror in pioneer elite pro-510hd. the old one broke when i removed the back off. So I purchased a new one, now i need to know how to put it in.
the tech sent me the service manual and i was able to see the picture that had the clip on the front of the tv, so i removed the panel from the front. this allowed me to insert the mirror from the front.
Mar 19, 2008 | Pioneer Televison & Video
Replacing rear projection glass on Pioneer Pro-620HD
1)Pioneer entry is through the front,as you already found out.
The service manual will show you.......
2)Remove lower front speaker grill
3)Remove screen frame only
4)Choose left or right side to remove rail to access screens
5)CAREFULLY slide screens out to expose interior
6)Replace mirror and wipe off RGB lens caps
7)Reassemble .......................go slow,.............T.
Jan 25, 2008 | Pioneer PRO-620HD 58" Rear Projection...
Pioneer elite Projection TV PRO-98
Need to replace the convergence board. Cost through Pioneer is $350.
Nov 25, 2007 | Televison & Video
Pioneer Elite PRO 710HD 64" rear projection tv
You could get the old one and have them match it up. If not try www.pioneerservice.com
Sep 17, 2007 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer PRO-700HD 64" Rear Projection Television Logo
198 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
