I have audio, but no video, what's up? last night I was watching, and the picture went out, I truned off the TV, then restarted it...the picture came back. Today I tryed to turn it on and no picture, just audio. Help
  • 3 more comments
  • trip95051 Oct 17, 2008
    The type of TV is a Westinghouse Digital 2004 27" wide-format LCD-TV... I hope this info will help.
    The picture tries to come on when I turn the TV on, the first screen that always comes up... a blue screen with some info in the upper left hand corner, flashes on then off when I turn the TV back on.
    I think it must be the cable box not the TV... because of the screen that trys to come on... what do you think? ~Trip
    where do I find Kevin's solution? Trip95051
    Hi Kevin, thanks for your information. I tried to turn on the dvd player and it just keeps trying to scan the channels. I tried to put it on 3 but it just keeps scanning... this might be due to the fact that I called the cable comp. and they are trying to correct the problem via signals. They said that the signals are behind or running slow so I have to wait for 40 Min's to see if what they are doing brings back the picture. Trip95051
    Genius:
  • 1,847 Answers
S the audio coming from the TV's internal speakers, or from an external sound system? In the 169 series chassis, if the power supply caps or secondary rectifier are bad, or if the high voltage splitter has shorted inside, the set will not run and there will be no picture or sound from the TV. If the picture is completely black but the TV still has audio, press the menu button and see if the menu comes up on the screen. If the menu is there, check your cables on the back of the TV. If you are using a cable or satellite box, the box could be bad or the video wire could be bad or loose. If you do not get the on-screen menu, then I would guess that the solder joint next to the flyback transformer that sends filament (heater) voltage up to the picture tubes has cracked, or the low value resistor in the heater circuit has opened up. If that is the case, have the set serviced by a qualified tech familiar with the 169 series chassis.
Posted on Oct 17, 2008
  • Legin Varghese
    Legin Varghese Oct 17, 2008
    haa... Kevin here,
    if you think it is the cable box, try connecting your dvd or cd player and play something and check.
    let me know the details
    Thanks
    Kevin
Tv has audio but no picture. tv was working perfectly fine last night with audio and pic but now no picture
kindly check ur video cable if ur r useing audio/video cables for you tv
if not u need to check for ur tv tube
Jun 04, 2010 | Mitsubishi WT-46807 46" Rear Projection...
My Screen Went Black and i can only hear Audio.
Ur tv the LCD inverter board it dead.This board it help to get a backlight to ur LCD screen panel go through the Tuner board to produre a picture.Replaced this LCD inverter board u will get ur picture back.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter board for the replacement.It a long board in shape.
May 26, 2010 | Sanyo 42 in. LCD TV
My Philips standard tv picture went out
You may have a corrupt eeprom! Eventually the red light will come on with no audio or video!
Jun 17, 2009 | Philips 27MS4504 TV
Screen goes blank while watching
Couple of things:
1) When the picture "stops", does the standby light blink at all?
2) Can you post the model number please?
Some of these sets are known to have problems with the picture tube as it starts to age. There are some workarounds for this that can extend the life of the set for a short time. Without the model number though, I can't confirm that this set is in that catagory. Please supply responses to the issues above and we'll continue from there.
Thanks,
Dan
Sep 22, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Playing DVDs
try to use an Audio-Video(AV) cable(it has two or three wires,ask for it at the electrics shop),and push the button AV on your remote control.
May 24, 2008 | JVC AV-27230 27" TV
Sound no pic
Convergence ICs are STK392-110 you will need two of them they are available at the link I am posting and they give free instalation instructions with pics and free tech support so you can do the repair yourself.Heres the link.
http://servicemanuals.vstore.ca/
May 01, 2008 | Mitsubishi VS-50501 50" Rear Projection...
No picture, good sound
It's most likely the video board. The menu is injected at the output of the video stream right before the LCD panel. Having audio indicates the signals are getting from the inputs through the input switcher and audio boards. Unless you have electronics experience, I suggest having an experienced tech look at it.
Apr 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
DVD movies do not play
A blue screen means the TV is not receiving a video signal. Check all connections, then try another player, cable, etc. Also, check DVD and TV AV settings.
Dec 10, 2007 | Pioneer VSX-D912 Receiver
No picture on screen
MYGR8-YOU HAVE TO LIST BRAND NAME AND MODEL #. JOE TV
Nov 30, 2007 | Televison & Video
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Electro Med Services...
