Question about Panasonic Lands Phones
We have a Panasonic Model No KX-TA624 phone system for our home. Water leaked down the basement wall and got into the control panel. Now it won't power up. NEED HELP!
  • Panasonic Master
  • 2,460 Answers
Generally water damage is permanent. The best you can hope for is to open it up and inspect the printed circuit boards for signs of green corrosion. You may have just a blown fuse, or it could be something worse. In any case, it's usually better to replace with new than repair watered electronics.
Since Panasonic has a promotion on 824's, you can grab one for about 1/2 of what you paid for the 624. None of the expansion cards will fit in the 824, but if you only had the 3x8 system without door phone, you're good to go.
If you're in the Midwest United States, I have 2 824's on the shelf that can go out the door at competive prices.
Posted on Oct 17, 2008
How to active caller id for panasonic kx-t7730
It depends what telephone system the KX-T7730 is connected to. You should have a Panasonic box that says 'KX-TA624', 'KX-TEA308, 'KX-TES824' or similar somewhere.
Depending which Telephone System you have, it may just need programming or it may need an additional card (circuit board) installing. Panasonic KX TEA TES Telephone Systems Tiny Telecom
Nov 23, 2016 | Panasonic KX-T7730 Corded Phone
Unable to get an outside line / dial tone from my phone (KX-T7735-B) originally erroneously reported as a KX-T7335
If this is VOIP then the problem is with Comcast. The settings need to be set to recognize a two line phone. The long way around this is to find out the equipment they are using for switching from a digital to an analog signal and call the manufacturer for help.
Nov 14, 2013 | Panasonic Kx-ta624 Advanced Hybrid...
Unable to receive calls on Panasonic KX T624
There is a reset code for each handset which I believe is 790,
Jul 14, 2012 | Panasonic KX-TA1232/KX-TA624 phone
How can I get the music on hold to work on the Panasonic Advance Hybrid System KX-TA624?
On the cabinet, there is a jack marked EXT MUSIC. You plug in an audio source to the jack and then go into system programming and turn it on in program 111.
Feb 04, 2011 | Panasonic KX-TA1232/KX-TA624 phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
How do I program the phone to ring on an incoming call? The ringer is on.
The solution will depend on why the phone is not ringing. Do you have a good cable? (Can you get a dial tone and make outgoing phone calls?) If you don't have a dial tone, use another phone to check if the phone is the problem or if the jack is at fault.
Next is the phone forwarding calls or in the "do not disturb" mode.
If the problem is one of the above, which model of the Main Unit do you have, KX-TA624 or KX-TA1232?
If the unit is in the "do not disturb" mode, to cancel: pick up the handset, press Program then 0 followed by # with the TA624. For the other model, press Program followed by 0 . Then hang up the handset. For this the manual says press the FWD/DND button not the Program button. I'd check both.
To cancel Forwarding, except for Follow Me Forwarding, pick up the handset, press FWD/DND and then 0 and # (TA624) or 0 (TA1232) then hang up the handset. To cancel Follow Me Forwarding: pick up the handset, press FWD/DND then 8 followed by the extension number. Then press # for the TA624 and hang up; just hang up the handset for the TA-1232.
I hope this helps.
Sep 23, 2010 | Panasonic KX-T7730 Corded Phone
How do i delete speed dials on panasonic kx-t7730
since panasonic kx-t7730 does not have a delete option
we can however replace the number to a another number or a dummy number as per the model
KX-TA624 ....PRESS 2 *
KX-TA1232...PRESS 3 0
.... TYPE DESIRED NUMBER(eg: 0000)
This would replace the existing number
tell me if this works
Feb 24, 2010 | Panasonic KX-T7730 Corded Phone
Panasonic KX-TA1232, Setup and use
You can purchase a manual for about 10 dollars
Email your system/phone model number to sales at for further instructions.
Mar 31, 2009 | Panasonic KX-TA1232/KX-TA624 phone
Panasonic KX-TA624 system
ttry the manual first you probably don't have it
Aug 05, 2008 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
69 people viewed this question
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
