Question about Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator
Water in bottom of refrigerator
I have a F&P E521TRE 5 years old with freezer at top---there is water at bottom on right hand side of refrigerator section--Help please--Max.
WARNING-It is a condition for the reader to take full responsability in attempting repairs and author shall not be responsible or liable for any damages. If you have no knowledge or experience to do this repair do not attempt it.
I have had the same issue with Fisher Paykel Active Smart fridge . This can be due to:
1) 12Volt fan in freezer is not functioning.
To test: open freezer door, place a magnet on magnet switch at the bottom of freezer where door seals(white plastic rectangle) It takes few seconds for fan to rev up so move magnet slowly until switch on. You can also close door and listen carefully if fan starts if unsure.
If fan works go to 2) 3)as defrosting resistance can be the trouble
2)If fan does not work . UNPLUG FRIDGE at the main plug
Empty freezer and defrost it if too icy (do not use sharp objects). Then on back panel you will see two holes on top. Put two hook tool and pull down and slightly forward until top lip is free. This is hard to do but the plastic panel is very strong so you can apply a bit of force there!!!
On the second panel is the fan, check wires are not broken (common cause of failure). unplug fan, you can check fan on 12V battery (+red). Buy a new fan if faulty and put freezer panel back.
3) If fan OK and you see a lot of ice on condenser (do not remove it by force, just let it melt completely) then the resistance is the cause of you trouble. It is delicate to remove and make sure FRIDGE IS UNPLUGGED! Do not force anything as condenser is very fragile and if you damaged it, your fridge can go straight to the dump. You can test the resistance with an Ohm meter to make sure internal resistance is broken or not. If broken replace it and your fridge will be fixed. If not broken then trouble is either with on board computer (very seldom) or the thermistance.
Posted on Dec 18, 2008
Leaking water
The drain tube under the evaporator in the fridge is clogged. these can only be accessed by removing all the shelves and the light diffuser, then removing the back wall. even then, the hole is tiny and hard to put anything down into to clear the debris. I usually use a steamer to force steam down through to clear out the clog or ice. I get theses hand held steamers at walgreens for about $25. Might be cheaper than a service call to invest in one. Hope this helps.
Sep 07, 2013 | Sub-Zero 700TC Bottom Freezer Refrigerator
FRT16CRH Top Freezer Frigidaire Water leaking underneath refrigerator front bottom right hand side
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 04, 2010 | Frigidaire Refrigerators
Water collects at bottom/Ice forms in top
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Hotpoint HTS16HBR Top Freezer Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
Hi GE top freezer fridge - 5 years old( no ice
Well for one thing that unit was manufactured 10 years ago. But it sounds like the defrost drain is clogged and the water is running down the inside of the unit. The evaporator (not condenser) is on the bottom of the freezer compartment. The bottom panel of the freezer comes out. They are a bit of a pain to do, but can be done.
Jan 03, 2010 | GE GTS22KBP Top Freezer Refrigerator
Sub zero 550 (14 years old) has a small but steady leak onto floor from freezer compartment. Small amount of frost buildup on inside of door. Food is frozen and the door "appears" to seal we
Right hand side wall in the freezer - take a look- any frozen water or moisture? Need check a drain line, usually defrost heater inside the freezer wall getting bad and draining water just freezing inside of it.
May 10, 2009 | Sub-Zero Bottom Freezer Refrigerator
F&P Active Smart E521TRE Removing freezer back panel
My fridge (E440T but I believe the E522B is similar) had a broken fan wire and i had to pull off the rear panel and re-solder a wire. I created a document for others to follow that shows the rear panel removal if interested at http://www.accentis.com.au/downloads/misc/How I fixed my Fisher and Paykel Fridge Active Smart Fridge.pdf
Thanks to all postings on this site - it really helped a lot.
Nov 06, 2008 | Fisher and Paykel Active Smart® E522BR...
Amana XRSS287BB side by side fridge freezer (3 years old)
you may try hard restart by shuting the fridge off and unplugging it from the wall . plug in back in and after 5 min turn it back on . close both doors and wait one hour . check the temp. if the unit still will not respond calll the local woranty amana repairman only. hope this helps you
Jul 01, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Fisher and Paykel Active Smart® E522BR Stainless Steel Bottom Freezer Refrigerator Logo
751 people viewed this question
Top Fisher and Paykel Refrigerators Experts
Brian Coughlan
Charles T Nevin
Charles T Nevin
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
