New toshiba 42 inch lcd, picture has interferance on all channels, disconnecting and then reconecting the coax cable fixes it for 2 or 3 days ands the it does it again.??
  • jeastla Oct 16, 2008
    Thank You
  • 19,396 Answers
The problem is the coax cable, just replace it to get rid of the interferences. Buy a shielded coax cable, it will get rid of the interferences.
Posted on Oct 17, 2008
    Genius:
  • 1,847 Answers
Try playing your DVD or CD player and the picture quality.
Posted on Oct 16, 2008
  • Legin Varghese
    Legin Varghese Oct 16, 2008
    if the DVD plays fine then the issue seem to be with the incoming signal
    else
    there could be issue with the tuner card inside the TV. to check that a expert need to check it physically.
Picture has a horizontal line of faded picture that travels with text
Sounds like an electrical interference pattern called a hum bar. Should only happen when using coax cable, not HDMI or other digital source. You could buy a ferrite core and try that solution, try ebay or amazon, they're a couple bucks tops.
Apr 02, 2014 | Dynex DX-L42-10A 42 in. LCD TV
42 inch flat screen shows black screen with sound only no picture
That sounds like the backlight system or its powersupply has failed. If you can see an ghost like image when close and at an angle near the dge (depends on the light) then this confirms the backlight being the problem.
Repair cost should be about $100. You should be able to get this fixed under warrenty if you have any. If not get repair estimates before doing anything. It should be worth fixing but it never hurts to know if it is getting close to what a new replacment tv is worth.
Apr 23, 2010 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
HSL4229HDIP 42 inch LCD intermittent lip sync problem
Hi
Try Buying a aerial with a booster, u can purchase a inline booster at dicksmith or most large electrical stores.
kinds regards Kyle
u can reach me at
kyle-stelzer@hotmail.com
Apr 20, 2009 | Hisense Televison & Video
Cable box remote doesn't work when tv is turned on.
I am having this same problem with our Mitsubishi LCD Flat Panel TV, Model LT-46246 ans our Scientific Atlanta remote cable box, same model as yours. We cannot use the remote at all to change the channel. I called Mitsubishi and they said they have never heard of this. I find this incredibly hard to believe. Time Warner, our cable provider says that it is not the box because it works when not hooked up to the TV. What a pain. I would love to hear if anyone else is having this problem or has a fix for it.
Mar 25, 2009 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Cannot optimize picture width on new flat screen HD
On your cable box remote press the hd zoom button. I have comcast cable box and it worked for me.
Dec 25, 2008 | Toshiba REGZA 42 in. Flat-Panel LCD HDTV
Vizio 42'' LCD having intermittent fuzzy screen on stdrd channels
you might have an overheating problem- make sure you have adequate ventilation around your tv
Nov 25, 2008 | Vizio GV42L 42 in. LCD Television
Toshiba 37 inch TV
do you have the satellite hooked up through the coax cable if so that could be the problem you will have to manually set the settings with the remote. always make sure you have only one thing hooked up at a time. if you have cable and satellite dont hook up both it makes the picture lousy see the owners manual i think its page 58 or somewhere close to there.some times if both are hooked up it will not work at all.
Dec 10, 2007 | Toshiba 37HL67 37 in. LCD HDTV
Cable Card Problems Toshiba 52HM95 model
a good rule of thumb with cable cards is,,if the card doesn't work try a second one,,if that one won't work try a third,,and so on..most of the time it is not the set it is the card that won't work correctly..many television companies have left the cable card slot out of the currect line because of this..a cable box is more reliable
Nov 26, 2007 | Toshiba 42HP66 42 in. LCD Television
Moving line through plasma and LCD TV's
This is a very common Ground loop problem. The quick cure is to put a 2 prong to 3 prong adapter on the plugs which effectivly removes the ground from the circuit and stops your lines. Have fixed over a hundred TV's since the 60's that way.
Oct 04, 2007 | Vizio GV42L 42 in. LCD Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
