Question about Sharp AR-M205 Copier
Toner cartridge IC
Is there possibilty repairing it??????????
  • mar-c Apr 25, 2009
    just for emergency ,SOMEONE TOLD ME TRY
    * I CA I
    ENTER 80 copy 1 copy
    but this wont stay long
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 115 Answers
Gavinsx is correct, Frcs68 is definetly wrong.. if it is the chip which sometimes it is.. you can replace it. that is the only thing you can relpace on the toner cartridge. another thing that you can possibly try is clean the contacts of the chip both inside the machine as well as the toner cartridge. a real quick gentle blast of air and a wipe with a lint free cloth helps sometimes.
Posted on Oct 24, 2008
    Problem Solver:
  • 12 Answers
Hi Marc-c,
There is unfortunately no way of repairing the chip.
I assume that the cartridge has been re-filled and was run until empty.
The only possible solution is for you to purchase a new cartridge and then monitor the toner supply (press and hold in the light exposure key for 5 to 10 seconds, the copy quantity display will change to "--"and the red lights on the panel will flash. then press and hold in the zoom % key again for about 5-10 seconds the display will then show the approximate toner percentage remaining. When this display then shows "LO" remove that cartridge, and detach the chip at the back of the container (2 screws) replace this chip onto the cartridge that you are now struggling with and continue copying.
NB. to get out of the toner % display just press the light exposure key again.This programme that I have explained is known as the "User Settings" programme and you can change the default settings of the machine including the auditing mode in this section.
Posted on Oct 17, 2008
    Genius:
  • 1,605 Answers
No you can't repair the toner cartiridge or any of the toner cartridge (I have try, believe me, it don't work). the new toner cartridge is around $40 to $70.
My konica minolta 130 f is asking me to replace toner. I have opened it, refilled but is still asking me to replace toner
what you need to do is to change the toner cartridge. Refilling will not reset the toner IC inside the cartridge so by so doing, no notable change is witnessed.
Jun 12, 2011 | Konica Minolta Bizhub 362 Copier
Change the toner cartridge message doesn't go away on AR-M237
plese check you have changed the same partno toner or not. if its ok you have problem in connector wich hold the toner cartrdge ic
Feb 10, 2010 | Sharp AR-M237 Digital Copier
My sharp ar5316e show f2 04 solve this
clear the memory of the machine, change the destination of the toner or fixe in a new toner crum or also known as toner sensor
Jul 01, 2009 | Sharp AR-5316 Advanced Digital Imager...
I CHANGE THE CARTRIDGE OF THE COPIER AND TURN ON IT. SO THE COPIER DISPLAY MESSAGE 2F.
i think the error your actually getting is F2. this error pertains to toner cartridge chip error. it's that little chip on at the end of the cartridge.you'll need to have that replaced.
Mar 25, 2009 | Sharp AR-M160 Laser Printer
Having a problem with new toner in a HP6L laser printer
If the problem was not there before you replaced the cartridge then I suggest that the toner cartridge is at fault. If you touch the blue drum in the toner cartridge ( under the flap ) with your fingers then that can also cause a smear.
Mar 06, 2009 | Datacard Group Cleaning Card (for Select,...
Need Override for Low Toner Message Minolta QMS 2300
It depends on the model. The 2300 series using a mechanical mirror on the cartridge itself. A tab needs to be moved the mirror slid back to home. The 2400 series & newer uses an IC that you need to replace. when you buy your toner to refill the cartridge make sure you get the IC with it. Russell
Aug 21, 2008 | Minolta magicolor 2350 Laser Printer
Sharp AR-M205 Copier Logo
89 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
