Question about IBM ThinkPad i1200 1161 Notebook
Have no idea how to add memory to my laptop
I purchased more memory for my laptop. I have absolutely no idea where to add it. I found the slot that already has a memory chip inside. I know this probably sounds really stupid to you, but I thought I was adding more memory on, do I have to remove this chip or is there somewhere else I install the new one? I am pretty clueless when it comes to this; however, I want to make sure I do it right and don't do anything to harm my laptop. I'm obviously not a tech-e so I will need directions in as basic of a format as you can provide for me.
I truly appreciate your help and advice.
Kelly
  • shenjee27903 Mar 08, 2009
    hi !
    my IBM think pad 1161 screen display reamnains so dim that it is difficult to see it , but it is working properly , aftter ssaveral attemts of restart the display becomes oky ,
    can u please help me out of it?
    thanks
Mersi
Posted on Mar 08, 2009
  • IBM Master
  • 4,338 Answers
Your laptop only has one slot for memory. If you have a Dimm in the slot , that is all you can have. If it is a 128 MB. Dimm. If it is less than 128 MB,You can add 128 MB memory.
Here is a link for 128 MB:
http://www.crucial.com/search/searchresults.aspx?keywords=.thinkpad%20I%20series%201200%20Thinkpad%20I%20series%201200%201161
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 17, 2008
Does my laptop (Dell latitude d600) have a memory card slot and where is it?
If you are talking about a slot to Add RAM yes, there is.....there is a little panel on the bottom of the laptop that has a small screw you can remove and add memory.
If you are referring to a memory card READER (like a slot to read compact flash or camera SD cards) no, I don't believe a D600 has one of those.
Mar 10, 2011 | Computers & Internet
I purchased 1 g of memory to add to my laptop. I am not able to do anything with the laptop due to the lack of memory. I can't afford to have someone add the memory and must do it myself. What can you do...
It's easy to add the memory yourself. Memory has a small compartment in the middle, you only have to unscew one screw to have access to it, the screw circled in the image below. When you put the memory in you have to put it to a 45 degree angle and press it down until it clicks in.
Then you close the cover and start the laptop. If you get a beep it means the momery is not installed properly.
Jan 16, 2011 | Toshiba Satellite A135-S2276 Notebook
How do yo get to the memory and can I add 1GB to the existing1!GB or do I have to purchase a 2 GB memory...thanks
Most laptops have 2 memory slots, if you have 1 Gb of RAM using two 512 Mb RAM then you need to replace them with two 1 Gb RAM modules. If you have one RAM module 1 Gb then you only need to add another 1 Gb RAM module. Try to use the same make and speed RAM.
Aug 19, 2010 | Acer Aspire One A150-1006 Notebook
Toshiba a60 on board memory faulty
i found this page on that problem.
http://www.laptoprepair101.com/laptop/2007/04/27/toshiba-satellite-a60-a65-problems/
hope it helps
Aug 18, 2009 | Toshiba Satellite A60 Notebook
I want to add RAM, but I haven't yet found the slots. Can someone tell me where they are?
The slot will be on the bottom (the part of the laptop that sits on the desk). Remove the screw(s) that are holding the cover and you will see the existing RAM (usually a green module about 2 inches in length).
Apr 13, 2009 | Computers & Internet
Memory problem
you may have purchased a memory stick that requires more speed than your memory block can give. the speed for this lap top should be around 455-500 MHz on the memory block. if the memory stick requires more than that, its not going to work.
Mar 11, 2009 | Gateway M305CRV Notebook
Inspiron 6400 notebook
There are two slots for memory on that laptop and it will take a maximum of 2GB of RAM. The memory type is 1.8-V SODIMM DDR-2.
The cover ont he bottom if the laptop is easy to access and add more memory.
Dec 31, 2008 | Dell Inspiron 6400 Notebook
How do I download pic from a memory stick
If the memory stick is the right one for the media slot on your laptop, you should be able to plug it in the slot. The operating system will see the memory stick. Then you can drag and drop the pictures to the My Pictures folder.
If it is different from the slot on your laptop. You can purchase a card reader for about $20.
Please remember to rate all users who assist you for free :)
Oct 01, 2008 | HP Pavilion dv6000z Notebook
Don't know where to install my new memory on my laptop
Heres a link:http://www.notebooks-drivers.com/acer-notebooks/download-manual-for-acer-aspire-5220.html for the manual of your laptop, memory slots are usually found at the bottom, just download the manual and theres an instructions on how to add or replace your memory on it. good luck
Feb 26, 2008 | Computers & Internet
Install 2 RAM modules of 1 GB
The other memory may be soldered in. Check your manual and see if it has any information on additional memory. If you only have on expansion slot you may have to buy larger memory chips. like instead of 2 chips 1 gig each you may have to purchase a 2 gig chip. Computer companies usually make the chip installation easy to get to on lap tops.
Jan 14, 2008 | HP Compaq nx6310 Notebook
IBM ThinkPad i1200 1161 Notebook Logo
153 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
