Question about Toshiba Satellite A135-S4527 Notebook
Error coe 31094D-34-00000000
Got This error when trying to burn an iso image to disk using Toshiba
Toshiba error code 31094D-34-00000000
  • Patrick Kam May 11, 2010
    Have you tried some CD Burning freewares to burn the ISO? If same error, please try reinstall the software drivers.
    Please also state what OS it's running and name of the application you used.
The error code it meens that you have a wrong image file size
try another iso, or download again the file
Posted on Dec 27, 2008
I am having issues burning dvd or blue ray from my mac with adobe premiere elements. It is an external burner connected via USB works fine with final cut but has error message with elements. Says " device...
Try burning an iso image file instead from the program, then you can use the built in mac software to burn that disk image file to a disc. Sometimes in video editing there is a problem with the process of compiling the video to a disk. Try a simple very short project with a dvd-rw (reusable) disc to see if it still gives the error.
Apr 11, 2014 | ASUS Computers & Internet
Error 0x80070057
You can use your original Windows 7 Ultimate installation DVD as a Recovery Disk if you have one, alternatively, you can download a copy of an official Microsoft Windows 7 Ultimate 64bit DVD .ISO disk image from the following URL.
http://msft.digitalrivercontent.net/win/X17-24395.iso
Note: The above download image is 3GB in size and may take some time to complete depending on the speed of your internet connection.
For those looking for download links for other versions of Windows 7 these links were published on the AskVG web site a little while back and include .ISO images inntegrated with Service Pack 1.
If you are having problems when burning an ISO image to DVD media that is giving the 0x80070057 error, then you may have a device driver issue as that seems to be a common cause of such errors.
You could try using a free third-party CD/DVD burning utility such as CDBurnerXP which works fine on Windows 7, Vista or XP.
Dec 24, 2011 | Microsoft Windows 7 Ultimate for PC
Hi, I have a problem with my toshiba, I have tryed to burn a disc but the laptop does not let me do it, and shows me a error 3109A0-34- 0000000 please helpme what do i can do for fix the problem?
It seems that you are using Toshiba Disc Creator.
The error means that the data that you want to burn on the disc is larger than the capacity of the disc (either CD or DVD) try to reduce the number of items you are trying to burn, and if you are trying to burn an ISO image then it is larger than the disc you have in the drive
Sep 03, 2011 | Computers & Internet
I HAVE TOSHIBA LAPTOP SATELLITE A665 AND I TRY RECOVERY BUT STOP ON 3RD RECOVERY DISC WITH THIS ERROR 10-FA12-045D HOW TO FIX THIS PROBLEM?
This error code with Toshiba usually indicates a bad hard drive, bad memory, or bad recovery discs. Download this drive fitness test HERE. It is an ISO image that you can dowload on another computer, burn the image to disc, and run it on your laptop to test your hard drive (bootable disk). You can download memtest 86 HERE in ISO form to test your system memory (bootable disk). I think you will find your answer with one of these tools.
Apr 22, 2011 | Computers & Internet
How to fix this error "BOOTMGR IS MISSING". Every-time I reboot my laptop, it always say to press CTR ALT DLT to restart. I did that, and seems to me that this error is keep coming...
Try this:
1. First you need Vista Recovery Disk .iso file. Can be downloaded here: [redacted]
2. Then you probably need image burning program. I prefer CD Burner XP >http://cdburnerxp.se/download.php
3. When you have installed CD Burner XP, start program, choose "Burn ISO image" and browse to Vista Recovery Disk.iso file.
4. When program has finished to burn ISO image, put CD into PC with "boot mgr is missing" problem.
5. Re-start PC, press F2 2-3 times, go into BIOS Setup Utility, choose Boot, move CD/DVD unit up to the first line with F6. Press F10 , choose YES.
6. Click this link to find out what to press when PC boots from CD:http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
If this helps you, please rate. Thank you
Jan 20, 2011 | Acer Aspire 1690 Notebook
Error : 10-FC12-0570 when i try to reinstall with the cds
Error 10-FC12-0570 on Toshiba satellite This error message means that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive.
The problem could be with the disc, the CD/DVD drive or the hard drive.
Solution:
Try copying the second disc using another system. If it's impossible: order for a new disc. If you can copy it, try using the copy to do the restore.
Try using a third party disk checker to verify the problem, is or is not, with the hard drive.
The best way would be to load the Windonws Vista discs, format the pc and reinstall.
(Vista Recovery Boot Cd is available free by Microsoft). Download it burn the Image .iso and run that disc. That disc will not restore the OS: run diagnostics on the HDD; once disk check is completed and repaired, proceed with the Recovery disks that you have.
Nov 22, 2010 | Toshiba Satellite A215-S7422 Notebook
Firmware
Had the same problem at first. The disk must be burned using an "ISO Image"....if you're using Windows Vista, it uses a different format. Google "Free ISO Image Burner" and download one of the free ISO image burners, if you don't have one. Burn the firmware file you downloaded to a CD as an ISO Image, and it should work.
Jan 10, 2010 | Panasonic SC-BT100 Theater System
I am coming up with error 10-fc12-0570 on the toshiba satellite a215-s7422 i used the both recovery disk and this was the error code
The error message is telling you that the recovery utility was not able to read the data from the disc correctly, or wasn't able to write it to the hard drive. The problem could be with the disc, the CD/DVD drive or the hard drive.
but usually error 10-FC12-0570 is pertaining to a bad HDD or memory
First, try copying the second disc using another system. If you can't copy it, order replacements from Toshiba Customer Assistance: 1-800-457-7777. If you can copy it, try using the copy to do the restore.
You can try using a third party disk checker to verify the problem is or is not with the hard drive. But since the system is under warranty, you're going to have to arrange to have it repaired anyhow, so it may not be worth the effort to verify whether it's the hard drive or CD/DVD drive. It's probably not the CD/DVD drive since you got all the way through the first disc. Contact a Premier (not regular) ASP for service from here: http://pcrepair.toshiba.com
The best way would be to load the Win Vista discs n format the pc...and reinstall...iam telling this because u have a tried the recovery disk as well....
I know most users will not have the Vista CD with you but the Vista Recovery Boot Cd is available free by Microsoft just google...
Download it burn the Image .iso and run that disc. Since that disc will not restore the OS all it does it lets u run diagnostics on ur HDD and allows u to install the OS. Once disk check is completed and repaired, proceed with the Recovery disks that you have.
thank you
have a nice day
Jul 08, 2009 | Toshiba Satellite A215-S7422 Notebook
ERROR INSTALLING PREINST3.SWM
The work around for this is to take the Toshiba restore disk and do a dvd copy disk to disk and use the copies to restore the computer. I had the same problem and the disk would not read correctly. I called Toshiba and they were no help. I saw a post on another web log and they suggested copying the origianl restore disks. They copies ran without a problem.
Jul 07, 2008 | Computers & Internet
Toshiba Satellite A135-S4527 Notebook Logo
2,285 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
