Question about Yahoo Messenger
Yahoo voice connects and stays on a few seconds and says error connecting back to server
    New Friend:
  • 109 Answers
Pls check with your internet service provider may be has problem with the rate of your bandwith installing the new yahoo beta intant messenger.
Posted on Oct 17, 2008
[CS Raw] Connecting to connection server port '5050'... [FAILED] *** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0203' ***
Solve this problem
Checking connection servers...
*** 'COMPONENT_TYPE_YCP_EX' YCP EX Error: ('FND.0210', 0, 0) ***
[CS Raw] Connecting to connection server port '80'... [PASSED]
[CS Raw] Sending port check command... [FAILED]
*** 'COMPONENT_TYPE_YCP' YCPError: 'FND.0000' ***
[CS Raw] Connecting to connection server port '23'... [FAILED]
[CS Raw] FAILED
*** 'COMPONENT_TYPE_YCP' YCPError: 'PortSelector::AllPortsFailed' ***
Dec 08, 2010 | Yahoo Messenger
Yahoo error 81003016
Open up your Internet Explorer
  • Click Tools>>>Internet option>>>Connection tab
  • Under Dial-up and Virtual Private Network setting
  • Double click your current internet connection that you are using now
  • Make sure that under Proxy Server, the 'Use a proxy server for this connection' is UNCHECKED
  • Now back to connection tab
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again
Sep 18, 2010 | Yahoo Messenger
Yahoo VC Error message
reinstall your ym...best version of mayb 8 - 9...after uninstall your ym, use registry fix like tuneup utilities for fix any error on your system
Apr 27, 2010 | Yahoo Messenger
Help, my voice call in Yahoo messenger suddenly will not connect to the server. I have been making calls from PC to PC for many months and lastnight it just stopped letting me connect to my friend. I get a...
As you said you were able to call or using the voice call from yahoo messenger for 2 months I understand that your IP( Internet Protocol) address is banned from yahoo voice server.
To fix this issue, If you are connected through a personal modem restart your modem in order to change the IP.
Or if you using Fix (static)IP address from your ISP/Network vendor ...contact them to change the IP or try use VPN(Virtual Private Network) connection to authenticate/connect with different address.
Hope that will help you.
Thanks for joining us.
Good luck
Nov 21, 2009 | Yahoo Messenger
Yahoo error 81003004
sometime yahoo has a glitch or two from time to time
Jul 31, 2009 | Yahoo Messenger
Why i see error number 81003005 in yahoo messenger?
This message appear probably because of your computer proxy software by default change your connection properties.
Solution is
Open you internet explorer
  • click tools>>>Internet option>>>connection tap
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ isUNCHECKED
  • Click LAN setting
  • Click OK>>OK
  • Try to logging to your Yahoo messsenger again.
Jul 25, 2009 | Yahoo Messenger
Error 81003005
Have yo ever been able to connect just that this error is usually to do with a server side issue on the yahoo side,If It does not correct Itself then you could try this...
Yahoo uses by default your Internet explorer settings so just check these and try to connect again.
  • Make sure that under Proxy Server, the ‘Use a proxy server for this connection’ is UNCHECKED
  • Click LAN setting
  • Click OK>>OK
Good luck
Richard
Apr 29, 2009 | Yahoo Messenger
Pc to pc dalls
Usually you get the message: connecting to voice server, for successful connection you should have an high speed internet connection, even then voice server(of yahoo.,, or any other....) have this problem so you have to bare until you get voice connection and sometimes voice quality may be dull.......
Dec 26, 2008 | Yahoo Messenger
I dont get voice Chat available on Yahoo, where as all Ok
when i connect the web cam on yahoo massanger the message come error occure while connecting to the server
Oct 07, 2008 | Yahoo YHT-630 System
Webcam not connecting to yahoo messenger
!st, let me explain the problem more clearer, then I'll explain the solution.
Problem) My camera worked fine. Even when logging on to Yahoo messenger, i could still veiw myself when chatting. But when I clicked on the "broadcast" button, the "idle" status would change to "connecting" for a few seconds. Then the the following message would pop up, " The server is busy, Please close this window & try again in a few minutes".
Solution) In Yahoo messenger, click on "Messenger", scroll down & click on "preferences". In Category:, click on "connection". Make sure that "no proxies" is selected.
Jul 01, 2008 | Labtec 961307-0914 Webcam
Yahoo Messenger Logo
60 people viewed this question
Top Yahoo Computers & Internet Experts
micky dee
Mike
fixrfast
Level 1 Expert
Are you a Yahoo Computer and Internet Expert? Answer questions, earn points and help others
