Question about PC Chips M909G Motherboard
Sistem crash ram is not compatible whit bios need an upgrade
If you know what motherboard you have find the manual on the internet and you will be able to see exactly waht kind or ram you can get (i'd suggest Kingston)
Posted on Feb 25, 2009
Microsoft is unable to determine the exact cause of this error. However, this problem was most likely caused by an error in your computer?s random access memory (RAM). RAM is the main internal storage area...
What are you doing when this happens? It sounds like you will have to get a BIOS upgrade weather you like it or not. Visit the motherboard manufacturer's website and obtain the BIOS update from there.
Dec 29, 2009 | Microsoft Windows XP Professional for PC
Computer does not see all ram. I have 2 of the same 512mb ram sticks it only sees one 512. If I only put in on at a time each one works but not both together. It does not show up in post or windows xp sp2...
u do need to remember that when you use 2 ram "sticks": 1. they CANNOT BE putted in slots directly next to each other. leave slot between them free. 2.they need to be exact same frequency and type [ddr1 or 2 or 3] and they both must have or not error connection on as if bios program upgrade utility is damaged do not try to upgrade bios as u may damage your motherboard beafore u try with 1gb stick refer to otherboard manual for ddr type and momory frequency
Dec 06, 2009 | Computers & Internet
Problem whit media player not responds acer power 4300 pentium III RAM 316 XP PROFESIONAL SP3 Media Player 11 30 GB HDD
you need to wait for the system to response.because media player 11 is designed for vista,but it also compatible with xp.but it works good only if u have 512 mb ram as minimum.so it is advisable to upgrade your ram.
Aug 17, 2009 | AcerPower 4300 PC Desktop
Problems whit my acer aspire 2920 display
Check your memory card. Reseat or clean its edge connector with soft eraser.Do this after you shut it down properly , battery disconnected, and no any other power source is connected.
That is the first thing to suspect. Or try it also with a spare good ram card.
May 09, 2009 | Computers & Internet
Hard crash, Need To Replace BIOS
If you're not good at sodering I'd suggest replacing the whole motherboard. Otherwise go Here <<< for a guide on the bios, and how to replace it.
Apr 27, 2009 | NEC PowerMate eco PC Desktop
Bios Failed During Bios Upgrade
pls check the RAM try re installing the RAM or try replacing them , may be it is a co incedent u thought it as a bios update failure pls check and reply back with mother board complete model number and manufacturer with processor details
and pls rate me if its helpful
Feb 24, 2009 | Gigabyte GA-K8NSC-939 Motherboard
Acer Aspire Memory problem
The read speed of your new memory is not compatible with your motherboard. It is a higher rate than allowed. The reason why it works when you have one of your old chips installed is because your PC will automatically drop the higher rate chip down to the one that is working. The reason it does not drop both new chips down to a suitable rate is because it has nothing to guide it like your compatible chip does. Always check the MHz on RAM chips and compare that with the acceptable rates listed on your motherboard specs. The good news is you can probably sell those chips and have money left over when you find upgraded compatible memory that is sure to be cheaper since it is slower.
Apr 11, 2017 | Acer Aspire T650 (AST650UC3601) PC Desktop
Memory upgrade
check the compatibility of the ram.. also,, check the maximum upgradeable memory of your notebook..
Feb 14, 2008 | Toshiba Satellite A105-S44284 Notebook
Asus Mobo Will Not Boot After Memory Upgrade
not right ram gotta use samusng low density sum mobo so picky
Jan 20, 2008 | ASUS P4PE-X Motherboard
TOTAL UPGRADE
>Can I upgrade the processor as well? Pentium 3 is compatible and what is the maximum MHz? Maximum CPU for GA-6BXE is Celeron-1400 (Tualatin core, with PowerLeap Adapter: http://www.powerleap.ca/Products/PL-370T.htm ...and patched bios by BIOS Patcher: http://forum.rom.by/topic5071.html&highlight=6BXE (last official BIOS don`t support Tualatin CPU-s) >A bigger HD will be compatible? With last F3a-version or patched bios - upto 128Gb. >The BIOS can aslo be upgraded? For max CPU / HDD - must be upgraded.
Sep 23, 2006 | Gigabyte Slot 1 GA-6BXE Motherboard
PC Chips M909G Motherboard Logo
141 people viewed this question
Top PC Chips Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
