Question about Nikon N75 35mm SLR Camera
Replaced the batteries
I replaced the batteries and I still can't see through the lens. It shows that the battery is full. I am getting an ERR messages when I look through the lens in the lower left hand corner that is flashing.
  • Anonymous Nov 09, 2008
    I have the same problem did you ever find a fix?
  • hrodbehrt Dec 06, 2008
    I have the same exact problem. I got my camera at a second hand store though.
    Scholar:
  • 95 Answers
This is usually a lens compatibility issue. You either have an older generation lens that is not compatible, or one where the lens is not set to its minimum aperture setting (the biggest number - ie 22).
Here's a link to the User Guide:
ftp://ZUAB14RT:F3NET50W@ftp.nikon-euro.com/Manuals/M1GTMV8H/F75_En_02.pdf
The F65 is the same as the N65
Posted on Dec 10, 2008
Error Bosch DLR130 distance measurer
Same problem Err and --- on display. The front lens had become misaligned. Take off front rubber boot, clean lens and replace lens exactly in glue pattern on unit with rounded side facing out. Then holding unit with seated lens upright push rubber boot slowly back on. Very hard at first but push as much in by hand then use a narrow blunt point like the back of a screwdriver handle to press around the edge working it in with slow continuous pressure a quarter inch at a time. It will reseat just take your time and work the high spots. This time was not the batteries, works like new.
May 23, 2013 | Measuring Tools & Sensors
Canon 400D,Error 99 keeps coming up,have replaced battery pack,even recharged batteries,stillbeing told to"replced battery pack".Help...
Welcome to Fixya
Err 99 could means several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Have a good one!
Feb 06, 2011 | Canon EOS 400D / Rebel XTi Digital Camera...
Canon Rebel XT wont fully come on
Hi
Error 99 is usually a lense error and gives the only real clue as to what is going on with your camera. You can try this simple fix which comes straight from Canon. Follow the steps to help isolate the issue. Note the fact that you are currently not getting the Error 99 is probably a good sign according to the troubleshoot.
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
Hope this helps. Please do rate my answer. Thanks.
Aug 09, 2009 | Canon Rebel XT / EOS 350D Digital Camera
When I try to take a picture with my New Canon 450d/Sigma 70-300
check your card,change with new cf.That might fix problem i had the same issue and it was my card.
Mar 29, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Err CF then Err 99 - Canon Rebel XT / Hitachi 4GB Mircodrive
Not all CF cards are created equally, so yes, it could be your batch of cards. To determine if the error is CF related, and not anything else, try the following steps which are used to diagnose err 99's
To isolate the cause of the issue, do the following: -
4. Insert only a fully charged battery, and turn on the camera.
Does the “ERR 99′ message appear? If so, the camera may be faulty and requires a service. If it does not, then: -
Does the “ERR 99′ message appear? If so, then the CF card is faulty. Try a different card. If the message does not appear: -
2. Clean the gold contacts on the lens by GENTLY rubbing them with a pencil eraser or soft cloth. Keeping the camera face pointing down, also clean the gold contacts on the camera, being careful that you do not let any debris fall into the camera body.
If the “ERR 99′ message only appears when one particular lens is attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the camera is faulty and should be serviced.
Feb 13, 2009 | Canon EOS 30D Body Only Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Reset security code on AU Falcon
turn key to <acc> turn radio will blink err. leave on for at least half hour.err will be replaced by enter code.
Mar 25, 2008 | Radio Communications
Err CF
Observe the connector inside camera, using a flashlight. If there is a bent pin take the camera to service immediately. Don't turn it on any more as we did in one similar case - creating a short circuit that damaged the camera electronics and voided the warranty.
If no visible problems, remove battery and leave it out overnight.
Jan 15, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Nikon N75 35mm SLR Camera Logo
134 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Greg Cann
Greg Cann
Are you a Nikon Photography Expert? Answer questions, earn points and help others
