We are in z motor home and have a 12volt zien tv but recently till it gets warmed up we loose the picture to strips of all colours. we still have sound it goes perfectly once it is warm. thanks nancy
  • nncytierney Oct 17, 2008
    the tv is 3yrs old
    it is a xien 12 volt flat screen three in one, it has cd, dvd,mp3
  • 2,334 Answers
What is the model of your TV?
How old is it?
Posted on Oct 16, 2008
  • Jaime Hernandez Oct 17, 2008
    It looks like your TV might have dry solder joints since it works well after warming up. If your TV is less then 3 years old; i would suggest to contact the manufacturers to get fix under warranty. These brand has 3 years warranty as state it in their website.
    Click here to get the contact information.
    Genius:
  • 1,847 Answers
Repair involves either/both replacement of the flyback transformer or horizontal output transistors.
  • Legin Varghese
    Legin Varghese Oct 16, 2008
    This could be also the with any loose connection, for this the tv have to be physically checked by a technical person.
  • 19,396 Answers
There are a number of faults that can cause similar probblems, one of the components on the unit is defective, and when it warms up you lose picture.
The TV must be inspected by a technician and the component replaced.
If you decide to call technical support , you can use the phone number printed on the owner manual.
  • Ginko
    Ginko Oct 16, 2008
    If you use an external receiver, for example a sat box, check alsothe cables connecting to te tv.
    Test the TV with a regular antenna only, if you do not lose color anymore, then the problem is either with cables or receiver box.
Hi my 12volt 7amp 60psi pump motor runs but dosnt pump it is not blocked Thank you Doug.
pump gears have failed --stripped teeth or loose on shaft
common problem if run with out fuel
May 05, 2017 | Cars & Trucks
I have a sceptreflat screen hdtv that display a red picture Always
go into settings and check your hue settings.
This setting controls your color mix ratio
of primary colors red, blue and yellow.
Apr 22, 2017 | Televison & Video
I have sony bravia KDL-40BX420 TV ,purchased 03 years back.recently got a problem with pictures & colour.It shows pictures with shadow & colours are blured.please give your feedback
I would check the menu settings and reset everything to default. if there are calibration tests in the menu, use them. Try more than one source for video.
May 22, 2014 | Sony BRAVIA KDL-40BX420 40" 1080p 1920 x...
Mitsubishi tv flickering
the problem you are having is the colour wheel. it spins to correct the colour on the screen when it fails you get wrong colours and flicker... the motor on it fails after time. and will need replacing.
Mar 05, 2014 | Televison & Video
Vertical colour bars
The problem is in the LCD controller board is overheated because the power supply unit is at the bottomof the TV and the heat rises upward to the vent on the top of the TV. You can verify that is hest problrm by running TV with the back removed and have a small fan blowing on the top secdtion of the TV where the LCD controller is. This how I fixed my scrambled picture after warm up (I added heat sinks to the IC on the LCD controller board) : http://s807.photobucket.com/albums/yy352/budm/LTV-32W3HD/
You can try it if the board was not badly damaged already by the heat. My has been running great for over a month now.
Feb 04, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Sony BRAVIA KDL-40W4000
I've been looking into this myself as I've also recently purchased the KDL-40W4000. I was watching a murky old film and was getting a bit of sludgy ghosting but found that by reducing the contrast to 25, setting the backlight on low, colour on neutral and the brightness about 40-60 (and taking ALL advanced noise functions off), this reduced the ghosting considerably.
BUT, this is quite a cool and dark image. If you watch standard TV and films mainly, a variation of the Cinema setting is probably the best overall setting i.e.
backlight: min
contrast: 79
brightness: 50
colour: 53
colour temp: Warm 2 (although Warm 1 is less yellow and still fine)
sharpness: min
noise reduction: off
mpeg nr: off
contrast enhancer: off
colour space: standard
Ben, UK
Oct 11, 2008 | Televison & Video
Television picture fault
sounds like an issue with the tube but you probably wont be able to fix it on your own, i would take it by an tv repair shop, they will determine if its repairable
Aug 06, 2008 | Sony Televison & Video
Samsung tv settings
it depends on what your using it for, adjust colour tones to what you think looks natural, contrast between 80-90, keep sharpness below 30. just have a play around till you find what best suits the source material.
Mar 25, 2008 | Samsung LE40R74BDX 40 in. LCD Television
Colour distortion at the sides of the picture
check to see if you do not have speakers on the side of your tv or any where around it.which could be causing your problem.
Jun 09, 2007 | Sony FD Trinitron WEGA KV-29LS35 29" TV
Televison & Video Logo
Top Televison & Video Experts
