Question about Brother CS-8150 Computerized Sewing Machine
Machine makes a loud noise and will not make stitches.
I have a Brother CS-8150 that has only been used a few short months. My daughter accidentally knocked it over on the floor and ever since then it will not work properly. If I try to sew a few stitches there is a loud grinding noise and the bottom stitches are not picked up. Today I took it apart because I got the "safety mechanism is engaged" when I pushed the needle position button a few too many times. The machine will move the needle, but I can hear the grinding coming from the wheel on the side. Could it have been a belt that was knocked out of place? I have checked for burs, stuck thread and everything. Any suggestions would be greatly appreciated.
  • brandbmg Oct 24, 2008
    Will do! Thanks so much for your answer!
  • 46 Answers
Sounds like something is broken. best to get it checked out. take to the sewing machine doctor.
Posted on Oct 24, 2008
My sister has gifted me a sewing machine. it's details are here--brother made in taiwan, 120v,60hz ac, 90w ,listed sewing machine ,ul 273c...i don't know how to use this machine..it is working with...
Hi
Manuals for Brother machines are usually available from the Brother site.
http://www.brother-usa.com/manuals/default.aspx?PGID=3
They have one for the CS-8150 but I'm not sure if this is your machine or if the model number is UL273C.
The manual for the CS-8150 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_8150_EN_183.PDF
The manual for ULT2001 is here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_ULT_2001_EN_200.PDF
Maybe one of them is similar enough to your machine.
Hope this helps!
Oct 28, 2010 | Brother CS-8150 Computerized Sewing...
Wanted a maintenace manual
i was able to fnd manual at www.ifixmachines.com
Jan 25, 2010 | Brother CS-8150 Computerized Sewing...
Stitching problem
bunching up on the bottom means that there is no upper tension...
Jul 21, 2009 | Brother CS-8150 Computerized Sewing...
I need to know how to change the bulb on a brother ps 33 sewing machine!
Hi, thank you for using FixYa! I don't see a model PS-33, however; you posted in the CS-8150 machine section, the link to the manual for a CS-8150 machine is attached. It has a section for winding and installing the bobbin and another section for upper threading. If your machine is not the CS-8150, please comment with the correct model number (PS machines start at number 1450 and increment upwards). If this is the correct manual, would you please take minute to rate this solution? Thank you! Gregg
Mar 29, 2009 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Won't Work in Reverse
Look at the feed dogs under the foot see if they are raised high enough to pull the material through.
Nov 13, 2008 | Brother CS-8150 Computerized Sewing...
Ruffler/gathering foot
There is a ruffling foot for brother machines. Google Brothers sewing machine feet and I am sure you will find a automatic ruffling foot.
Sep 05, 2008 | Brother CS-8150 Computerized Sewing...
Brother Super Galaxie 2100 Buttonhole lever not working
I have a problem with my CS 8150 which sometimes tells me to lower the pressure foot even though I had already did it. What clears the problem for me is that I eject the thread cassette and re-install and I can go ahead and sew. Try that to see if it will quit telling you to pull down the lever.
Sep 03, 2008 | Brother CS-8150 Computerized Sewing...
Brother Sewing Machine model:CS8150 bobbin thread problems
The top of the machine is not threaded correctly. First raise the presserfot then rethread the machine. Bottom looping is usually caused by a lack of top tension. There could allso be a bur on the hook.
Feb 22, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-8150 Computerized Sewing Machine Logo
512 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
