Question about Lands Phones
Nec dterm80 phone change name on my extension
I have looked through the solutions for the nec dterm80 phone for this particular problem, and they don't seem to work. I am unable to program my name on my extension. How can I do this?
  • Anonymous Apr 24, 2009
    I need to change my name on my Dterm80 phone and it is not in the manual
SOURCE: Change time on nec dterm80 phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time in 24 hour format. For example at 2.56 p.m. type 1456. Then press speaker again and you're done
Posted on Apr 22, 2008
SOURCE: NEC Dterm80 Name change
OK, I got this from somewhere else. But anyways, pick up the phone and dial 700, then dial the extension number, then finally you can punch in the name like you would doing a text message. When you're done, hit Hold, hang up, and hit Speaker twice.
Posted on Sep 05, 2008
SOURCE: NEC Dterm 80
http://www.battscom.net/User%20Guides/IPK/IPK%20Multiline%20Telephone%20UG_2b.pdf
Posted on Oct 10, 2008
SOURCE: How do you disable DND on NEC Dterm 80 phone WITHOUT DND button
Feature 69 feature
Posted on Apr 01, 2009
  • 3 Answers
SOURCE: NEC Dterm80 ring tone
To here ring types hit speaker then 711, then 1 for internal rings (select 2 for outside ring selection) then 1-8 the ring type.
To set ring type hit speaker then 720 (follow all the steps above).
Posted on Jul 28, 2009
How to disable do not disturb on NEC Dterm80 phone?
Have a coworker call your extension to see if DND is on, they will go straight to voicemail or get a fast busy. Speaker 42 may be the default cancel DND code, depending on your system and whether the codes were changed. Anyway, ringing is set up in system programming. If someone calls your extension it will likely ring, but outside calls have to be assigned to ring in system programming. Usually need a tech to do the programming since it gets complicated very quickly.
Sep 09, 2014 | NEC Dterm DTP 16D-1 Corded Phone
How do you change name on display on a dterm80 phone
You can modify the name display only if you have access to the PBX. What type of PBX are you using?
Mar 30, 2011 | NEC Lands Phones
I need to change a name on a particular internal extension line, but I dont have a code. How do I do it. It's for an NEC Dterm Series i
To change the name I believe you have to go into the voice mailbox for that extension, and change the recorded name.
Mar 07, 2011 | Lands Phones
I am trying to change the name displayed on my nec i-series phone. How do i do this?
Assuming you are not an NEC trained Tech and your system is on a IPKII, You will best served by acquiring the IPKII Instalation manual and the Feature and services Manual.
This is not the kind of simple change that the average end user should attempt although I would agree that it is a feature that should have been made availiable to the average user because of occasional movement in
any office environment.
Jul 22, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I am new at a company that has NEC phones (I have the main line)
you would need to enter program mode and in MB 4-18 enter the correct names for each port(extension). ldtsnj.com
Mar 12, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
Trying to change the name on the display on the phone
Dial 700>dial your ext #>enter name>press Hold & press Speaker
Feb 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Jan 17, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Dterm80 NEC phone
How do I get the following off my display?
MSG >>> In-Mail #2
Sep 12, 2007 | NEC Dterm DTP 16D-1 Corded Phone
Lands Phones Logo
1,034 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
